Old 02-26-2011, 04:35 PM   #91
solohvs
somewhere around the bend
solohvs's Avatar
Oddometer: 182
Ohlins Rear Shock
My Ohlins shock photo found a new home.
Ohlins rear shock
Thanks guys - all the info here makes sense to me, but I am disappointed that the shock brace will not fit... yet. I'll put my order in for the stronger top bolt and discard the bottom bolt for a new one. Couple of bucks spent in the right place.
Do I pull the rear wheel and the Mudsling too?
Or would that just make things more complicated?
I have a shop manual, but I haven't done much looking yet.
solohvs is offline   Reply With Quote
Old 02-26-2011, 04:52 PM   #92
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,661
You'll want to check on your bike, I could have installed the Ohlins with the RM brace with no problems. Since I have the Indy kit, I'm going to have to modify my RM brace like JohnGil did. But I did install my Ohlins rear shock today!
You definitely need to remove the mud sling. It will prevent you from removing the shock.
I don't know if you have to remove the rear wheel, mine is currently in another state, but it sure made it easier. I don't recall removing my rear wheel when I pulled the stock shock before.
Scott - Semper Fi
'04 BMW R1150GSA, '05.5 KTM 950 Adventure
Y E T I is offline   Reply With Quote
Old 02-26-2011, 04:59 PM   #93
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
The Ohlins BM-802 with the specific length spring they gave me will not fit in any way shape or form with my RM brace. I am going to order up a grade 12.9 upper bolt and wait for Ohlins to finish their upper support system. I'll just ride "gingerly" until then.
How much do you guys weigh? I have a feeling based upon what Johngil said about his spring that if you weigh 200+ lbs the spring they use is shorter than the spring for the 170-200 lb range. To be brief, if the spring is shorter, the hydraulic preload adjuster will be lower on the shock body which will possibly allow use with the RM brace. For some reason the spring that they put on for the 170-200 lb range is longer, making the hydraulic preload adjuster up higher on the shock body, which in turn makes a serious conflict with the RM brace.
I assure you, I personally cannot use the RM brace with my Ohlins.
Old 02-26-2011, 07:38 PM   #94
KnuckC
F8er
Oddometer: 199
You definitely do not have to pull the rear wheel.
KnuckC is offline   Reply With Quote
Old 03-01-2011, 09:23 AM   #95
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,479
Indy Upper shock mount Kits for Ohlins or other aftermarket shocks will be available late March for worldwide shipment
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 03-01-2011 at 09:30 AM
Indy Unlimited is offline   Reply With Quote
Old 03-01-2011, 10:28 AM   #96
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
I've got the stock shock one already, but I'll be ordering this version to await my Ohlins shock too.
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 03-01-2011, 12:17 PM   #97
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
If Ohlins is not done with their fix I will definitely buy the Indy kit. In fact, I will probably buy the Indy kit anyway since I can install it myself. Ohlins will want to install their fix themselves. Boo.
Old 03-01-2011, 07:27 PM   #98
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,661
Mine looks just like John Gil's, plenty of room between the shock and the RM brace. I just need to bore out the hole to fit the Indy brace. I do weigh more than 200 lbs.
For now, mine just has the Indy fix.
Scott - Semper Fi
Old 03-01-2011, 09:56 PM   #99
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,802
Isn't Ginger a girl's name?
johngil is offline   Reply With Quote
Old 03-02-2011, 07:49 AM   #100
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,661
I rode a Ginger once. Redheads rock. They're all insane but . . .
Oh wait . . .
Scott - Semper Fi
Old 03-02-2011, 08:21 AM   #101
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Oh wait . . .
Old 03-03-2011, 07:08 PM   #102
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,661
There's GOLD in that thur bike!!
Turns out the rebound adjuster really adjusts. I had it turned only two clicks out for my test ride. Not good. Now back to 14 and it's PLUSH!!
Scott - Semper Fi
Old 03-03-2011, 09:14 PM   #103
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Mine:
See, your prelaod ajuster assembly is considerably lower on the shock body than mine. Is your preload set to what it came as? Or have you cranked a bunch in?
I can see the retainer pin on your preload adjuster clear as day. Whereas on mine It's not even visible.
After setting my sag there is no way I could use the RM brace. Where the preload is in my pic is where it needs to be for my current weight.
Old 03-04-2011, 06:42 AM   #104
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,661
Mine:
I honestly haven't set my sag yet, I need to find a guide for how to do it. That is currently just how it came.
Scott - Semper Fi
Old 03-04-2011, 08:32 AM   #105
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
There's a guide for how to set sag in the manual for the shock.
I find it very interesting that the spring they are providing for the +200lb riders is shorter than the spring for the -200lb riders. If they can alter a spring's stiffness by other methods like wire diameter and composition, why would they need to change the lengths of the springs for different weight riders?
It really bums me out that I can't use the RM brace. Indy fix only for me I guess.
Times are GMT -7.   It's 03:35 PM.
