Thread Tools Rating: Thread Rating: 154 votes, 4.97 average. Display Modes
Old 12-21-2012, 11:39 AM   #2221
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,958
Why!
Not just buy a brand new one, like $125. or so. I'd love one of these.
RED CAT is offline   Reply With Quote
Old 12-21-2012, 11:54 AM   #2222
grizzzly
The Pre-Banned Version
grizzzly's Avatar
Oddometer: 3,340
if i can get a slide for $40 why spend the extra $85
you actually expect people to take responsibility for their actions in today's society?!
grizzzly is offline   Reply With Quote
Old 12-21-2012, 11:55 AM   #2223
prince_ruben
prince_ruben's Avatar
Oddometer: 1,726
Anyone shoot a S&W M&P .22? Was thinking of picking one up. My current .22 it's the Remington 597 and I want an upgrade.
Sent from my DROID RAZR using Tapatalk 2
No worries in death, no worries in life.
prince_ruben is offline   Reply With Quote
Old 12-21-2012, 11:58 AM   #2224
Boondoggle
Gear Grinder
Boondoggle's Avatar
Oddometer: 15,488
because then you'll go get a slide anyway and have TWO of 'em
____
Public Service Announcement: even for asshats, suggesting they set themselves on fire is a bit much.
What is wrong with you guys? -RapidWife
I've been poking a giant bouncy ball with a needle. You feel anything yet? -Blake716
Boondoggle is offline   Reply With Quote
Old 12-21-2012, 02:33 PM   #2225
selaznog
Avoiding pavement
Oddometer: 2,891
Scope?
I just bought myself a Ruger 10/22 Takedown. After discovering that my vision is not what it once was, I've decided to add a scope. What do you guys recommend that is on the inexpensive side, recognizing that I am only an occasional shooter?
selaznog is offline   Reply With Quote
Old 12-21-2012, 03:08 PM   #2226
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 8,581
Any cheap $50 3x9 scope should handle the "stress" of a .22-- from there its just how much fluff you wanna pay for.
Day Trippin'- Endless Utah
Signal is offline   Reply With Quote
Old 12-21-2012, 03:11 PM   #2227
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 45,363
I've been meaning to ask the Collective on this one: does anyone have an opinion on the longer-term accuracy of the takedown model? And if it's negative, please be sure to phrase your answer in a manner that doesn't give selaznog buyer's remorse
"When I joined ADV I was a fuckin brain surgeon, but 24,745 clicks from you and I can barely wipe my ass." Bender, former brain surgeon.
Hedge36 is offline   Reply With Quote
Old 12-21-2012, 04:00 PM   #2228
RustySpokes
Two-bit throttle bum
RustySpokes's Avatar
Oddometer: 1,065
Well, they are pretty new to the market but from what what I've read they might just be more accurate than the regular version if not the same. Of course I'm trying to sell myself on one so I may be biased...
RustySpokes is offline   Reply With Quote
Old 12-21-2012, 05:12 PM   #2229
PunkinHead
Moobless Adventurer
PunkinHead's Avatar
Oddometer: 5,975
I bought a BSA Sweet 22 9x40 for one of our 10/22's and was pleasantly surprised. I thought the range adjustment based on bullet weight was kind of gimmicky, but it actually works pretty well within the normal operating range of a .22 (25-100 yards).
PunkinHead is offline   Reply With Quote
Old 12-21-2012, 05:40 PM   #2230
Fire Escape
Fire Escape's Avatar
Oddometer: 1,572
Something small and light would seem appropriate for the 'Take-Down'. While most any lower power scope will probably be OK, keep in mind that most .22 scopes are set to be paralax free at 50 yards while 'high power' (as in the rifle not the magnification) scopes are more often set to be paralax free at 100 yards or more, unless the scope in question has user variable paralax adjustment (i.e. adjustable objective) and that is generally on more expensive models. A .22 specific scope may be a better choice for that reason.
What is paralax and why do you care? Paralax is the movement of the 'cross hairs' in conjuction with the position of your eye (while the actual scope is not moved), the gun is fixed but as your eye position is changed the cross hairs move. Set the scope on something secure, looking at a distance close to what you expect to shoot most often and move your head around a bit to see if and how much the aiming point seems to change. If you like it, buy it if the amount of paralax is problematic try another scope. I have bought scopes without being able to look through them (usually with 'higher' grade stuff) but really prefer to get a 'test look' whenever possible.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 12-21-2012, 05:41 PM   #2231
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,485
I agree.
The critics of cheap scopes often point out how poorly they re-zero after adjusting settings for windage.
I have one on an AR15, and it's held its zero through a lot of rounds simply because I set it once and then stopped messing with it.
Mambo Dave is offline   Reply With Quote
Old 12-21-2012, 07:26 PM   #2232
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
If you want to use the stock case with the take down you might not be able to use a larger scope, both pieces won't fit.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 12-22-2012, 02:30 AM   #2233
Aghartha
Awesome
Aghartha's Avatar
Oddometer: 340
1-4x compact is what I'd likely go with
Aghartha is offline   Reply With Quote
Old 12-22-2012, 09:40 AM   #2234
selaznog
Avoiding pavement
Oddometer: 2,891
Thanks for the recommendations. The size of the scope is not a huge issue. I bought the takedown model so that I could fit it in a backpack when riding a dirt bike. My house backs up to BLM land and there is a makeshift range about two miles away. I found a cheapo 3-9x40. I'm not pleased with the rings that were included, but we'll see. I just need a case that is more like a sock, which shouldn't be hard to find.
Oh, and in this age of soaring gun prices. Sportsman's Warehouse had a bunch of 10/22 takedowns for $309, which is a lot less than I paid last week when I could find only one locally.
Old 12-22-2012, 11:32 AM   #2235
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 1,117
You will enjoy the TD. Loving mine. Fun for my son and I to shoot. I put a small BSA on mine and it works very well. Also fits in my Oakley packpack for the moto ride in.
Have since put the straight tube on the Tapco stock for the scope. The angled was good for the iron sights, but he straight is better for the scope.
Matto
mattomoto is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 12:36 AM.
