Thread Tools Rating: Thread Rating: 116 votes, 5.00 average. Display Modes
Old 10-29-2013, 06:47 AM   #2161
Bender
I can pass this guy.
Bender's Avatar
Oddometer: 36,842
Originally Posted by CousinLarry View Post
Damn that shit is fancy!! What's that go for? I have a couple of these cheapies, use them every time!!
I resisted the urge to maiden the wing at noght!! Bit i have it here with me and aupposed to be 5mph wind this afternoon so I shall maiden it today.
I got three of those for 6 bucks and they work just fine.
Bender™
Bender is offline   Reply With Quote
Old 10-29-2013, 06:49 AM   #2162
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
Originally Posted by andoulli View Post
Batteries are 3s 3200 mAh 20c LiPo and I'm charging them at a 3.2 amp rate on the Onyx. I could not find a recommended charge rate for them but they are 1c batteries so 3.2 should be about right.
Ya, sounds about right. If you don't have a balancer or a charger that will balance you should get one.
"Fools you are. To say you learn by your experience. I prefer to profit by others' mistakes and avoid the price of my own."
- Otto von Bismarck
biggziff is offline   Reply With Quote
Old 10-29-2013, 06:51 AM   #2163
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
Good point^^ I have gotten in to the habit of setting my TX down on the ground while I'm plugging in batteries or moving the airplanes to the flight line. I don't want anything to touch that throttle by accident! A 13" prop being spun by 16v wouldn't feel good.
I setup Throttle Cut on every model and use it faithfully. Another advantage of a computer radio.
- Otto von Bismarck
Old 10-29-2013, 07:02 AM   #2164
CousinLarry
Ridin Dirty
CousinLarry's Avatar
Oddometer: 664
Yeah that works too but i've flipped that switch by accident before! It's a long one that seems to catch on shirts and stuff. Hahaaa
Basically I don't trust myself so that's why the TX sits by itself when I'm powering up.
2000 KTM 200 EXC with a street plate
CousinLarry is offline   Reply With Quote
Old 10-29-2013, 07:03 AM   #2165
RC Pilot OP
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,658
I'm flying 15 minute runs and my batteries are taking less than 1500 mah to top off. Is that in the ball park?
Yep, the Apprentice is very easy on the batteries.
Yea, whatever.
RC Pilot is online now   Reply With Quote
Old 10-29-2013, 07:04 AM   #2166
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
Yup....better safe than have scars like me.
- Otto von Bismarck
Old 10-29-2013, 08:10 AM   #2167
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,287
x2. Btdt, not fun.
Modern Brushless speed controls typically will NOT arm themselves unless it senses the lowest throttle point on the transmitter. I don't know if the lower quality units from HK or the likes do that, so I typically buy Castle Creations or the likes, ones that I know won't arm unless the low throttle point is sensed.
Because of this arming feature, I either use the throttle cut or push the throttle stick to FULL throttle (sometimes a combination of both, to lock the throttle at full) before powering up the speed control- the ESC will power up, but will not arm itself for motor functions until it senses that low throttle point. Preflight protocols can prevent incidents from happening, and I practiced them until it turned into a habit. I can't even do anything else before powering up the model now, I HAVE to do a preflight.
2004 KLR650
Team Hitec, Customer support Representative.
XpressCS screwed with this post 10-29-2013 at 08:15 AM
XpressCS is offline   Reply With Quote
Old 10-29-2013, 08:57 AM   #2168
RC Pilot OP
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,658
The safest ESC I have is actually an older 45SS. It will not arm the motor unless the following is done. Turned on with throttle at lowest point, move throttle to full, wait for two beep and then return to lowest point.
Yea, whatever.
Old 10-29-2013, 08:59 AM   #2169
RC Pilot OP
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,658
Used this
and a friends Go Pro to film this
Yea, whatever.
Old 10-29-2013, 04:40 PM   #2170
a65l
Wise guy, eh?
a65l's Avatar
Oddometer: 1,511
I may just be lucky, but to date I've never had an un commanded startup of an electric motor. I do not use an idle cutoff or an arming switch. Again, I may just be lucky, but I make it a point to always carry my transmitter with my thumb over the throttle stick, holding it in the min throttle position. I dislike making things more complicated than they absolutely need to be. More steps are more steps to forget or skip.
And just for reference, I always carry my stryker in my van, and almost always get a couple flights in at the field. This method has worked for me for the last 7 or so years. Not saying it'll work for everyone, but......
"It does not take so many words to speak the truth"
Chief Joseph
a65l is online now   Reply With Quote
Old 10-30-2013, 11:25 AM   #2171
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 2,090
Nice vid RCP....very stable platform
Jimmy the Heater is offline   Reply With Quote
Old 10-30-2013, 11:28 AM   #2172
RC Pilot OP
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,658
Thanks, it was a spur of the moment thing as a friend was using his Go Pro on his birds and asked if I wanted to put it on the Telemaster. I figured "why not" so we stuck a mount on the bottom and off we went.
Yea, whatever.
Old 10-30-2013, 01:56 PM   #2173
brewmann
brewmann's Avatar
Oddometer: 925
Been flying R/C for about 25 years..planes, helis & jets...here's some float flying with a Go-Pro on an Ultra Stick...
brewmann is offline   Reply With Quote
Old 10-31-2013, 01:47 PM   #2174
I_FLY_LOW
I_FLY_LOW's Avatar
Oddometer: 2,618
Just found what I want for Christmas...
Looks very similar to the real one I used to have, many years ago.
http://www.e-fliterc.com/Products/De...ProdID=EFL2790
I_FLY_LOW is offline   Reply With Quote
Old 10-31-2013, 06:51 PM   #2175
andoulli
CAJUN
andoulli's Avatar
Oddometer: 2,114
It's back ordered at Horizon. Many of their best offerings are. They had E-Flight Apprentices for about a week. Now they are back ordered as well. I checked every day on the Apprentice, it showed up for sale and I bought one, a week later and they are sold out again. I would be diligent, snooze you lose.
andoulli is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:16 AM.
