Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 10-02-2012, 04:24 AM   #16726
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
Originally Posted by ttpete View Post
Hydraulics don't necessarily make it easier. One of the first things most new Ducati owners do is to change the slave cylinder to make the clutch pull lighter. All a hydraulic setup does is eliminate cable problems. The force/travel tradeoff remains the same because your hand still provides all of the power to operate the clutch.
Maybe you should review hydraulics 101 again
Why do they change the slave cylinder? to make the clutch pull lighter
Clue:
It has to do with the applied force and the surface area ratio of the two pistons
Sent from my dRoiD3 with the help of 44 cyber-enhanced dwarves
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak screwed with this post 10-02-2012 at 04:31 AM
xtphreak is offline   Reply With Quote
Old 10-02-2012, 04:39 AM   #16727
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,108
Originally Posted by txwanderer View Post
Well, you have half the story right. most don't understand "why" it should be that way. However there is a reason, actually a couple of them.
First and not most important, if you use your first two fingers you could run into interference by hitting the two on the grip. Causing an incomplete clutch throw, or worse on the brake handle and lose some of the braking ability.
.....or you just adjust your levers properly. I've ridden two+two on the levers (both of them) since my hand was big enough to wrap around the grip and the lever without clamping any "extra" fingers.
Second and more important, is body mechanics. This is what is difficult to explain, but easy to demonstrate. The ring and pinky fingers are built for strength and stability, and it doesn't stop at the grip The pointer and middle finger are used for more complex actions such as writing, and have much smaller muscle and tendon structure for the complexity of movement. It is also much easier to demonstrate the body's stability in person, but your body is much more stable when clenching the ring and pinky into a fist. Short story, it is all about balance and strength.
I agree there may not be a "right or wrong" way but there are better and not so much better ways.
I'd say it is whatever you are comfortable with. I started riding that way because it removed the temptation (and ability) to do a full four finger clamp on the front brake. That was over 20 years ago, my throttle and brake control goes all to hell if I try to four finger the brake lever, on the clutch it putzs with my timing for a couple gears. ...and I tend to ride bikes that the brakes will toss you ass over tea-kettle before you really have a change to correct them.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 10-02-2012, 05:18 AM   #16728
jalapenopete
jalapenopete's Avatar
Oddometer: 35
gee-zus
What a bloviating pack of wankers we have here.
jalapenopete is offline   Reply With Quote
Old 10-02-2012, 05:34 AM   #16729
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,820
I don't see a pic in this post either...
So here's one:
boot fail
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 10-02-2012, 05:36 AM   #16730
greasyboy
cur·mudg·eon
greasyboy's Avatar
Oddometer: 1,767
Dent in the pipe
Unacceptable
greasyboy is offline   Reply With Quote
Old 10-02-2012, 05:46 AM   #16731
HooliKen
Awesome is a flavor
HooliKen's Avatar
Oddometer: 3,018
So here's one:
boot fail
M
2. Visor Fail!
3. Wrong side of the road FAIL! Unless of course this is the New Dragon with British driving Rules!
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is offline   Reply With Quote
Old 10-02-2012, 06:15 AM   #16732
cliffy109
cliffy109's Avatar
Oddometer: 1,772
Originally Posted by RDTCU View Post
This crash had nothing to do with over-braking. See the trolley tracks? His front tire wedged in it at the moment he hit the brakes. Flipping over the bars of an S1000RR is flat out impossible without something external grabbing the tire. It has proportional braking linked to the rear plus race ABS.
cliffy109 is offline   Reply With Quote
Old 10-02-2012, 06:22 AM   #16733
thetable
thetable's Avatar
Oddometer: 1,480
Yeah, because it's impossible to disable the ABS, and the ABS was never an option on the s1000rr...
thetable is offline   Reply With Quote
Old 10-02-2012, 06:34 AM   #16734
txwanderer
txwanderer's Avatar
Oddometer: 516
Sorry, but just because you can't do it doesn't make it wrong. If your control goes away, take your own advice and adjust your levers properly.
Shame on you for being a 20 year rider and never learning to truly master your machine. If you got a motorcycle to look cool, imagine what learning to ride it can do for you.
txwanderer is offline   Reply With Quote
Old 10-02-2012, 06:37 AM   #16735
k1w1t1m
Kiwi
Oddometer: 920
Have another look.
It's all for Jesus, CMA Faith Riders, Chapter 732
'01 BMW R1150GS
k1w1t1m is offline   Reply With Quote
Old 10-02-2012, 06:38 AM   #16736
hushpuppy
hushpuppy's Avatar
Oddometer: 158
Nah, take another look. Yellow lines to the left and white on the right.
hushpuppy is offline   Reply With Quote
Old 10-02-2012, 06:44 AM   #16737
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,530
And now Killboy's added a KneeDown with... sparkles.
http://www.facebook.com/media/set/?s...0253139&type=3
'73 R60/5 Toaster
Old 10-02-2012, 06:53 AM   #16738
Bill Harris
Oddometer: 8,530
Originally Posted by greasyboy View Post
Dent in the pipe...
...means she's a user and not a loser.
'73 R60/5 Toaster
Old 10-02-2012, 07:32 AM   #16739
Gummee!
Gummee!'s Avatar
Oddometer: 28,820
I looked at that. He's hanging his head over the DY but the bike's on this side.
He's also sorta crossed up in his cornering technique, but I let that slide.
M
Old 10-02-2012, 07:35 AM   #16740
2handedSpey
bunned
Oddometer: 237
I must be the only KLr rider because a pinky, or just two fingers isn't going to do squat.
It's heavy and has "sluggish" braking. There is no way a pinky or two fingers is going to slow the pig down.
Ps... As mentioned above, the riders front tire gets wedged in the rail tracks above. There's no way a front brake could lockup that clearly, on a dime. If it were a front brake "over tug" the front would have skidded, washed out and rider high sides.
In the video, the rider is inbetween the tracks, an idiot pedestrian runs out, rider barely sees pedestrian, rider distracted, bike dips into track groove, bike stops on a dime, no skidding, no rubber smoke. Just abrupt stop. Wheel locked in the track rail. Pedestrian flees. Don't see him coming back. What country is this filmed in? I couldn't tell by the license plates.
What's shocking is how slowly all the bystanders move. Gawking and reluctant to do anything.....
2handedSpey screwed with this post 10-02-2012 at 07:41 AM
2handedSpey is offline   Reply With Quote
Times are GMT -7.   It's 01:42 AM.
