Old 04-30-2009, 11:58 AM   #1
mnormand OP
Oddometer: 358
Garmin 60CSx firmware v3.90 probs?
I see on another forum some folks had probs after using Garmin's Web-updater and upgrading their firmware to this recent v3.90 release dated 3/30/09.
I was about to do this, but stopped for now. Any new information or success stories here?
Thx!
mnormand is offline   Reply With Quote
Old 04-30-2009, 12:53 PM   #2
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
I just tried it. The first time it said eveything seemed to go fine but at the end the 60Cx let out a long beep and displayed "software missing"
I ran it again and now everything appears fine. I had quite a scare though.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 04-30-2009, 01:22 PM   #3
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
Also - I hadn't updated mine for a while so I think I still had v3.30 The first time I ran the update it said it was updating verion 3.30. After the failure, on the second install it said it was updating v3.10
I should remember this by now, but how do you find the current software version on the unit? (60Cx).
Mike S.
AMA MSTA
Old 04-30-2009, 01:31 PM   #4
Countdown
Oddometer: 5,463
I always read what the changes are before ever updating anything. If I don't need some new feature that corrects "POIs in French", I don't take a chance.
Jerry Counts
Countdown is online now   Reply With Quote
Old 04-30-2009, 01:41 PM   #5
mnormand OP
Oddometer: 358
I hear ya Jerry, at first glance I thought this sounded ok on paper ...
From Garmin's site....
Changes made from version 3.70 to 3.90:
  • Added support for maps greater than 2 GB.
Old 04-30-2009, 01:43 PM   #6
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
Agreed, but I hadn't done mine for a while so I thought I probably had some worthwhile updates in there.
Again, it *did* work ok the second time...
Mike S.
AMA MSTA
Old 04-30-2009, 01:43 PM   #7
Countdown
Oddometer: 5,463
That would be a good one for sure!
Jerry Counts
Old 04-30-2009, 01:44 PM   #8
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
Hey, how do I display the current software version on the unit?
Mike S.
AMA MSTA
Old 04-30-2009, 02:04 PM   #9
mnormand OP
Oddometer: 358
a quick google produces..
1.
How can I tell what version of firmware is in my Garmin GPSMap 60CSx?
MENU > MENU > Setup > ENTR > System > ENTR > MENU >Software Version > ENTR
2.
How can I tell how much map memory is in use on the GPS?
There are a couple of options.
On recent firmware, Go to the Main Menu, then select or press Tracks:Enter:Setup:Enterata Card Setup:Enter:Menu:Card Info:Enter
On any firmware, but you can start Mapsource and read maps from the GPS. In the tab for 'maps' it will display a total of the space used.
Alternately, you can put the GPS into Mass Storage mode and view the disk usage on it from your favorite computer.
3.
Why do I sometimes see two firmware version numbers displayed?
If you see two version numbers displayed, the first is the main OS of the receiver. The second is the version of the code used by the Sirf receiver circuit.
Old 04-30-2009, 03:26 PM   #10
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
Thanks. I tried searching Garmin's site, ADVrider, and then a general Google and didn't come up with anything. Maybe because I was using "software" instead of "firmware" .
I am showing version 3.90 now.
Mike S.
AMA MSTA
Old 04-30-2009, 10:48 PM   #11
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,798
3.90 worked for me first time. Just lucky I guess.
GodSilla is offline   Reply With Quote
Old 05-01-2009, 02:15 AM   #12
the venturer
the venturer's Avatar
Oddometer: 1,415
Is this the same problem as mine?
http://www.advrider.com/forums/showthread.php?t=459602
the venturer is offline   Reply With Quote
Old 05-01-2009, 06:58 AM   #13
mnormand OP
Oddometer: 358
Venturer I pm'd you some info from elsewhere, hope it helps you.
Old 05-01-2009, 10:58 AM   #14
the venturer
Oddometer: 1,415
I got it but I own a Streetpilot 2610. I will sign up to get deeper into the forum. Thx.
Old 05-02-2009, 05:10 AM   #15
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,021
This is interesting. From this thread 60csx powers down when routing
Thanks for the info, John.
Originally Posted by Blind Joe Beck
There is an on-going thread on the Garmin_GPSMap_60Cx_60CSx Yahoo forum to the effect that the 3.90 firmware causes the unit to behave as you describe. There seem to be two workarounds:
- Re-install 3.90 (Using the WebUpdater as opposed to manually downloading and running the install)
http://www8.garmin.com/products/webu...wtoinstall.jsp
- Install the 3.70 firmware (which might be available here: http://www.gpsinformation.org/perry/gps60/ )
Yahoo forum: http://groups.yahoo.com/group/Garmin_GPSMap_60Cx_60CSx/
- John Goldie
dunno.....
Times are GMT -7.   It's 12:12 PM.
