Old 11-20-2011, 04:06 PM   #226
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,033
Looking good Ray.
Pity your having grief with the headlights, they looked good in the pics.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 11-23-2011, 06:51 PM   #227
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
Check out this one for fun.
http://www.photoreflect.com/store/Or...&po=281&pc=653
Pictures 281 to 307 Pictures may disappear in a week.
US129.com The Dragon November 12th, 2011 Saturday 11/12/2011
scooteraug02 is offline   Reply With Quote
Old 11-30-2011, 01:39 PM   #228
tripodtiger OP
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,700
Originally Posted by TouringDave View Post
Looking good Ray.
Gee, how dated is this thread?
S'pose that happens once a project becomes 'finished'.
I ended up taking a photograph of the headlight and having that printed onto a pair of decals. They went onto a plastic disc that I fixed into the recesses. They looked very sad until I put the clear stone covers over them. Quite a few people have thought they were real headlights. I think the plastic covers just give them that reflective shine that happens with glass. Looks okay. I'm thinking some real headlights may just have to go in, one day.
rayb Crash Dummy (no testing involved)
Old 11-30-2011, 01:43 PM   #229
tripodtiger OP
I used to be SCRay
Oddometer: 4,700
That is the awesome-est Tiger!
It's almost better than mine!
Calling LeighSA!
Is there a write up? I'd love to read that, especially how the 2wd is set up?
The advantage of mine is, however, mine is in my garage. This one is only two dimensional, insofar as I am concerned.
Old 11-30-2011, 01:43 PM   #230
TouringDave
Tri Moto Veritas
Oddometer: 7,033
[QUOTE=tripodtiger;17413847]Gee, how dated is this thread?
/QUOTE]
Finished? Finished? What is this "finished" you speak of?
I didn't think it was possible to finish a sidecar project.
K7 Strom with Chair
Old 11-30-2011, 01:51 PM   #231
tripodtiger OP
I used to be SCRay
Oddometer: 4,700
[QUOTE=TouringDave;17413883]
/QUOTE]
I did write 'finished', not finished.
I'm now contemplating pulling the aibox off & having a few small alterations done. I dare say I wont get much opportunity to ride it in the next month, so it's the perfect time. Must make a video of the air filter service and airbox removal. Post it onto the web so all the other T300 owners can weep!
Don't you have some job to go to?
Or are you already at work?
Old 11-30-2011, 05:57 PM   #232
scooteraug02
Dog Rancher
Oddometer: 4,521
Calling LeighSA!
I couldn't find a write up.
Maybe it is like this:
http://www.advrider.com/forums/showthread.php?t=532098
http://mobec-international.com/range/duodrive/index.php
Old 12-28-2011, 05:26 AM   #233
tripodtiger OP
I used to be SCRay
Oddometer: 4,700
Not a Mobec.
Chain drive has been taken from left to right.
Moved in board and then has a shaft to drive the rear wheel.
What isn't clear is whether it's driving the sidecar wheel also. One may have to assume so, because that's an awful lot of work to allow the use of the same wheels.
I was searching for an electrical problem on mine. Kept getting flat batteries and I didn't believe it was the battery. So I tested the alternator - following instructions given by My Master.
Not the alternator
More instructions and I quickly discovered it was the controller for the heated grips. This would be the 3rd time the controller for the grips has given up in one way or another. And, I gotta say, I haven't used the heated grips that often.
More trouble than they are worth?
Anyway. Having solved that problem I did what any self respecting lunatic would do, I kept right on with the spanners!
Pulled the rear rack to pieces and made up a template for my Pelican case to go on. So now, before I do that I want to find a black case.
Changed the dust seal under the seat/lid of the box. Larger section seal but stuck in the recess that was made for it.
Pulled the airbox off. That took about 10 minutes but discovered a bit of a drama. One of the inlet manifold rubbers had folded over. I can only hope it was providing a seal for the carb. No dust evident around it, so there is hope.
I set the rubber into hot water a couple of times, trying to get the correct shape back. It almost worked.
Almost being the significant word.
On the phone tomorrow to get another one ordered. This time of year it may be longer to get one than normal.
New tyres shortly, too. TKC on the front, for a change.
Leigh and I have been toying with the idea of having a wide 17" rim laced to the standard rear hub. That will allow me to use a 150 / 17 TKC (do they make a 160?) or similar for when I know that I'm going into looser terrain, to give a bit of traction. The car tyre is just inadequate.
Next question to answer is how wide can I go with the rim, to flatten the profile of a bike tyre?
How much am I willing to spend on another wheel?
More things that make you go 'hhmmmm'
And the answer to whether I can get a TKC in 160? No. They make a 180/55 - what does that go on? Otherwise, the 150 is as big as it gets.
Old 12-31-2011, 11:00 AM   #234
mikejohn
mikejohn's Avatar
Oddometer: 1,179
how much beer ya want for the blue prints and dimensions of this here airbox?
mikejohn is offline   Reply With Quote
Old 01-02-2012, 04:19 PM   #235
tripodtiger OP
I used to be SCRay
Oddometer: 4,700
Well, for a start, that stuff you blokes call beer.
Seriously, the man that designed & constructed it isn't a drinker. He bought half a dozen cans of bourbon & coke - that should be his annual intake, only for very stressful situations, mind.
He happens to be visiting at this very moment and wants to know "Who's going to buy one for $1000?"
He said he'll give you some guidance regarding the requirements. Version 2 has yet to be built, and the only real alterations need to be in the join between the airbox body & the inlet chamber - just to get it to seal properly but still be able to be easily removed.
Leigh will get m back to you on this one. He's on a holiday trip at the moment.
Old 01-22-2012, 02:58 AM   #236
bully1
bully1's Avatar
Oddometer: 4,382
Here's a bit of an update. There is some progress with the Tiger, specifically the engine... but I can show you what Leigh has been spent most of his time doing.
It's a little job on an R100GS P/D
Not sure if you have seen it Ray but the PD has a new home on the west coast.
I picked it up just before chrissie, got Alex to check it out for me. F@#k it rides nice !! just upgraded the brakes to dual discs on the front and getting an ali chair made up for it, I'll post up pics when it's done.
I'll have to contact Leigh to get some more info on it, the original owner was a bit vague about it.
'02 GSX 1400 outfit........lot's of grin factor
'11 Husky TE 630.......tyre shredder
'06 HUSKY TE610 x 2............ for the boys
'92 R100GSPD ( modified)...........slow and easy
bully1 is offline   Reply With Quote
Old 01-24-2012, 09:37 PM   #237
tripodtiger OP
I used to be SCRay
Oddometer: 4,700
Maybe a bit like passing on an old book. Good luck with it.
I changed over the front tyre to a TKC80 - what a difference in steering! Astoundingly different.
The old Avon had been on it for quite a number of years. Seemed like it would never wear out. First few feet with the TKC and I can immediately tell it turns much more easily. It's like riding a different bike it's so quick to turn. I suspect my wife wouldn't have any problems riding it.
Better get back to it. New rear tyre to go in this arvo. And throw a bit of paint at my small top box, plus mount the under top box support.
Never quite finished.
Old 05-09-2012, 06:30 AM   #238
tripodtiger OP
I used to be SCRay
Oddometer: 4,700
Trek gets some use, every now & then.
This is on the way back from a AdvRider get together.
It shows that Alec is getting to do a bit of hanging off the side. Not around town or on main roads however. Far too many finger waggers and nay sayers.
Old 05-09-2012, 07:20 AM   #239
DRjoe
DRjoe's Avatar
Oddometer: 5,095
that looks like fun
DRjoe is online now   Reply With Quote
Old 02-25-2013, 06:32 PM   #240
tripodtiger OP
I used to be SCRay
Oddometer: 4,700
this was fun too.
except I got wet socks.
Trek Too is progressing, in Adelaide. Quite a few alterations that I'm jealous of.
Times are GMT -7.   It's 02:42 AM.
