Old 05-01-2009, 03:31 AM   #1
the white rabbit OP
Vicarious
the white rabbit's Avatar
Oddometer: 3,051
60csx powers down when routing
I just got hold of a 60CSX second hand and it seems to power down when routing, if the routing takes more than a few seconds. I thought the card was wrong or too many tiles so I tried a bog-standard 2GB with not many tiles, still happens. It then will power up, try again, fail, etc etc.
It has firmware 3.90.
I did wonder if it was because I had both GB Topo v2 and Navigator Europe v9 on at the same time, but seems to happen (although less) if I hide Topo.
Any ideas? It is doing this while sitting on the desk, so not a vibration issue!
Edit, I will only have intermitant internet if anyone has an idea, so please bear with me in replying
'These are the hardest conditions I have made a basket like this in' Ray Mears
the white rabbit screwed with this post 05-01-2009 at 04:52 AM
the white rabbit is offline   Reply With Quote
Old 05-01-2009, 05:48 PM   #2
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,880
What sort of batteries are you using?
I've been using lithium batteries (despite what the manual says) because they provide strong consistent power right to the end. It's possible that the extra power requirement of enabling routing is drawing more than the batteries can provide, the symptom sounds the same as when the batteries run flat. Just a guess.
GodSilla is offline   Reply With Quote
Old 05-01-2009, 08:35 PM   #3
Blind Joe Beck
Blind Joe Beck's Avatar
Oddometer: 94
There is an on-going thread on the Garmin_GPSMap_60Cx_60CSx Yahoo forum to the effect that the 3.90 firmware causes the unit to behave as you describe. There seem to be two workarounds:
- Re-install 3.90 (Using the WebUpdater as opposed to manually downloading and running the install)
http://www8.garmin.com/products/webu...wtoinstall.jsp
- Install the 3.70 firmware (which might be available here: http://www.gpsinformation.org/perry/gps60/ )
Yahoo forum: http://groups.yahoo.com/group/Garmin_GPSMap_60Cx_60CSx/
- John Goldie
Blind Joe Beck is offline   Reply With Quote
Old 05-06-2009, 03:22 AM   #4
the white rabbit OP
Vicarious
Oddometer: 3,051
Thanks for your help.
Old 05-06-2009, 03:26 AM   #5
the white rabbit OP
Vicarious
Oddometer: 3,051
I was using brand new Duracell's, I don't have an external power source to try and see if that solves it. Thanks.
Old 08-01-2009, 01:49 PM   #6
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
This solution worked perfectly for me - my 60CSx with 3.90 firmware was powering down every time I tried to calculate a route, and using Web Updater made the problem go away.
Software is now on version 4.00, not 3.90.
Times are GMT -7.   It's 11:56 AM.
