Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 01-14-2011, 04:18 PM   #151
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 3,940
Send a message via AIM to BlueLghtning Send a message via MSN to BlueLghtning Send a message via Yahoo to BlueLghtning
Originally Posted by Sportourer View Post
New Question...
I just purchased a like new 478 from someone on Craigslist. The unit was never registered so when I registered it, I got a free update to 2011 maps which was great. Now, the bad part. There is an internal problem with this unit and the car speaker does not work. I called Garmin and they sent me a new one for free but it still doesn't work so the problem is definitely internal. I called them back and they said they need a reciept for me to send it in and get a free replacement which I don't have. Without a reciept it is a $150 replacement cost. I can get the sound out of the stereo output, but I wanted to mono one to work because my audio system has a mono input which will override the music and such coming from my Zumo which is where I get all audio. Anyway, this is getting complicated now so, here is the question. A good friend of mine got a new 478 a couple of years ago and it did the same thing. He sent it in and got a free replacement and the new one did the same thing in about 6 months. So, if I decide to spend the $150 and turn my great deal into a not so great one, can I expect mine to keep working or is this a common problem. I have a Street Pilot 3 that is 8 years old that the speaker works fine on, so I would like to believe a new 478 would solve the problem. But if it will fail again I guess I will need to just convert the stereo output to mono. Let me know...
I'm confused what speaker isn't working? The built in speaker the cig plug like this one?
So you are saying that is tied to something internal in the unit, not just through the plug? Hmm, my speaker on my cig cord still works fine and I've actually been using that plug in my tank bag for over a year when the other basic cig plug bit the dust? There is obviously the 3.5mm plug on the back? So it won't work for you because its stereo? You could just get a stereo to mono adapter? I've also seen some hardwire plugs with a mono plug built in. Not sure if the same thing carries the sound through though's as the cig plug?
I've never heard of that being a major problem on the 478's, but most people that
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650
Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225
Smugmug Pics - Save $5: Y2l43o9LVBERU
BlueLghtning is online now   Reply With Quote
Old 01-14-2011, 04:42 PM   #152
spidennis OP
SandStorm Adventures
spidennis's Avatar
Location: South Padre Island, Texas .... far from anything
Oddometer: 1,259
My cig plug speaker stopped working but sometimes it will work for a short time. I'm thinking it's a bad connection. My stereo jack on the back works just fine though.
2003 Yamaha WR250F (texas street legal, my primary ride, oh yeah baby!)
List of mods and rides:
http://www.sandslave.com/2003wr250f/
List of my Spot Tracker Adventures:
http://www.spotadventures.com/user/p...?user_id=53368
spidennis is offline   Reply With Quote
Old 01-15-2011, 02:15 AM   #153
Jamie Z
Jamie Z's Avatar
Oddometer: 6,979
Send a message via Skype™ to Jamie Z
I had this same problem with my 478, even down to Garmin sending me a new speaker plug, which didn't fix it, and my lack of receipt. I had no choice but to accept this problem or to try to fix it myself. I took my GPS apart, cleaned up a few contacts and tested the sound. It worked! Yay. I reassembled it, and it no longer worked. Boo.
After several trials, here's what I found worked for me. Refer to the picture below.
The ring around the antenna connector shown in this picture was too tight. If I loosened it up (use a pair of needle nose pliers) my sound worked. If I tightened it, the sound went away. The truth is, I couldn't figure out why this fixed it... but it did, so I can't complain.
That's the easiest fix to try first. If that doesn't work, I can give you more detailed instructions on what different things I tried to fix the sound on my GPS.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is offline   Reply With Quote
Old 01-17-2011, 04:41 AM   #154
Sportourer
Sportourer's Avatar
Oddometer: 63
Jamie,
Thanks for the advice. I am a mechanic for a living so I have no problem taking the unit apart if that will fix it. I am away from home at work for the next few days so I don't have the GPS with me. I will try the antenna ring first as you suggested and if it doesn't work I will let you know and ask what else you did.
Alex Schmitt
Bethel, NY
IBA#364
STOC#4028
AMA#372280
Sportourer is offline   Reply With Quote
Old 01-17-2011, 10:56 AM   #155
mcnut
Oddometer: 1,153
The antenna connector on most models is powered to supply power to the optional amplified external antennas. A short there would certainly cause a problem!
Bruce
mcnut is offline   Reply With Quote
Old 01-19-2011, 12:27 AM   #156
Jamie Z
Jamie Z's Avatar
Oddometer: 6,979
More specifically, I found I only needed to loosen the ring maybe half a turn and then the sound worked. If I snugged up the ring, the sound quit working.
Jamie
Old 02-02-2011, 01:08 PM   #157
Sportourer
Sportourer's Avatar
Oddometer: 63
Jamie,
I finally got around to doing this. I loosened the ring a little bit and the sound now works! I can't believe this fixed it. I am sure glad I asked about this on here and did not send the unit in. Thanks again for the help!
Alex Schmitt
Bethel, NY
IBA#364
STOC#4028
AMA#372280
Old 02-03-2011, 01:20 AM   #158
Jamie Z
Jamie Z's Avatar
Oddometer: 6,979
Jamie,
Holy cow! It worked. I can't believe it either. Must be some sort of flaw in the design or manufacture so that tightening the external antenna ring opens or shorts some circuit inside.
I've been wondering if you ever gave it a shot. Thanks for posting your result.
Jamie
Old 02-04-2011, 11:37 AM   #159
Sportourer
Sportourer's Avatar
Oddometer: 63
Jamie,
I wonder if you were to take the unit apart and put a small washer in place which would allow the antenna post to be tightened but not pull on the board if that would totally fix it? If I have a problem with it cutting out I might try this but until then I don't want to take the unit apart if I don't have to. Loctite is always another solution as well if it wants to loosen up. On another note, I read your travel article. Very nice. I do a lot of what you say myself but I did learn a few new ideas. I can't say I am as thrifty as you, but I did just do a 14,000 mile trip to Alaska and back on a 1987 Transalp. The only time I did not camp was when I stayed at the University of Fairbanks in a dorm room for $20 which I split with someone and in a couple of peoples' houses along the way. It is the only way you can travel these days without spending a fortune.
Alex Schmitt
Bethel, NY
IBA#364
STOC#4028
AMA#372280
Old 02-04-2011, 11:40 AM   #160
Sportourer
Sportourer's Avatar
Oddometer: 63
New 478 Question...
I am wondering if anyone has used the boat mount on their bike? I want to use the unit on my ST1100 and Transalp. I plan on getting a Touratech mount for the Transalp when I get lucky enough to score a used one hopefully. But for the ST1100 it seems like the boat mount should be rugged enough. What are your thoughts?
Alex Schmitt
Bethel, NY
IBA#364
STOC#4028
AMA#372280
Old 02-05-2011, 03:01 AM   #161
Jamie Z
Jamie Z's Avatar
Oddometer: 6,979
New 478 Question...
As far as I remember, that's what I'm using. It's been a year or two since I mounted it.
Jamie
Old 02-05-2011, 05:27 AM   #162
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,352
New 478 Question...
Why not use a ram system mount to your touratech bracket, then you can swap the mount from bike to bike.
This is what I've got. I have a ram ball of each of my bikes and just swap the arm and mount over.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx
You can be Han Solo, and I can be another Han Solo...
Old 02-05-2011, 10:58 AM   #163
Jamie Z
Jamie Z's Avatar
Oddometer: 6,979
Yup. The Garmin marine cradle is RAM compatible. In my opinion a better cradle than the RAM cradle. I really like RAM, except for their cradles.
Jamie
Old 02-05-2011, 02:52 PM   #164
SCflyer
SCflyer's Avatar
Oddometer: 1,322
4.30 software update out
May be old news but to those that didn't know...
Softwa
Changes made from version 4.20 to 4.30:
  • Improved GPS satellite acquisition processing
  • Updated magnetic variation table with IGRF 2010 modelre update 4.30 is out.
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 03-03-2011, 08:33 AM   #165
spidennis OP
spidennis's Avatar
Oddometer: 1,259
date and time
I'm having a problem with changing the date and time. In setup it won't allow me to change it. It has the wrong date and time, needless to say it can't find any satellites and the position marks it as in the Atlantic off Africa somewhere.
I got on an alrliner from texas to the east coast and from that point on it's had troubles.
Is this the internal memory battery problem?
Times are GMT -7.   It's 05:19 AM.
