Old 10-26-2012, 07:32 PM   #17671
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 4,441
Originally Posted by PFFOG View Post
Have you not seen some of the barges that were pictured here, and the pirates?????
X the DY.
TrashCan is offline   Reply With Quote
Old 10-26-2012, 07:52 PM   #17672
mrphotoman
mrphotoman's Avatar
Oddometer: 1,063
Originally Posted by UnsureFooting View Post
They have a place. Not everybody wants zip around at 6k rpm.
6k? that is barely idling for a bike.
mrphotoman is offline   Reply With Quote
Old 10-26-2012, 07:55 PM   #17673
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,456
Originally Posted by Mr_Gone View Post
27.3 miles per hour.
--Bill
'73 R60/5 Toaster
Old 10-26-2012, 07:58 PM   #17674
UnsureFooting
UnsureFooting's Avatar
Oddometer: 5,689
For SOME bikes. The pitch and character of the bike are not what I enjoy.
UnsureFooting is offline   Reply With Quote
Old 10-26-2012, 08:17 PM   #17675
ttpete
Rectum Non Bustibus
Oddometer: 5,751
The Ducati Diavel is what H-D SHOULD have designed. They got rid of Buell because he was more intelligent than all of the H-D engineers put together.
15 BMW RnineT
09 Kaw Versys
ttpete is online now   Reply With Quote
Old 10-26-2012, 08:20 PM   #17676
MattB
Oddometer: 30
I looked em up, like you asked. They're flat for sport bikes, but not nearly as flat as a sportster or a vstar 1100.
That's not the torque curve of the Sportster that you are looking at, that's the life monitor and the bike has flat lined. It's dead boring.
If you think loud pipes save lives, imagine what learning to ride might do!
2000 Honda VFR :: 2002 BMW K1200RS :: 2008 Suzuki GSXR (Track) :: Honda CRF 70 (daughter) :: Honda CRF 80 (son) :: Honda CRF 150 (dad)
MattB is offline   Reply With Quote
Old 10-26-2012, 08:39 PM   #17677
UnsureFooting
Oddometer: 5,689
Which is why hd is still growing sales quarter after quarter. Derp! Leave the marketing and engineering decisions to people who know what the fuck they're doing.
Do you have thoughts? Or is your whole life as dumb-fuck stupid as that quip?
Old 10-26-2012, 08:45 PM   #17678
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
Originally Posted by SilkMoneyLove View Post
I haven't ridden all of MN, but lots of MN riders come to WI to ride good roads. MN sucks donkey balls for decent roads with curves and elevation change from what I can find.
CA, NC, TN, WV, VA, WA, OR, MD, PA and WI all eat MN for roads.
I loved riding around the driftless region in WI. It was full of surprises, as were some of the Rustic Roads.
Lived in MN for over 50 years and rode all over the state many times and always had flat spots on my tires.
Live in CO now - no comparison.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 10-26-2012, 08:52 PM   #17679
PT Rider
Oddometer: 685
Originally Posted by Montague View Post
wonder how the martime oil thread will turn out?
you asked for it.....
The main engine has oil injected through ports in the cylinder walls to lubricate the piston skirts and the cylinder liners. This consumes about a ton of oil per day, SAE 50 or 60, 70 TBN. The crankcase has about 30 tons of 30 wt in its dry sump, and this oil is a lifetime fill. The crankcase is sealed separate from the combustion spaces on these cross head engines. The piston rod is bolted rigid to the piston. The piston rod passes through a seal and is bolted to the crosshead which does the job of a wrist pin...transferring the angular thrust of the crank to the engine frame. The connecting rod is bolted to the crosshead and goes to the crankshaft.
The trunk piston engines (conventional wrist pin in the piston) use an SAE 40 oil with a high TBN to counteract the acid from the fuel with 3% sulfur. The oil is continuously centrifuged and only changed when indicated by the oil analysis...years of service.
No, no synthetics.
TBN = total base neutralizing, a measure of the alkalinity of the oil. Highway Diesel engines oils are about TBN 10 or 12.
A big Diesel engine is one where you put a man with a ladder in the cylinder, and a crew of men with chain hoists, ladders, and planks into the crankcase. A chain hoist is needed to lift a bearing insert. Figure that the engine weighs something like 1800 to 2000 tons. 7 ton individual cylinder head.
It's not what you look at that matters, it's what you see.
Henry David Thoreau
PT Rider screwed with this post 10-26-2012 at 08:59 PM
PT Rider is offline   Reply With Quote
Old 10-26-2012, 09:05 PM   #17680
Bill Harris
Oddometer: 7,456
Dang. That is H U G E .
--Bill
'73 R60/5 Toaster
Old 10-26-2012, 09:20 PM   #17681
ttpete
Rectum Non Bustibus
Oddometer: 5,751
Of course they know what they're doing. They're building overweight underpowered barges to stroke the egos of all the Sonny Barger wannabes who don their Harley Pirate Costumes on sunny days and cruise at 15 under the speed limit showing off how bad and macho they are. Performance isn't critical as long as they can set off the alarms of the parked vehicles they pass.
I have fun making them look silly with my little 400 pound 650 twin.
15 BMW RnineT
09 Kaw Versys
Old 10-26-2012, 09:25 PM   #17682
UnsureFooting
Oddometer: 5,689
They're making money, and apparently enough not to need yours.
You think they look silly, they think you look silly. Why the hate? Did a pirate steal your girlfriend in high school or something?
Old 10-26-2012, 09:36 PM   #17683
DAKEZ
DAKEZ's Avatar
Oddometer: 19,702
You truly are an ignorant fuck
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 10-26-2012, 09:56 PM   #17684
Tip Over
Whoopsie!
Tip Over's Avatar
Oddometer: 1,025
Originally Posted by ZONKR View Post
All chaps are assless or they would be pants.
Not quite.
They would be crotchless pants.
Tip Over is offline   Reply With Quote
Old 10-26-2012, 10:22 PM   #17685
folknride
Old Adventurer
folknride's Avatar
Oddometer: 667
blah, blah and freaking blah
Where to start?
(more pics - less "enlightenment")
This might get you going
folknride is offline   Reply With Quote
Times are GMT -7.   It's 02:42 PM.
