Thread Tools Rating: Thread Rating: 92 votes, 5.00 average. Display Modes
Old 03-17-2014, 05:22 AM   #2551
JeffinTD
JeffinTD's Avatar
Oddometer: 1,375
From the float fly last Saturday. CZ Carbon Cub, Magic, and. Apprentice.
Have: 09 R1200GSA, FLHR Road King, 680 Rincon, 500 Foreman.
Had: CX500, DR650, S2 Thunderbolt.
Need: To win the lottery so I can actually get time to ride.
JeffinTD is offline   Reply With Quote
Old 03-17-2014, 05:49 AM   #2552
FPGT72
Oddometer: 5,777
Float fly?
Here the water is solid again....Saturday it was 70.
sigh.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant'
is like calling a drug dealer an 'unlicensed pharmacist
[/FONT]
FPGT72 is offline   Reply With Quote
Old 03-17-2014, 12:21 PM   #2553
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,192
Is that a Magic 3D I spy?
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Old 03-19-2014, 03:53 PM   #2554
HapHazard
t00 0ld 2b n00b
HapHazard's Avatar
Oddometer: 2,231
In between dropping tiny screws on the floor that zip off into the 8th dimension while assembling my "Ready to Fly" Sky Surfer, I've been using the easyFly 4 simulator.
It reminded me that I'm better at making left turns than right turns. Come to think of it, on dirt bikes, too.
Anyone else?
HapHazard is offline   Reply With Quote
Old 03-19-2014, 05:13 PM   #2555
XR650L_Dave
Oddometer: 3,724
Left easier, bicycles, motorcycles, and RC planes.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 03-20-2014, 11:25 AM   #2556
XpressCS
XpressCS's Avatar
Oddometer: 1,192
You get used to steering the plane all over.
I'm biased in right rolling harriers, but can fly left/right in any other attitude just fine.
2004 KLR650
Old 03-20-2014, 01:37 PM   #2557
CousinLarry
Ridin Dirty
CousinLarry's Avatar
Oddometer: 623
New toy on it's way!
Got rid o my Gaui X2 and this will take it's place.
6S powah!!!!
Can't wait.
2000 KTM 200 EXC with a street plate
CousinLarry is offline   Reply With Quote
Old 03-20-2014, 05:01 PM   #2558
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 1,895
My RC nut neighbor is trying to convince me to get an Apprentice S, however I absolutely do not get along well with tricycle landing gear. My T28 and I just never got along when it comes to landings.
I was wondering if I could convert it to a taildragger and then make a stand that holds it level when initializing and calibrating the SAFE system? Would that cause any problems on initial rollout with the plane thinking its too nose high?
Jimmy the Heater is offline   Reply With Quote
Old 03-21-2014, 04:43 PM   #2559
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,867
Are you a beginner? Trike gear is better if you're starting out. Tail-draggers are definitely harder to control on the ground. If you have trouble with the nose gear, you might have trouble with prop strikes on a tail-dragger.
'12 Moto Guzzi Stelvio NTX
'06 Honda Helix
Mr. B is offline   Reply With Quote
Old 03-21-2014, 05:38 PM   #2560
Buzzbomber
Not Dr. Who...
Buzzbomber's Avatar
Oddometer: 1,253
I haven't found that to be the case. Trike gear may be better on a nice hard surfaced runway but I've always found it to be a PITA on the grass runways at the fields our club flies from. My first glow powered plane was a Kadet LT-25 so I might be biased.
Buzzbomber is offline   Reply With Quote
Old 03-21-2014, 07:47 PM   #2561
XR650L_Dave
Oddometer: 3,724
I can see someone not having problems with a tail-dragger or tailwheel plane, some people just 'get' it.
Off grass is a lot easier than off pavement, of course.
I would be surprised that someone would have trouble with a trike setup, assuming the setup was OK.
I could see problems dialing in a perfect trike landing if tailwheel was learned first.
Old 03-21-2014, 08:33 PM   #2562
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,867
I agree. Tricycle gear is a PITA on grass unless you have big honking wheels.
'06 Honda Helix
Old 03-22-2014, 12:09 AM   #2563
Jimmy the Heater
Tilting the Horizon
Oddometer: 1,895
I would say I'm an intermediate. I have a T28 that I do ok with on everything but take offs and landings. All my taildraggers and my Radian, I can grease landings no problem and take off is easy too.
90% of my flying is done off of grass. However even on pavement the T28 gives me fits. Setup seems to be ok, my neighbor can fly it ok, I just don't have the tricycle gene I guess.
Anyway, beyond that, any issues with converting the Apprentice S to taildragger?
Old 03-22-2014, 04:14 AM   #2564
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,867
I don't think there would be a problem with the stability gizmo if it can initiate itself as usual. I suspect the issues will be maintaining the CG (Center of Gravity) and getting the plane to sit on the new tail wheel once you remove the nose gear.
'06 Honda Helix
Old 03-22-2014, 02:31 PM   #2565
a65l
Wise guy, eh?
a65l's Avatar
Oddometer: 1,365
Nah. Converting to tail dragger is as easy as it can be. The hard part is finding suitable structure to mount the new main gear to. I've had to cut out the bottom of the fuselage on a couple airplanes and epoxy in a plywood gear mount plate, then reinforce it with triangle stock. The only bit of engineering is to make sure the mains are at least on, preferably forward, of the CG. Generally, I've found the hardest part to be engineering a steerable tailwheel. I've converted a couple tricycle trainers to taildraggers, and always liked them better that way.
I haven't had any experience with the self-stabilization thingies, but I couldn't imagine that it would give you much trouble. And if you're flying taildraggers, you probably don't need it anymore anyway.....
"It does not take so many words to speak the truth"
Chief Joseph
a65l is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 01:56 AM.
