06-09-2009, 10:31 PM
#31 |
What could go wrong?
Oddometer: 4,956
I am sure the cases could leak into the bottom of the combustion chamber and reek RPM havoc.
Have you gone to Kawasaki triples worldwide . com ? http://www.kawasakitriplesworldwide....pBB2/index.php
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
06-10-2009, 05:07 PM
#32 |
Oddometer: 9,781
Did you let the sealer set up before firing it up?
06-11-2009, 10:15 AM
#33 | |
XLR8
Oddometer: 30
The K3 site had links to photos etc. on the proper install. I've got sooo much on my plate right now pulling the motor again will have to wait. Hey...it starts with a couple kicks at least!
"When my time has come I prefer to be in the Saddle, rather than the Recliner" |
06-11-2009, 01:06 PM
#34 |
Oddometer: 9,781
You've seen this bike right?
06-11-2009, 01:15 PM
#35 | |
More tacos than you
Oddometer: 5,088
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
06-11-2009, 01:21 PM
#36 |
Oddometer: 9,781
Roughly but the knee portion is more contoured than the norton.
iirc it was a custom aluminum jobber. http://www.hotrodhomepage.com/hrhp/2...00-wh2-engine/ |
08-14-2012, 12:43 PM
#37 |
XLR8
Oddometer: 30
Believe it or not I got the H-1 running...again. Turns out it had the wrong coils in it hence the magic smoke coming out of them.
Also replaced all the points with new. I was always kind of underwhelmed by the power considering all the hype with the triples. Well now it have a MUCH better spark and hence at 7500 rpm it sounds like three chain saws running WFO and is now far too fast for the chassis and cheesy brakes...as it should be. Not to mention the dry rotted tires....hmm better order up some new tubes and skins....
"When my time has come I prefer to be in the Saddle, rather than the Recliner" Tundra Tom screwed with this post 08-14-2012 at 02:04 PM |
08-24-2012, 08:48 PM
#38 | |
Oddometer: 4,956
08-25-2012, 04:33 PM
#39 |
Oddometer: 993
Replace all 3 condensers, as having the wrong coils fitted will almost certainly have damaged them. Pressure test the motor before stripping it, as this will determine exactly where the leak is, and will save an awful lot of work.
You will also find that bikes pretty dangerous in the turns, as moving the shock mounts and fork tubes, will have reduced ground clearance quite a bit, and will mean center stand, pipes, and footrests will all ground out very easily. |
09-04-2012, 02:29 PM
#40 |
Back
Oddometer: 13,511
I thought the H1's were always CDI
. Seem to remember the little lightening bolt under the CDI badge on the old refrigerator white tanked ones.
"...Carved in stone is a date he had to go on, And another from the moment of his first dawn..." - In Memory of Preston Haun - In Memory of Mike Berlein - In Memory of Amanda Cassady |
09-04-2012, 02:41 PM
#41 |
De Oppresso Liber
Oddometer: 30,297
They were, even the 69 said Electric on the side cover meaning CDI. He is talking about replacing the pick up coils on the CDI he refers to them as condensers.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
09-04-2012, 02:54 PM
#42 | |
Back
Oddometer: 13,511
09-04-2012, 02:56 PM
#43 |
De Oppresso Liber
Oddometer: 30,297
yeah, that's odd right there. But there is a gap, an air gap on those pick up coils.....and they can be cleaned.
09-04-2012, 03:00 PM
#44 |
Back
Oddometer: 13,511
Yep just like the pick-up on my Lawn Boy
09-04-2012, 03:28 PM
#45 |
Oddometer: 993
H1A had CDI system, HIB points, and all the subsequent KH bikes CDI
