Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 216 votes, 4.98 average. Display Modes
Old 11-23-2010, 09:30 PM   #616
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
Originally Posted by Denis
Thanks, that's an interesting site. I'm going to try the bore snake.
Denis
You're welcome, Denis. Boresnakes are OK for a quick field quality cleaning. Just remember never to use a wire bore brush on a stainless steel barrel. Not sure if your Marlin is a stainless steel barrel. If it is, don't use a Boresnake, they have a wire brush in them.
I have many firearms, some with stainless steel barrels, some with chrome moly steel barrels. I've standardized my cleaning kit by using only nylon bore brushes on all my firearms. That way I don't have to worry about it. Bronze wire bore brushes will scratch your stainless steel barrels. They're fine for steel, but not stainless steel.
I like to use a nylon brush for applying the solvent to the bore. Take a small patch and wrap it around the brush, soak it with bore cleaner and push it through the bore. This gives you a nice snug fit in the barrel, with the "flex", of the brush providing for the snug fit. Better than using a jag or loop, IMO. Let the solvent sit for 10 minutes or so and then put the stab jag on the cleaning rod, "stab", a patch, give it a few drops of gun oil and push it through. Repeat 'til the patch comes out clean. "Stab", another patch, leave it dry and push it through. Repeat until the patch comes through dry. If you're going to store the firearm for awhile, oil a final patch and push it through and leave the bore sightly oiled. Before you shoot it, be sure to push a few dry patches through to remove the light oil film.
The Sweets 7.62 solvent is intended for removing copper fouling. You use it the same way as the Hoppes #9 solvent, but don't let it sit in the bore for more than 5 minutes. To "stop" the action of the Sweets, you'll need to push some oiled patches through the bore. The first one or two will come out with a green color on them. This is copper that has been transferred from the bullet to the bore. An excessive amount of this fouling will negatively affect accuracy. I'll use Sweets about every 500 rounds in high velocity rifles, like the .17 HMR, .308, 30-06, etc. In my .22's, I clean them once or twice a season with Hoppes only. My .22's shoot better with bore fouling. Also, it's best not to mix .22 ammo in the same firearm. Find a type that shoots good and stay with it. Because of the nature of .22's, it takes 10 or 15 rounds for an ammo brand to "settle in", due to different propellant types used in the cartridge. This is also true of center fire firearms.
If you hunt, this is something to be aware of as your first shot has to be dead on. After I sight in a hunting rifle, I give it a cleaning right at the range, then fire 3 or 4 rounds through it as "fouling" shots. I put it in the case and leave it that way until the season is over.
Here's a pic of my High Power competition rifle. It's not a .22, but a .223. Shoots good out at 600 yds!
[IMG][/IMG]
Stromdog is offline   Reply With Quote
Old 11-28-2010, 09:02 AM   #617
jeep44
junk collector
jeep44's Avatar
Oddometer: 2,094
Another inmate at the Museum of Walnut and Blued Steel-a Mossberg 46B, from about 1938 or so. That rear peep is variable, operating much like a camera shutter (the proper terms escape me at the moment). The lead-lapped bore is as shiny as glass.
jeep44 is offline   Reply With Quote
Old 11-28-2010, 10:02 AM   #618
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,322
Aperture.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 11-28-2010, 10:37 AM   #619
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,710
Merit adjustable iris sight disk, IIRC.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 11-28-2010, 10:44 AM   #620
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,322
I'm thinking about getting this for my 39a.
http://www.skinnersights.com/2.html
EvilGenius screwed with this post 11-28-2010 at 10:49 AM
Old 11-28-2010, 11:30 AM   #621
jeep44
junk collector
jeep44's Avatar
Oddometer: 2,094
That one looks like it has all the requirements to fit into my museum . For some reason, I have no lever-action or slide-action .22s. I have exactly one Marlin,too-an 81DL from the '50s.
Old 11-28-2010, 01:42 PM   #622
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,712
I've got one of those, minus the shiney disc.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 11-28-2010, 01:48 PM   #623
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,322
The sights too or just the rifle?
Old 11-29-2010, 04:39 AM   #624
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,712
Rifle, complete with the carry bag.
N. Texas
Old 12-11-2010, 02:23 PM   #625
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,727
Wondering if this is a legal weapon because the barrel is so short
Catalog Number: 10/22-FS | Model Number: 1261 | Caliber: .22 LR
Stock: Black Synthetic Finish: Black Matte
Barrel Length: 16.12" Overall Length: 36.25"
Material: Alloy Steel Length of Pull: 13.50"
Sights: None Weight: 4.30 lbs.
Grooves: 6 Twist: 1:16" RH
Capacity: 10 Suggested Retail: $316.00
Copyright 2010 by Sturm, Ruger & Co., I
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-11-2010, 04:35 PM   #626
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,710
Finish: Black Matte
A rifle with a barrel 16"and over is legal, and it looks like that one is 16.12".
Old 12-11-2010, 07:12 PM   #627
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
10-4, it's legal. The "ubiquitous" Ruger 10-22. A fine little rifle, for a number of reasons.
Old 12-11-2010, 07:13 PM   #628
Rusty Rocket
Life behind "Bars"
Oddometer: 9,727
I always thought it was 18" min. Learnt somethin' t'day. Thanks Andy
2009 DR650
Old 12-11-2010, 07:55 PM   #629
El Guero
V4 Whore
El Guero's Avatar
Oddometer: 9,727
I think the 18" may be for shotguns.
El Guero is offline   Reply With Quote
Old 12-11-2010, 08:39 PM   #630
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
Correct!
Thread Tools
Times are GMT -7.   It's 10:14 AM.
