Thread Tools Search this Thread Rating: Thread Rating: 280 votes, 5.00 average. Display Modes
Old 08-28-2012, 06:12 PM   #331
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 663
BaseCamp or MapSource will work fine. I'd recommend breaking the trip up into a route or track for each day rather than one long one. Much more manageable. You can easily plan for options and just name the route accordingly. You run the risk of having too many shaping or via points and getting a truncated route with a long route.
SW
The Weather in my Backyard
Steve W is offline   Reply With Quote
Old 08-29-2012, 08:04 AM   #332
dlh62c
Oddometer: 1,603
That's how I do it.
In Basecamp, sometimes I put in a proximity value for my starting waypoint, something like 250 miles. In BC, a red circle with a radius of 250 miles will appear around the waypoint. The 250 miles might be my ride limit for the day. I then search for some type of lodging just inside or outside the radius along the route or track I'm following.
daryl
Old 08-29-2012, 08:36 AM   #333
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,768
daryl
What a good idea! Thanks.
Gracie's Gold
Lobby is offline   Reply With Quote
Old 08-29-2012, 09:37 AM   #334
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 663
That's how I do it.
daryl
Brilliant!!!
SW
Old 08-29-2012, 10:34 AM   #335
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,996
That's how I do it.
daryl
When you put in very large Proximity Alarms, just remember to remove them before you transfer the Waypoint to your GPS. Otherwise you will get a nearing/approaching anytime you turn on the GPS while you are within the Proximity radius and a leaving alarm as you pass thru the radius - which may not have any on-screen [map] meaning since you won't be seeing the waypoint most likely.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 08-29-2012, 11:12 AM   #336
dlh62c
Oddometer: 1,603
Cheers,
I'm well aware of that.
daryl
Old 01-31-2013, 02:22 PM   #337
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,100
Which XM antenna?
Recently purchased a 478, upgraded the firmware to 4.40 which says it supports the GXM-40 antenna, but I've read in certain forums that it also removed support for the GXM-30. Anybody successfully running 4.40 with a GXM-30? I need to know which antenna I should be looking for in order to enable weather. Thanks!
Starchamp is offline   Reply With Quote
Old 01-31-2013, 02:29 PM   #338
spidennis OP
SandStorm Adventures
spidennis's Avatar
Location: South Padre Island, Texas .... far from anything
Oddometer: 1,275
Good Question! keep us updated ...... I'm still using a 30 but hadn't upgraded since I got the 478.
2003 Yamaha WR250F (texas street legal, my primary ride, oh yeah baby!)
List of mods and rides:
http://www.sandslave.com/2003wr250f/
List of my Spot Tracker Adventures:
http://www.spotadventures.com/user/p...?user_id=53368
spidennis is offline   Reply With Quote
Old 02-02-2013, 06:01 PM   #339
Dagwood08
Oddometer: 3
I too recently purchased a 478 and upgraded the firmware to 4.40. I have a GXM-30 and can receive the preview channel but have not yet subscribed to anything. Not sure if this helps much with the recent question.
Dagwood08 is offline   Reply With Quote
Old 02-02-2013, 06:36 PM   #340
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,100
It does help, yes. But I went ahead and got the GXM-40 anyway, since it was pretty much the same price. Good to know that I have options, though!
Old 02-02-2013, 07:11 PM   #341
Lurch II
Lurch II's Avatar
Oddometer: 615
I have a 478 that I upgraded to 4.40 and am using the 30 with no issues.
Shawn
2007 R1200GSA - Lurch II (his)
2007 R1200GS - Wickd (hers)
"Dying is a very dull, dreary affair. And my advice to you is to have nothing whatever to do with it." - W. Somerset Maugham
Lurch II is offline   Reply With Quote
Old 02-15-2013, 07:09 PM   #342
Dagwood08
Oddometer: 3
How do you prevent the active track log from displaying during navigation on the map page on the 478? I have the color set to transparent on the track setup menu tab but the track still appears in white. If I select any of the colors they all seem to work properly, but the transparent choice still draws the track.
Old 02-16-2013, 07:38 AM   #343
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,339
Just looked and not sure you can on the Active Log? I know on any saved tracks, you can un-select the box to show on map, but you don't have that option on the active log, only color. So even transparent, you can see pretty good? Are any of the other colors even less visible? I usually keep mine in Cyan as I like to really see it.
Just curious, but what is it about the active log being visible that bugs you? Unless you are in the same area going round and round, its usually just behind you on where you've been.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 02-16-2013, 05:09 PM   #344
Dagwood08
Oddometer: 3
The active track log appears as a breadcrumb trail in white. The color you choose actually is a highlight over the white breadcrumbs so no matter what color you choose the white breadcrumbs are always there, no way to not show them (that I can figure out).
I've only had my unit a short period of time and have been using it on short local trips. That's probably why the appearance of the log stands out as I've been back and forth on the same roads. As you alluded to, on longer distances it likely won't be an issue. Also, none of my other GPS's have this feature so it's a matter of getting used to it.
Thanks for your input.
Old 02-17-2013, 07:31 AM   #345
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 663
You could just turn track recording function to "off" for everyday riding. This will stop the breadcrumb trail from being displayed. Just remember to turn it back on for trips you want to save the track.
SW
Times are GMT -7.   It's 03:41 PM.
