12-04-2011, 11:48 AM
#196 | |
Oddometer: 148
They do make a huge difference. |
12-05-2011, 08:58 AM
#197 | |
Oddometer: 42
02-02-2012, 02:32 PM
#198 | |
Oddometer: 3
SH300 recall - How effective?
I've had my 2008 SH300 for almost 4 years now and have enjoyed over 11,000 miles of great fun and trouble free riding. I have had the recall notice but have not had it done as; a) I have not had any problems (if it ain't broke don't fix it!) b) The mix of performance and economy for 280cc is just so good I wonder if the new ECU will adversely affect the SH to fix a problem I don't have? (I log every fill into a spreadsheet & my SH's lifetime overall mpg is 79.7. This included one winter where I fitted a big screen which knocked down average mpg to 74). Have any of you guys who have had the ECU update noticed any performance or fuel consumption changes? agesofman screwed with this post 02-02-2012 at 02:33 PM Reason: corrected title |
02-02-2012, 04:52 PM
#199 |
Oddometer: 4
Had mine done at Farnham Honda a couple of months ago, although I hadn't had the problems either. I put it in cos a) it was free, and b) I hoped they might clean it
Mines 2 years old / 9000 miles only used for the daily commute, and haven't noticed any difference in either starting, fuel economy or pick up / torque since they did the ECU swap, however my oil change light came on last week (about the right time) but won't cancel ! I'm wondering if it's related to the ECU swap. It's been on before and always cancels with ignition on, engine not running, hold down the trip and clock button together. This time just can't get it to switch off
02-02-2012, 05:01 PM
#200 |
Oddometer: 10
Can you suggest any good ride for the dirty roads?
02-04-2012, 12:58 AM
#201 |
Oddometer: 548
dude, we get the fury. there is a blue one sitting in my local dealer it has been there for a year or two.
also here it is on the honda uk website where only models available in uk are shown. http://www.honda.co.uk/motorcycles/custom/#!/vt1300cx/
'11 Honda Hornet '01 Peugeot Speedfight 100 4x Puch Maxi |
02-04-2012, 08:55 AM
#202 | |
LE Rosbeeeeef!
Oddometer: 349
since then, the bike stalled a few times when pulling away from standstill, it stalled once whilst riding along in central London, which wasnt the best considering that you need to have the brake held in to restart the bike.................... After a few weeks of riding, the bike stopped stalling and has been perfect ever since |
03-07-2012, 01:55 PM
#203 |
Pas mi Ellin Varvaro
Oddometer: 2
Hi owned a Honda sh300i/CBS ,now i have 8500 km of working order but 5 times in the past,the engine stall when i was idling, i've changed everything but the problem insists (Change ECU,IACV,Throttle Body) do you know what causing all this trouble...
Do you know anybody something about this issue! thanks in advance! |
03-13-2012, 03:15 PM
#204 | |
Oddometer: 148
John |
04-16-2012, 04:21 AM
#205 |
Oddometer: 1
Just bought 2011 SH300... seems nice one week in.
Just checked the oil for the first time (bought it with 2000 miles on it). Do you do this on the centre stand, with the dipstick unscrewed and place back in place? It's reading pretty low. The dealer did say it will consume oil, being used for stop-start traffic a lot (central London). Can anyone else report on how much oil they're using, and how they're reliably checking it please? Many thanks. Previous bike was a 2-stroke... |
04-16-2012, 12:42 PM
#206 |
Oddometer: 148
Check oil on centre-stand with dipstick unscrewed and resting on the mouth of the filler hole.
Top it up and then check how much oil is being used. Honda recommend 10W-40 semi-synthetic. Mine uses very little oil, but it does not hold very much anyway, so I check it regularly. Best of luck, John |
04-20-2012, 01:43 AM
#207 |
Scooterist
Oddometer: 20
Belt change?
Hi all
My SH is nearly at 11,000 miles so I guess a drive belt change is due, correct? I'd like to get the parts in advance so are there any other things that need changing at the same time such as the rollers? The reason I ask is that on cold days after a few minutes running, when pulling away, it seems that the clutch is engaging far too quickly and I can only describe it as trying to pull away in a car in too high a gear. It clears after the engine warms up so I'm assuming it may be worn or sticky rollers. Any ideas? TIA P.s. Any videos or 'how to's' available on the belt change? |
04-21-2012, 06:31 AM
#208 | |
Oddometer: 42
04-21-2012, 10:19 PM
#209 | |
Oddometer: 148
The lower service limit for the belt is 25.5mm and mine measured 25mm, the rollers measured 23mm which is well within the standard tolerance of 22.92 to 23.08. Since the weather warmed up immediately after changing the belt, I don't really know whether changing it effected the cure. Hope this helps, John John Bentall screwed with this post 04-21-2012 at 11:57 PM |
04-22-2012, 12:02 AM
#210 | |
Scooterist
Oddometer: 20
