Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 05-27-2012, 05:31 AM   #11446
haystack
Just ride
haystack's Avatar
Oddometer: 4,466
Originally Posted by B.Curvin View Post
Low budget suicide bomber!
Indeed, This is a gentleman's game....
German W.O.D. Certified
2014 Winner of the Biggest Potato in Jersey
haystack is offline   Reply With Quote
Old 05-27-2012, 07:09 AM   #11447
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,833
Originally Posted by TrashCan View Post
You just never know what you will see (Dragon Slayer)?
Let's hear it for Explosive Ordinance Disposal personnel!
M
(Dad was Master EOD)
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 05-27-2012, 07:25 AM   #11448
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
That's is NOT a KLR.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 05-27-2012, 10:35 AM   #11449
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,431
Jerry can too much $$, recycled milk jug would have been used.
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is offline   Reply With Quote
Old 05-27-2012, 12:23 PM   #11450
whitham_wannabe
whitham_wannabe's Avatar
Oddometer: 1,102
Sliding in racing isn't showboating by any means.
On any given turn you have two things to do that determine how fast you can travel around the corner - get from the start of the turn to the end, and get the bike rotated from the starting angle to the ending angle. Depending on the configuration of the turn, the latter may be the rate determination, in which case sliding on the way in or the way out makes you quicker.
I'm no Casey Stoner, but used to race regional CCS / WERA and AMA Pro Thunder, and it was a technique we used all the time, Bang too many downshifts into the slipper clutch under braking, push the back end out, stick it in the middle then roll off the edge of the tyre and light it up coming out.
Did the same racing cars, though my Spec Miata didn't quite have the power for the big exit.
From a WW1 RAF Flight Manual ...
"If a crash at the home airfield is inevitable, try to hit something soft and, preferably, inexpensive"
Travels With Bruce : More Travels With Bruce
whitham_wannabe is offline   Reply With Quote
Old 05-27-2012, 05:47 PM   #11451
viverrid
not dead yet
Oddometer: 30,482
Originally Posted by shaddix View Post
The concept is that the rear tire can handle more weight in the cornering load than the front due to the wider contact patch....
That's pretty much irrelevant to what we are talking about. As weight comes off the tire, contact patch gets smaller. The relative length & width of a contact patch of any particular size does have technical ramifications but that's not what is relevant here.
Noobs in either cars or bikes are told to brake in a straight line and then turn in because it is easier for them to handle one thing at a time. But if you don't get all the braking done before the corner, you can carry more speed farther in. If you are doing all your braking before the corner, I will pass you while you are braking because I start braking later and then brake deeper into the corner. To trail brake you "just" have to complete some of your braking while you are already turning, which is more difficult to maintain control doing, but is faster.
The concept is g-force or friction circle. Using accelerometers you can graph the g-forces on the bike under braking, acceleration, or cornering. If you brake first you get a spike toward the front from the heavy decel. Then the data point comes back toward center and then it goes to the side from cornering force. The idea is that to maximize use of the available traction, you seek a more "round" graph.
Yes the graph plot is forward under decel, but rather than stopping decel and THEN starting to turn, you transition into turning as you ease off the braking. The plot swings from heavy braking and no turning, to moderate braking and slight turning, to moderate turning and slight braking, into no braking and all turning. Like powering out in mirror image.
You don't wait to finish turning before you start accelerating. But (without traction control) you don't necessarily crank max throttle in while you are still leaned waaaaay over. Same concept on the other end with trail braking.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 05-27-2012, 06:23 PM   #11452
shaddix
Oddometer: 647
Well this all makes sense, I just don't understand why twist of the wrist II disagrees with it. Is that book really for "noobs"? It makes sense that if you still have some longitudinal acceleration either forward or back you should use it of course to maximize your speed, so logically what you're saying makes sense and what I always thought as well, but it seemed like TOTW2 disagreed with that, maybe it doesn't.
shaddix is offline   Reply With Quote
Old 05-27-2012, 09:59 PM   #11453
ironslede68
ironslede68's Avatar
Oddometer: 463
Originally Posted by Ritalin Boy View Post
True.
If it was a Hog it would be a wrecker instead of a trooper.
Either way both are rolling roadblocks.
depends on who's in the saddle most days too
ironslede68 is offline   Reply With Quote
Old 05-28-2012, 06:53 AM   #11454
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 4,776
X the DY.
TrashCan is offline   Reply With Quote
Old 05-28-2012, 07:04 AM   #11455
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,570
I think that the lead rider's helmet is about to blow off...
'73 R60/5 Toaster
Old 05-28-2012, 07:11 AM   #11456
bwalsh
bwalsh's Avatar
Oddometer: 12,314
KLR Akbar!!!
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 05-28-2012, 07:29 AM   #11457
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
That's the way the cool kids wear 'em YO!
Bib
Old 05-28-2012, 07:35 AM   #11458
mrprez
KJ4WMZ
Oddometer: 1,265
We were up there on the 19th and it was crowded and loud. An HD Rider decided he was going to announce his departure with lots of noise. Made sure everyone was looking his way as he rode off towards 28N with his beanie helmet riding on the sissy bar. He hit the first bump and while the helmet bounced down the road he roared off down the hill only to come slinking back a minute later to reclaim his lost brain bucket. Everyone was roaring with laughter. It was priceless.
mrprez is offline   Reply With Quote
Old 05-28-2012, 07:40 AM   #11459
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
Originally Posted by bwalsh View Post
KLR Akbar!!!
100mpg is offline   Reply With Quote
Old 05-28-2012, 07:41 AM   #11460
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 4,776
20 mph ain't gonna blow the heat off the motor , less alone a helmet.
X the DY.
Times are GMT -7.   It's 12:46 AM.
