Thread Tools Rating: Thread Rating: 98 votes, 5.00 average. Display Modes
Old 08-16-2012, 08:46 PM   #1411
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
And my A380 just showed up today.
'06 KTM 950 Adventure S
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox
"The bouncer is a bulldog who looks like Wilford Brimley and the password is 'diabetus'"-Stefon, SNL character
DakarNick is offline   Reply With Quote
Old 08-30-2012, 04:47 PM   #1412
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
Flew three packs in the Great Hall (banquet hall) after work. Those paper balls are hard-to-avoid obstacles!
Video here
VIDEO0018.mp4
Taken with phone's camera so excuse the poor quality. I thought of it last minute and just tucked it in my transmitter's strap.
I THINK wifey is getting me a Go Pro for my birthday next week :)
DakarNick screwed with this post 09-01-2012 at 09:46 AM
Old 08-31-2012, 09:44 AM   #1413
Saget
Not quite a full house
Saget's Avatar
Oddometer: 480
Nice flying in a small space! Did you get those airliners going?
_______________________________
http://gbergimages.smugmug.com
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
Saget is offline   Reply With Quote
Old 08-31-2012, 09:53 AM   #1414
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
Thanks, indoors is bad for space but good for no wind! If those damn balls and tables and chairs weren't there it'd be better!
I did get them going. The 380 is still stock. Flies pretty well. No video of that yet. The MD-11 is fun but I kept crashing it outside. The wind was too much. So, I took the next bigger tail motor and rotor (off of a Blade 120SR heli). It's heavier but has much more thrust.
Here is a short video.
VIDEO0018.mp4
My other project is finished. A radio controlled spider on a fishing line. It's on a spool/drum powered by a continuous-rotation servo. I work at a wildlife museum so I've been scaring employees with it.
Next up is I think I'll try to put vectored thrust on my Crack Yak (the foamy in the video). Why not, right? Let's see how tight of loop I can get.
DakarNick screwed with this post 09-01-2012 at 09:41 AM
Old 08-31-2012, 10:02 AM   #1415
Saget
Saget's Avatar
Oddometer: 480
An R/C spider?? That's different. Need some video of your cow-orker's reactions!
Here's my latest project that I just got flying. As you can see in the video it has some roll oscillations that I'm working on. The gyro is adjustable on each axis, so it's just a matter of time before I get it right.
Retracts aren't necessary, I just thought it would be cool.
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
Saget screwed with this post 10-03-2012 at 11:48 AM
Old 08-31-2012, 10:37 AM   #1416
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
It's just on the elevator channel for up/down from a ledge/above a desk, but I can put it anywhere. I was thinking along the floor also It's R/C rather than on a motion detector so I can a) time the drop, b) put expo on the servo so I can creep it or yank it fast, and c) for bi-directional control.
Next for work is a servo to pull a pin and drop a rubber snake on unsuspecting customers...er, coworkers.
I'll get some hidden camera footage for sure!
Youtube is blocked here, I'll check out your video ASAP.
Old 08-31-2012, 11:16 AM   #1417
Saget
Saget's Avatar
Oddometer: 480
Hilarious!
Here's a screen shot until then:
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
Old 08-31-2012, 01:25 PM   #1418
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
Nice! That looks like fun!
Old 08-31-2012, 09:00 PM   #1419
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
Watched the video. Very cool! I love the retracts!
I was never really interested in quads until I got the E-Flite mQX. Fun little things!
Old 09-01-2012, 09:25 AM   #1420
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
Here is my spider. I got one of the housekeeping girls, the CEO's assistant, and the VP of Development Made them all jump! Cameras to capture the shock is the next step!
Here are some pics and video of it. Got embed to work. Forgot I hace to click on the little "A/A" box in the right hand corner.
The case/box is enclosed for a few reasons. To cut down on noise, so I could mount some guide wheels, and so it's easy to set up and hide (I'll eventually paint it.
Why so big? Well, servos are usually strong but slow. So, to get the speed I needed at full stick I had to increase the circumerence of the drum. It now drops about 20 feet in six seconds.
Open
VIDEO0021.mp4
Closed
VIDEO0020.mp4
Box with carrying strap
6V DC adapter input and on/off switch. I can also run it on a 7.4 2S with a BEC (used an ESC with capped motor leads).
Opened up. The wheel is on the door for easy access. The small foam wheels (one on door, one inside case) help keep the drum running smooth and align the fishing line into the brass guide tube.
Inside wheel
My brother's Dachshund (we're dogsitting), Phoebe, wondering what I'm doing.
Super scary spider. The slot is for the brass tube to line up flush with the outside of the box. I added these cleats but forgot to slice a hole for the line. I cut a slot for the line between taking the two videos.
Receiver, switch, plug, and servo wire. AR600 receiver. Way overkill but all I have at the moment.
Opened
Continuous-rotation servo from Micro Center. It was in their Arduino/robotics section. Also the drum. It is scrap Gator Board ($60 per 4x8' sheet). It's a very light foam with paper backing. I recessed the servo horn and supports to keep the box as thin as possible.
DuBro foam guide wheel
DakarNick screwed with this post 09-09-2012 at 03:05 PM
Old 09-01-2012, 11:08 AM   #1421
Saget
Saget's Avatar
Oddometer: 480
Awesome!!
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
Old 09-03-2012, 09:55 AM   #1422
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,239
Finished an airplane this morning. I feel so accomplished. ow to tear it all apart again and swap out the servos.
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Old 09-03-2012, 12:05 PM   #1423
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,833
Nice Yak!
I just put vectored thrust on my Crack Yak. I'll maiden it this afternoon.
VIDEO0023.mp4
DakarNick screwed with this post 09-03-2012 at 12:40 PM
Old 09-07-2012, 09:55 AM   #1424
Saget
Saget's Avatar
Oddometer: 480
Started with some 1/8" ply and some 1" square, .05 wall aluminum tubing.
3 hours with a drill press...
...looks like this
...and this.
All bolted together.
Flipped over, looking at the bottom. These bars will be the electrical bus for all the ESC's and battery connectors. One side positive, one negative.
Added another piece of ply to velcro the battery to.
Painted and reassembled. The white arm will be the front, orange is the back.
A $2 salad bowl from WalMart makes it look like a UFO.
750 kv motors and Turnigy 25 amp speed controls.
All the power leads from the ESC's wired in.
An Orange receiver and a KKV2 multi-rotor control board.
And yes, it flies!! I had to include retracts, just for fun.
And here's a quick video, now that I have it fairly well sorted out. The $2 salad bowl has been replaced by a slightly larger $4 salad bowl. It took quite a few flights to get the control board dialed in just right. There are menus with several settings for the gyro gain on each axis. Tweak, fly, tweak, fly, etc etc.
The main issue now is that with 6 motors turning, it burns through a 4000 mah battery pack in about 4 minutes. I have some different props on order to experiment with that should help. It's set up to run two batteries in parallel, which will also help, but that means carrying more weight.
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
Old 09-10-2012, 05:48 AM   #1425
FPGT72
Oddometer: 5,859
Very cool...it was for the longest time here just too hot to fly, now it is starting to cool off but was a little windy.
I do have a half built Tamiya sand scorcher on the kitchen table, but lack some paint to finish it off. Local hobby store ticked me off, so a tower order is in my future for some paint.
I need to get these two guys in the air....only thing I have flown lately...about a month ago is the Radion....the sail plane is fun, but I need to learn to take a lawn chair out with me....I get tired of standing.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant'
is like calling a drug dealer an 'unlicensed pharmacist
[/FONT]
FPGT72 is online now   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:01 AM.
