Old 10-26-2012, 10:33 AM   #17641
lefty80883
lefty80883's Avatar
Oddometer: 17
Originally Posted by Mr_Gone View Post
Halloween comes early.
Lack of front rotor is scarier than his lid. Nice gloves though.
lefty80883 is offline   Reply With Quote
Old 10-26-2012, 10:36 AM   #17642
RDTCU
Oddometer: 2,279
I think he cares more about looking good than stopping fast... Maybe he came off a Harley, one tiny front rotor is enough for anyone, right? Besides, if you breath on the front brake to hard, you'll flip over the bars...
RDTCU is offline   Reply With Quote
Old 10-26-2012, 10:39 AM   #17643
DiabloADV
Semi-Occasional
Oddometer: 2,277
Originally Posted by cliffy109 View Post
Fail! What is the point of hanging your butt off the bike if you're going to crawl your torso back to the center of the bike? If you want to hang off, hang off!
What's the point of hanging off if the hard parts are still 8" above the pavement? Nothing gained.
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is online now   Reply With Quote
Old 10-26-2012, 10:47 AM   #17644
RDTCU
Oddometer: 2,279
Until that corner tightens up or something jumps out in front of you. You respond a lot quicker if you're already in position.
Old 10-26-2012, 11:21 AM   #17645
daveinva
Oddometer: 553
Originally Posted by klaviator View Post
Ahhh, the Chinese disposable scooter. The answer to the question few have asked, and even fewer have answered.
daveinva is offline   Reply With Quote
Old 10-26-2012, 11:32 AM   #17646
klaviator
klaviator's Avatar
Oddometer: 6,265
Most of the Hayabusa's I have seen on twisty roads have been going so slow they barely need brakes.
I ride, Therefore I Am.
klaviator is offline   Reply With Quote
Old 10-26-2012, 11:32 AM   #17647
andy29847
Dirt Road Rider
andy29847's Avatar
Oddometer: 2,298
Car Tire
This guys contact patch is way to small on the rear. He needs to ditch that car tire.
Andy Simons
ABC#8350
IBA#7647,
Trenton, SC
Smugmug coupon code = bQItjZEfrqLkI
MOAB Ride Report
andy29847 is offline   Reply With Quote
Old 10-26-2012, 11:46 AM   #17648
#46
#46's Avatar
Oddometer: 151
Originally Posted by UnsureFooting View Post
And that torque curve you showed me isn't all that flat. There's a 40 ft-lb difference between those lines. The graphic is being squashed by the scaling.
Look again. The minimum is 58 and peaks at 72! Difference of 14.
#46 is offline   Reply With Quote
Old 10-26-2012, 11:47 AM   #17649
RDTCU
Oddometer: 2,279
I found half a set of orange 'Busa bodywork in the ditch on the way up 276 near Ceasar's Head a month or so ago
Old 10-26-2012, 11:58 AM   #17650
Aussijussi
Oddometer: 1,138
Originally Posted by el queso View Post
...yet he seems to be going around a corner...
Just.
Aussijussi is offline   Reply With Quote
Old 10-26-2012, 11:59 AM   #17651
GSequoia
Where are my tools?
GSequoia's Avatar
Oddometer: 1,150
Originally Posted by kioti View Post
This guy took a bad line and breathed a little to hard on the brake lever.
http://www.youtube.com/embed/nT-iQ_X1_Ow
He must have sneezed on the brake lever.
2005 KLR 650 A bit beat up but works just fine. Powered by really angry canaries. - Actually it's a bit dead right now.
1990 DR350S Smaller. Lighter. Slower.
1985 Suzuki GS700E Some assembly required
1977 Cimatti City Bike. What, you call that a build thread? Officially stalled...
GSequoia is online now   Reply With Quote
Old 10-26-2012, 12:53 PM   #17652
dwoodward
dwoodward's Avatar
Oddometer: 5,496
"Bad line" doesn't begin to describe it- what the hell was he doin' over there?
You kidding? I'd LOVE to get my hands on one of those... pref. with a blown motor. I have evil plans...
dwoodward is offline   Reply With Quote
Old 10-26-2012, 12:53 PM   #17653
UnsureFooting
Title of User Here
UnsureFooting's Avatar
Oddometer: 6,235
The lines on the graph.
Because so much is riding on your tires.
UnsureFooting is online now   Reply With Quote
Old 10-26-2012, 01:23 PM   #17654
PT Rider
Oddometer: 692
Originally Posted by StoneAgeMan View Post
Did you know that a big cruise ship engine typically operates around 10 or 15 RPM and has less than 60 rpm at full speed? It's actually much more about piston speed, typically measured in feet-per-second, long stroke travels farther per RPM. Like a long crowbar vs. a short crowbar.
StoneAge Man
Nah. A large container ship engine, over 100,000 hp these days from an in-line 14 cylinder two stroke diesel, has a top speed of about 100 rpm and low speed of about 35 rpm. 960 mm bore x 2500 mm stroke, piston speed of 8.5 meters/second, burning very heavy black fuel oil (centrifuged and heated to 250F). These are directly connected to the prop and the engine is reversible. The engine designed for a very deep draft oil tanker or bulk carrier with a very large diameter prop (more efficient) may have a top speed of about 70 rpm. A cruise ship is more likely to have several medium speed engines, maybe straight 8, four stroke, up to 640 mm bore x 900 mm stroke, 23,000 hp, 300 rpm, piston speed of 10 m/sec. These will either be geared and clutched to a prop or run through a generator with an electric propulsion motor driving the prop. The medium speed engines with more cylinders in the total layout have more maintenance, but they're more compact so the ship has more staterooms to sell.
http://www.wartsila.com/en/engines/m...nes/wartsila64
http://www.wartsila.com/en/engines/low-speed-engines
I've run engines up to a twelve cylinder that put out 57,500 hp, the biggest in it's day, plus three 2700 hp straight-8 generator engines.
It's not what you look at that matters, it's what you see.
Henry David Thoreau
PT Rider is offline   Reply With Quote
Old 10-26-2012, 01:39 PM   #17655
PT Rider
Oddometer: 692
Originally Posted by Jim Moore View Post
Power = torque x rpm
Horsepower = torque x rpm / 5252.
Only for Harleys, Victorys, and Indians.
For metric bikes
Horsepower = torque (in newton-meters) x rpm / 7121
Henry David Thoreau
Times are GMT -7.   It's 05:28 PM.
