10-01-2012, 06:59 PM
#16741 | |
Oddometer: 345
Well, you have half the story right. most don't understand "why" it should be that way. However there is a reason, actually a couple of them. First and not most important, if you use your first two fingers you could run into interference by hitting the two on the grip. Causing an incomplete clutch throw, or worse on the brake handle and lose some of the braking ability. Second and more important, is body mechanics. This is what is difficult to explain, but easy to demonstrate. The ring and pinky fingers are built for strength and stability, and it doesn't stop at the grip The pointer and middle finger are used for more complex actions such as writing, and have much smaller muscle and tendon structure for the complexity of movement. It is also much easier to demonstrate the body's stability in person, but your body is much more stable when clenching the ring and pinky into a fist. Short story, it is all about balance and strength. I agree there may not be a "right or wrong" way but there are better and not so much better ways. Cheers |
10-01-2012, 07:11 PM
#16742 |
Oddometer: 825
My solution...
And I milled some serrations on the front for a bit more grip. A lot easier to bang down a couple gears or clutch the front up without losing grip on the bars ...
10-01-2012, 08:27 PM
#16743 |
Oddometer: 3,686
10-01-2012, 08:32 PM
#16744 |
Oddometer: 3,686
10-01-2012, 08:46 PM
#16745 | |
Ground feeder
Location: Not too far from Sugarloaf or Mount Katahdin, ME
Oddometer: 2,467
![]() lg
09 F650GS twin 07 KLX250S Will Ride for Beer Modern Quilt Designs - Unique Quilts For Modern People Sold Here |
10-01-2012, 08:52 PM
#16746 | |
Oddometer: 3,686
10-01-2012, 09:02 PM
#16747 |
Oddometer: 825
10-01-2012, 09:03 PM
#16748 |
irregular
Oddometer: 8,792
Or keep saying it but get ABS.
DL650A, M696A Alaska 2006 | South America 2007 | USA coast-to-coast 2008 | 2009, what happened? 2011, We lost fellow PNW adventure rider Ken Morton (DreadPirateKermit) |
10-02-2012, 12:06 AM
#16749 |
Crusty Demon
Oddometer: 338
Ah yes this is the funeral I was after. I love it when they think that four fingers means "white knuckles". These people discredited themselves with their circular arguments and "grabbing" comments and .. oh.. oh... my favourite... "when I used to race" .....
Most of the questions people put forward here are about "best techniques" that put you at "lowest risk" on the public road. Then some clown comes in and says "forget survive the ride" let's go for a podium finish. Wrong tool for the job.. but then again what would you expect from a "tool". "Best Practice" requires a definition of what you require for the benchmark.... On the public road perhaps I might be so bold to suggest that "Arrive Alive" might be a reasonable starting point. This then might lead me to the conclusion that ALL braking be done in a straight line, that ALL gear changing be done in a straight line and finally set your entry speed as constant through the whole corner... start out wide for vision, buffer from the "head on zone" and aim to finish tight. At all times buffer from any oncoming vehicles even if this means reducing your entry speed. Of course this approach would mean that you would run "stone cold motherless last" in a competitive racing situation. Go for the "podium finish" on the "public road" and it may be a "stainless steel autopsy table" is the prize that you get. You'll be "stone cold" ![]() ![]() ![]()
10-02-2012, 04:24 AM
#16750 | |
from B4 "adventure bikes"
Oddometer: 7,649
![]() Maybe you should review hydraulics 101 again Why do they change the slave cylinder? to make the clutch pull lighter Clue: It has to do with the applied force and the surface area ratio of the two pistons Sent from my dRoiD3 with the help of 44 cyber-enhanced dwarves
Do one thing every day that scares you. Baz Luhrmann Women and cats will do as they please, and men and dogs should relax and get used to the idea. Robert A. Heinlen Adventure is discomfort recounted at leisure. Flash / GSWayne Chrome don't get ya home. Rob Nye Stamp Out Hoplophobia in Our lifetimes. 1999 Tiger 885 1995 XT600E
xtphreak screwed with this post 10-02-2012 at 04:31 AM |
10-02-2012, 04:39 AM
#16751 | ||
Oddometer: 4,780
I'd say it is whatever you are comfortable with. I started riding that way because it removed the temptation (and ability) to do a full four finger clamp on the front brake. That was over 20 years ago, my throttle and brake control goes all to hell if I try to four finger the brake lever, on the clutch it putzs with my timing for a couple gears. ...and I tend to ride bikes that the brakes will toss you ass over tea-kettle before you really have a change to correct them. |
10-02-2012, 05:18 AM
#16752 |
Oddometer: 30
gee-zus
What a bloviating pack of wankers we have here.
10-02-2012, 05:34 AM
#16753 |
That's MR. Toothless
Oddometer: 25,661
I don't see a pic in this post either...
So here's one: ![]() boot fail M
There. I've moved back to VA. Can you PLEASE change the weather?! |
10-02-2012, 05:36 AM
#16754 |
Tattooed White Trash
Oddometer: 1,656
Dent in the pipe
Unacceptable |
10-02-2012, 05:46 AM
#16755 | |
One finger braker!
Oddometer: 2,095
3. Wrong side of the road FAIL! Unless of course this is the New Dragon with British driving Rules!
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell If Momma ain't happy ain't NOBODY happy! 2007 950R Super Enduro 2006 Buell XB12X |
