Old 12-09-2010, 02:03 PM   #361
jdrocks
Gravel Runner
Oddometer: 4,583
Originally Posted by Pulasky View Post
... My way seems to be easyer then cuting, welding new frame and trying to fit engine. There is a stock base, made by factory so its solid and fit properly, angine and frame most important parts are done. I know that this kind of ptoject is not easy to build, but if we have got the base it will make all project much easier.
builds using the kawasaki ptwin frames have been done, or are ongoing. nothing new there. the KLR or KTM builds with the ptwin engine are a different kind of bike by intent.
i'm content with my ptwin gravel runners in the stock frame, they work for the type of trip i do, and they're very cheap to build. 10,000 km of gravel road on these bikes so far. i'm going to try to turnkey my next ptwin build for $1000 plus the cost of new tires. we'll see how it goes.
maybe i should join this circus and start another build thread.
(lucas, a PM headed your way)
jdrocks is offline   Reply With Quote
Old 12-09-2010, 02:54 PM   #362
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,636
Thumb
I would agree to that
I like reading your builds and the ride report after the build
johnwesley is offline   Reply With Quote
Old 12-09-2010, 03:30 PM   #363
Pulasky
Pulasky's Avatar
Oddometer: 245
Almost stock Versys. Suspention, wheels and exhoust only changed. Great bike for gravels and dirt roads. Kawasaki should make this kind of bike paraler with street Versys, like new Triumph Tiger 800
Pulasky is offline   Reply With Quote
Old 11-22-2011, 08:00 AM   #364
svestenik
armchair adventurer
Oddometer: 37
LukasM, why not try Kawa KLE500 engine instead of Kawa KLE650 engine ?
I admit, it is only 500cc displacement, but it is proven, venerable design, bulletproof. Six gears, and it can run well above 170 kph in stock form. Easy to find, cheap to run & own, and with GPZ500 camshafts and carbs they develop a nice punch.
Same configuration as Versys/ER's, almost the same design, since Kawa 650 engine is based on it, but it should be smaller in overall dimensions and would maybe fit easier ?
They are carbed though, no factory EFI. You would have to do some aftermarket EFI conversion.
If you need measurements and photos of the engine, I can supply you with it, since I have one left from previous bike.
svestenik is offline   Reply With Quote
Old 02-26-2012, 11:03 AM   #365
dtdynamics
Oddometer: 44
id be interested in them dimensions!
dtdynamics is offline   Reply With Quote
Old 02-26-2012, 11:30 AM   #366
tonymorr
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,543
I don't think the 500 engine is smaller. I think it may even be bigger. I had a 500 before my 650 and the power delivery was quite different. The 500 is really soft on the bottom whereas the 650 has some grunt right off of idle.
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 11-14-2012, 12:18 AM   #367
katumo_jtb
bogus journeyer
Oddometer: 461
Hey Lukas,
I hope you're still checking this. I have an LC4 rolling chassis with no engine. Looking at used engines, the BMW 650 single seems to be much more available than LC4's (so, cheaper), and with a good record for reliability. They also have a right-side chain drive, although the engine mounts are quite different.
Do you have any idea if the Rotax fits in the LC4 frame? I'm thinking of going that route if I can do it with just some custom mounts.
John
katumo_jtb is offline   Reply With Quote
Old 11-14-2012, 03:36 AM   #368
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 774
ktm rotax
Originally Posted by katumo_jtb View Post
Hey Lukas,
John
Should be interesting, 83 or 84 KTM 's and some years ATK s 600 had the Rotax 604 ? engine .
pennswoodsed is offline   Reply With Quote
Old 11-14-2012, 09:45 AM   #369
katumo_jtb
bogus journeyer
Oddometer: 461
That's a good point, the 604 should be a near bolt-in given how many parts the ATK shared with the KTM. The swingarm and rear frame area looks very similar. However those engines are not easy to find. There are about 10 F650 engines on ebay right now, and I've never seen a 604 being parted out. I'll keep an eye out though.
Old 11-14-2012, 10:19 AM   #370
LukasM OP
Oddometer: 5,427
Yeah, I'm still here.
The project is literally not off the table yet, sitting on one of the benches in my garage. Recently got a set of 690 Rally tanks for trial fitting, those would work a lot better so I sold the 4x 660 Rally tanks.
Right now one option I'm considering is to have a pro put the stem and rear part of the frame in a jig, and then make up some new trellis frame tubes to connect them. Basically make it look like a 690 frame except a bit wider in the middle. That might actually work...
The F650 engine is the second option I am considering, especially if I can manage to find a crashed Husky Terra. I do know that it's a big wide engine but I've never sized it up to see if it would fit in the frame. Since it's got a single throttle body I think it should fit in between the frame spines on top. Worst case you might have to redo the two bottom frame tubes, but that's not too hard.
Old 06-04-2013, 11:03 AM   #371
danketchpel
Oddometer: 2,631
This is not er but sv 650,
I would love to see more detailed photos of that bike. It looks to be very well done.
13 MG Stelvio NTX, 09 Duc Sport Classic, 02 Speed Triple
13 Husky Terra 650, 00 Suzi DRZ400-S
danketchpel is offline   Reply With Quote
Old 06-04-2013, 04:20 PM   #372
pennswoodsed
lizards,bugs and me
Oddometer: 774
what he said
I would give some ones left nut for build details on this bike.
Times are GMT -7.   It's 09:40 PM.
