Old 10-03-2012, 03:14 PM   #16831
tedder
irregular
tedder's Avatar
Oddometer: 8,792
Originally Posted by crofrog View Post
Try finding a pad with a higher initial torque, increasing your rotor diameter or look at changing to a master cylinder with a different bore size.
We have a large supply of bores here.
tedder is offline   Reply With Quote
Old 10-03-2012, 03:43 PM   #16832
dwoodward
dwoodward's Avatar
Oddometer: 3,666
New pads is easy.
Larger rotors? Well, now we're making adapter brackets for the calipers, but OK.
Larger bore master cylinder will get you less lever travel (so you don't have to pinch your fingers) at the expense of power (force multiplication)l- so you have to use all your fingers to get maximum braking.
Smaller bore master cylinder gives you more power at the expense of pinching any fingers left on the bar.
What was the goal again?
dwoodward is offline   Reply With Quote
Old 10-03-2012, 04:00 PM   #16833
Contevita
Cigar Adventurer
Contevita's Avatar
Oddometer: 1,096
Contevita is offline   Reply With Quote
Old 10-03-2012, 04:16 PM   #16834
ttpete
Rectum Non Bustibus
Oddometer: 3,509
All that and more. The cheaper bikes usually came with single pot calipers. I upgraded the KLR with a 300 mm rotor, four pot caliper, and new master cylinder. I refuse to own a bike with inferior brakes. Except for the Triumph, which is a correctly restored vintage machine, and it is ridden at events only.
09 Kaw Versys
"The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher
Old 10-03-2012, 04:37 PM   #16835
GSequoia
Where are my tools?
GSequoia's Avatar
Oddometer: 857
That's rather personal, don't you think?
2005 KLR 650 A bit beat up but works just fine. Powered by really angry canaries.
1985 Suzuki GS700E Some assembly required
1977 Cimatti City Bike. What, you call that a build thread? Officially stalled...
GSequoia is offline   Reply With Quote
Old 10-03-2012, 05:04 PM   #16836
LittleRedToyota
Yinzer
Oddometer: 1,202
I'm baffled why people are obsessed with finding the minimum number of fingers necessary on their bike.
it's not about finding the minimum necessary.
using 1 or 2 fingers allows you to maintain better control over the handle bars and throttle at the same time you are braking. you can use all 3 controls (plus the clutch on the other side) with fine input at the same time.
also, covering the brake with all the fingers you use to apply it allows you to apply it more quickly (as the fingers are already in place instead of having to reach for the lever). and covering the front brake level with 4 fingers all the time would sacrifice bar and throttle control.
LittleRedToyota is offline   Reply With Quote
Old 10-03-2012, 05:35 PM   #16837
dbuzz
Citizen of the world
dbuzz's Avatar
Oddometer: 1,096
Because that is what all the 'cool' riders do because they saw someone they thought was 'cool' doing it. Then they have to justify it ... hence the hair splitting and finger counting. It's kind of like how one peice leathers automatically mean you are a great rider
Monkey see, monkey do.
dbuzz is offline   Reply With Quote
Old 10-03-2012, 05:37 PM   #16838
ray h
Oddometer: 229
Originally Posted by Kingsized View Post
I'm not really a high beam guy so that is odd. I wonder (and I totally understand what you are seeing), if it's some type of reflection bouncing back from my plastic guard? As bright as the low beam is, you'd think the high beam fixture would be fully filled with light. Either that or I just screwed up and hit my high beams.
No problem, I'm just messing with you.
I took all kinds of guff from a couple of inmates for riding with my highbeam on so I'm just spreading it around.
ray h is offline   Reply With Quote
Old 10-03-2012, 06:36 PM   #16839
Kingsized
Kingsized's Avatar
Oddometer: 474
It's all good. I never got my farkles in a tuff, ha!
Kingsized is offline   Reply With Quote
Old 10-03-2012, 06:52 PM   #16840
crofrog
Oddometer: 1,376
Not to mention the first time your braking and the front starts to tuck with all four fingers on the brake is going to be awesome, as you try to reduce pressure on the brakes while pushing the bars back straight and and scaring the shit out of yourself...
crofrog is offline   Reply With Quote
Old 10-03-2012, 06:54 PM   #16841
Barry
Just Beastly
Barry's Avatar
Oddometer: 6,478
Give some people credit for espousing the method that works best for them, vice drinking the coolaid and parroting what others do. I am a 1 or 2 finger braker, and a 2 finger clutch person... dirt or pavement. That works for me, it works better than 4 fingers. If 4 fingers worked better, I would espouse that as the method that works for me. Please don't paint with so broad a brush.
Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday.
Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot.
Barry is offline   Reply With Quote
Old 10-04-2012, 05:59 AM   #16842
Orygunner
Orygunner's Avatar
Oddometer: 78
If a new rider is braking, why do they need to use the throttle? As an experienced rider, I sometimes brake with two fingers and blip the throttle when downshifting to match engine RPM to road speed, but that's the only time that the throttle isn't rolled completely off when using the front brake.
Remember, this conversation started because someone that took the MSF basic rider course was told to use all fingers on their brake and they wanted to know why. It's simply because not covering the brake on the range, and using all four fingers when braking is the best practice for new riders, both for proper consistent technique and safety, for all.
If you (or anyone else) as an experienced rider, based on your experience and frequent practice with stopping quickly on your bike find that you can do so as safely and quickly with 2 fingers as you can with 4, that your other fingers don't get pinched or limit your brake application, then do it that way.
I haven't seen any riders, even new ones, sacrifice bar & throttle control from using all four fingers on their brake (or covering the clutch at all times), on the range or the street. What little off road riding I've seen I can CERTAINLY see the reason on rough terrain, but we're talking smooth pavement here where the bike's not bucking & bouncing.
...Orygunner...
2005 Kawasaki Vulcan 2000 Limited
1998 Honda Nighthawk 750
Originally Posted by markk53 View Post
Actually I'm not sure the Vulcan qualifies as a bike... two wheeled tank, maybe....With the 2000's clearance I'm not sure the Vulcan could make it around the tightest curves on a track without having to stop and back up...
Orygunner is offline   Reply With Quote
Old 10-04-2012, 06:06 AM   #16843
Orygunner
Orygunner's Avatar
Oddometer: 78
Are you talking about locking and skidding the front wheel? That's the only reason the bars are going to turn anywhere but in the direction of travel.
The proper technique when that happens is to quickly RELEASE the front brake and smoothly reapply. You can't "push the bars back straight" to maintain balance while the front wheel is skidding, simply releasing the brake will straighten the bars no matter what else you try and do.
I've seen some pretty gnarly front wheel skids on the range, and releasing immediately is the only solution. Every single person that released the front brake (before the bike was down, of course) regained control of the bike, even when they had been using all four fingers on the brake.
...Orygunner...
Old 10-04-2012, 06:24 AM   #16844
hooliken
One finger braker!
hooliken's Avatar
Oddometer: 2,089
Originally Posted by Orygunner View Post
I personally use all fingers for most braking, but sometimes just use two depending on what I'm doing (slow speed manuvers or blipping the throttle while braking & downshifting). Sometimes I even just use one brake or the other.
...Orygunner...
Originally Posted by LuciferMutt View Post
Sweet Jebus. Are you better at braking with four fingers or two? It matters more what the rider is good at and comfortable with than how many fucking fingers they use!
There are a shit ton of motorcycles out there, that even with factory spec/service brakes, you still need four fingers on the lever to get maximum braking from.
Right. New riders, so teaching a preferred technique that works on all bikes is better than teaching advanced skills.
Generally speaking it's much easier to "feel" the brakes with four fingers, even if it only takes one. I'm baffled why people are obsessed with finding the minimum number of fingers necessary on their bike.
Wear r d pikchures?
Victory! Victory!
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
If Momma ain't happy ain't NOBODY happy!
2007 950R Super Enduro
2006 Buell XB12X
hooliken is offline   Reply With Quote
Old 10-04-2012, 06:34 AM   #16845
Flying-D
Just Passing Through
Flying-D's Avatar
Oddometer: 1,610
Originally Posted by hooliken View Post
I have no opinion on his braking technique, and he seems competent enough, but IMO that is still the fugliest motorcycle ever made.
It's really all just stuff...and in the end, none of it means shit.
Flying-D is online now   Reply With Quote
Times are GMT -7.   It's 06:16 AM.
