Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 214 votes, 5.00 average. Display Modes
Old 05-16-2009, 11:43 AM   #136
PaleRider
gelande/strasse
PaleRider's Avatar
Oddometer: 9,980
Originally Posted by Jeffy
They are work trucks. Day and night, they are usually working. Unless there is a meetup someplace, you don't usualy see them as they are on truck routes.
Ooo, BMW's Art Cars...
1975: 3.0 CSL by Alexander Calder
1976: 3.0 CSL by Frank Stella
1977: 320i by Roy Lichtenstein
1982: 635 Csi by Ernst Fuchs
... I like the BMW art car series alot, and the initial Calder version is my favorite (those others are nice too).
... I also like: 1999: V12 LMR by Jenny Holzer
"Spirit ain't worth spit without a little exercise."
- Preacher
One Life. Live It.
PaleRider is offline   Reply With Quote
Old 05-16-2009, 12:30 PM   #137
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,411
Miles Crouch's Triumph Spitfire with Ford 2.3 Turbo Engine
as published in British V8 Newsletter, Volume XV Issue 2, September 2007
Owner: Miles Crouch
City: Atlanta GA
Model: 1979 Triumph Spitfire
Engine: Ford 2.3 turbo inline four-cylinder engine
Conversion performed by: Owner
Engine: the engine is from an SVO Mustang. It's been balanced and blue-printed, and the head has been ported by Boport. Wiseco pistons. Chevy 5.7" rods. I have adapted the 4g63 oil jets from a Mitsubishi engine into the Ford 2.3 block to cool the pistons better.
Induction: custom intake with a 75mm throttle body, 96lb injectors, water methenol injection, and an 1100cfm intercooler.
Engine Electrical: SDS engine management, using the Ford factory harness.
Cooling: big block radiator. It stays cool and can sit all day in traffic with no problem.
Exhaust: 3.5" down-pipe off the turbo into a pulse chamber. I made the exhaust by taking 1.5" pipe and cutting it in two, then using a 7 inch flat steel to connect the two halves of the 1.5" pipe. This will give a little more than the 3.5" pipe and great ground clearance. Supertrapp muffler.
Transmission: Performance Automatic C-4 3 speed with transmission brake and 1/1 final drive ratio. 3000rpm stall, 9" torque converter. Custom driveshaft with 2 safety loops.
Rear Axle: narrowed 9" Ford, with limited slip differential, 2.75:1 ratio, and 28 spline axles.
Front Suspension: custom air-ride suspension. I made my own A-arms and used Mustang II front spindles. Grand National shocks. Factory Spitfire rack and tie-rod ends.
Rear Suspension: 4-link and Panhard bar, with airbags and camaro shocks.
Brakes: four wheel disk.
Wheels: 15" Prostar Street and Drag aluminum.
Chassis: factory Spitfire frame supplemented with a full rollcage. The 4-link structure runs rocker-to-rocker and was tied into the old factory frame for the conversion. Trust me, the car goes straight out of the hole and this is important.
Body: Frenched antenna. Ford rear wing.
Electrical: more room for gauges and I made a new wire harness that had more than 3 grounds and a few fuses.
Performance: as originally set up, we did 511 at the wheels with 29psi and 116 octane. 93 octane @ 23 psi with water methenol made 348 rwhp. We're working on a new set-up that should be better.
Weight: between 1950 and 2000lbs.
Miles Driven: thousands... to Montgomery AL and everywhere around Atlanta. No trailer queen here!
Comments: all the work was done by myself except rebuilding the turbo and the transmission. This car is making over 500hp at the wheels with race gas. I have to get an NHRA driver's license now because it was too fast on the track! There are many other mods, but those are the main ones.
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson
Jeffy is offline   Reply With Quote
Old 05-16-2009, 12:43 PM   #138
CGH
Polluting the ether
CGH's Avatar
Oddometer: 23,134
Originally Posted by celticgent
Body by Fisher sawzall.
"...the hero would be me. Heroes often fail."
CGH is offline   Reply With Quote
Old 05-16-2009, 01:53 PM   #139
ADK
____
Oddometer: 8,245
Originally Posted by pirahna
Warhol should be in prison for this.
Remember when VH1 gave away the Corvette collection? He purchased the collection from the winner. The cars have been sitting in some crappy parking garage rotting away ever since.
ADK is offline   Reply With Quote
Old 05-16-2009, 02:38 PM   #140
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
100mpg is offline   Reply With Quote
Old 05-16-2009, 02:51 PM   #141
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,963
Chrome has some practical use for making parts corrosion-resistant and providing a durable finish. Anything gold-colored on a car screams bling and trying to appear richer than you are, especially on an old cheap car that smokes.
Support the AMA.
Waco is offline   Reply With Quote
Old 05-17-2009, 01:42 AM   #142
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,660
late chiming in but i think that's quite cool actually
made me chuckle anyways....
Never been a huge fan of this era of Roller's so this is a nice take on it IMO
Edit: seems i'm not alone in liking this! COOL!
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie screwed with this post 05-17-2009 at 01:50 AM
Shaggie is offline   Reply With Quote
Old 05-17-2009, 05:24 AM   #143
bajones238
Retired
bajones238's Avatar
Oddometer: 60
As someone said earlier:
bajones238 is offline   Reply With Quote
Old 05-17-2009, 05:49 AM   #144
JimX
Oddometer: 720
JimX is offline   Reply With Quote
Old 05-17-2009, 08:42 AM   #145
Brad Felmey
Brad Felmey's Avatar
Oddometer: 5,002
Originally Posted by JimX
They turned a 911 into a Citroen.
Brad Felmey is offline   Reply With Quote
Old 05-17-2009, 08:43 AM   #146
PaleRider
gelande/strasse
PaleRider's Avatar
Oddometer: 9,980
... what's wrong w/ this?
- Preacher
One Life. Live It.
Old 05-17-2009, 09:36 AM   #147
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Oddometer: 180
Um... I hate to be the one to break this to you guys but... Andy Warhol is quite dead. And has been since before there was such a thing as VH1.
I'm calm like a bomb!
http://darthlefty.livejournal.com
http://www.active2030folsom.org
Darth Lefty is offline   Reply With Quote
Old 05-17-2009, 09:52 AM   #148
42
Bokononist
42's Avatar
Oddometer: 17,707
Nothing.
42 is online now   Reply With Quote
Old 05-17-2009, 10:08 AM   #149
jeep44
junk collector
jeep44's Avatar
Oddometer: 2,094
I could say a lot of things,but Maybe I'd better not. My wife has had one of those Devilles since '95. I had to step out and look at it to see just how much metal they had to saw out to get those stupid tires and rims to fit. With the standard tires on it, I can barely slide my hand up under the trim to put Armorall or whatever on the rear tires-I guess that's why that idiot had to break out the Sawzall.
jeep44 is offline   Reply With Quote
Old 05-17-2009, 10:34 AM   #150
summerinmaine
Hells Atheists MC
summerinmaine's Avatar
Oddometer: 48,182
IIRC it was Peter Max who bought the collection and stashed them in a garage, neglected.
Perhaps it's some kind of "performance art."
"I think you'll find it's a bit more complicated than that." Ben Goldacre
summerinmaine is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 08:21 AM.
