Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 11-01-2009, 02:31 PM   #46
chipgibbs
ChipG
Oddometer: 125
Sheridan
This is my Sheridan dated about 1968. Check out the original scope, its a
Western Field 4 x 15.
1991 DR650S Dirt Tractor
1989 Harley Davidson Tour Glide Rocket
ChipG
chipgibbs is offline   Reply With Quote
Old 11-02-2009, 08:15 AM   #47
McNeal
Oddometer: 1,738
Originally Posted by koifarm
An old indian trick with traps, assuming you're using rat traps, is to put three traps together in a "T" form, triggers together, and use pecans as bait. Make a small slit in the pecan, crack it slightly, and shove the metal trigger in the slit firmly attaching the nut to the triggers. You'll get them that way.....if not put four traps in a square with triggers on the inside.
Hmm, I'll try that. I've used both the non-lethal traps and the big rat traps. The non-lethal traps only got the the young ones as the older squirrels knew to reach in from the side and get the peanut butter. I used the rat trap a couple of times and only once caught a squirrel. While I gladly kill a squirrel if its chewing up my house I'm not going to be cruel about it. The squirrel that was caught wasn't killed straight away. The trap caught the squirrel across the shoulders. I didn't know squirrels could scream like that. I ran out with my pellet gun and put one in the back of its head. I'll try your "T" idea and have the pellet gun ready.
McNeal is offline   Reply With Quote
Old 02-11-2010, 08:58 PM   #48
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,867
all I can talk about is from my experinec in the UK a few years ago.
in the UK the max power for an air rifle is 12 ft/lbs.
as a .22 pellet is heavier than a .177, the .22 will have a lower vlocity than the .177 but as it is heavier, it packs the same punch, 12 ft/lb
so, for stopping power of vermin (rabbits / rats / birds) the .22 is the best.
for long distance the .177 is better. because it flies faster, it travels further before hitting the ground (due to the effects of gravity) and hence has a flatter trajectory. for a .22 the further away the more compensation you have to give it i.e. aim higher
but
a .177 is affected more by wind and blades of grass etc.
the .177 will have the same stopping power (12 ft/lbs) as the .22
I found that the .177 woudl penetrate right through rabbits where as the /22 would not exit. remember the old boys talking about the stopping power of the 7.62 Nato as opposed to the 5.56 Nato, its the same.
I would some times shoot clay pigeons with my .177 and the center part, the .177 pellet would often pass through with out it breaking the clay the .22 would break it every time. (they would be propped up against a fence or wall - not flying!)
My .177 had a power of about 9.5 ft/lb but the fps was constant to within +/- 10 fps. The .22 was bang on 11.9 and similar consistancy.
there is a formula for working out the ft/lbs - I cant remember what it is.
like so many things, the more you pay, the better the quality - as long as it is designed for the task - no point in getting a paper taget rifle for shooting verming, not really appropraite.
I got out of air rifles just before pre-charged started getting popular, bu my choice would be a spring gun (or gas ram - Theoben) and I had good expericnes with Air Arms - the pro sport looked like a proper rifle too.
I had scopes on mine, but neiter were set up for open sights. If I was getting in to air rifles again, I wouldn't consider getting one with open sights, a sign of cheapness (unless it was a paper puncher type)
recomendatations - Air Arms Pro-sport or Weirauch
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 02-11-2010, 09:02 PM   #49
Cumminsman76
befuddled
Cumminsman76's Avatar
Oddometer: 8,586
I was at an auction yesterday. There was a Benjerman like the OP's but blued new in the box. Three hundred and seventy five bucks.
STURGIS ride report.
2009 R1200 Gelände/Straße Abenteuer
A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail
Save $5 on Smugmug "1alkVgTNLEuyQ"
Cumminsman76 is offline   Reply With Quote
Old 02-22-2010, 11:03 AM   #50
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,737
Any Sheridan experts in here?
I've got a late '71, early '72 Blue streak that I'd like to learn more about.
I don't have any pictures yet, but my main question is regarding the stock. Mine has a checkered grip and it has a more contoured thumb hold than any other ones I've seen.
It was my dad's, but sadly I can't get the history from him.
z@ch is offline   Reply With Quote
Old 02-23-2010, 09:10 AM   #51
docwells7
docwells7's Avatar
Oddometer: 6,535
Air Arms TX200 left handed action in a right handed action. The guy I bought it from preferred loading from the left side, and not knowing any better, I didn't find it a problem. Really accurate...wish I was...
I also have an IZH 46 just to punch holes in my basement in a homemade silent trap. Boy is that a humbling exercise. This is not my photo, I borrowed it from a search on smugmug.
I also have an IZH 60 rifle. It's flimsy as hell, but surprisingly accurate considering it has a loose fitting five shot inline magazine. I will say this...it is one of the funnest little guns I own. Also mostly for plinking and hole punching in the basement.
This is another borrowed image from google, but you get the picture...the only difference is I got a peep sight that really improved my accuracy, otherwise stock.
Seriously considering a blued Benjamin...
'1984 was a warning, not an instruction manual.' - Unknown
IBA#25276
Airhead#9654
docwells7 is offline   Reply With Quote
Old 02-23-2010, 09:29 AM   #52
Aurelius
Aurelius's Avatar
Oddometer: 22,458
Baikal IZH46M
Fired this test group off hand at 15 meters:
Dizave opined: Why do you care where the premises come from? They are above reproach. For all intents and purposes, you can just make up all your premises, since they can't be proven anyway. That's why we need premises.
Aurelius is offline   Reply With Quote
Old 02-23-2010, 09:34 AM   #53
z@ch
z@ch's Avatar
Oddometer: 4,737
Just shot my blue streak for the first time last night.
I'm hitting 3/4" circles pretty consistently already. This thing is FUN to shoot.
that pumping/single shot thing is kinda a PIA though.
Old 02-25-2010, 07:43 PM   #54
Anglewood
Has a fake Mustache
Anglewood's Avatar
Oddometer: 1,205
My first air rifle was a Red Ryder BB gun. I have shot thousands of rounds through it to the point that I barely have to aim using the sights. About two years later, I got a Beeman HW-30 Break action and have also gone through thousands of rounds. It may be a "budget" gun for some (about $170 in 1990) but has kept many birds out of the orchard and is still fun to plink with when back home. I don't have a pic handy, but I am sure I will pass that gun down to my future kids when the time comes.
Lates,
Connor
Anglewood screwed with this post 02-26-2010 at 01:47 AM
Anglewood is offline   Reply With Quote
Old 01-30-2013, 09:25 AM   #55
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,304
Lewis and Clark - Air Rifle in NRA Museum
See post #58 below
"Honeste vivere, alterum non laedere, suum cuique tribuere"
Plug and Plug.
Old_Lion screwed with this post 01-30-2013 at 12:35 PM
Old_Lion is offline   Reply With Quote
Old 01-30-2013, 09:50 AM   #56
straightrod
Oddometer: 1,311
^ What a fine video from NRA. Do firearms of any kind make a difference in ones life - absolutely.
straightrod is offline   Reply With Quote
Old 01-30-2013, 09:59 AM   #57
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,304
Toky Marui M9 Airsoft pistol
When searching Google with:
site:www.advrider.com airsoft
one is presented with numerous posts and threads relating to
balancing tires with Airsoft BBs.
I did notice a brief discussion at
http://www.advrider.com/forums/showthread.php?t=539582
which ended three years ago in January of 2010 with thirteen posts.
One of my grandsons has been playing Milsims (military simulations).
As a result I have become interested in Airsoft rifles and handguns.
Consequently I purchased on Ebay a used Tokyo Marui M9 replica springer pistol.
I have owned air rifles and pistols for 66 years (since age 12).
Never been one to spend fortunes on anything.
So my limited possessions are:
Daisy Powerline 717 Spring Pistol
http://www.daisy.com/node/70
Daisy Powerline 917 Multipump Rifle
This one seems to have made it into the National Firearms Museum.
LINK
Sheridan Bluestreak
Crosman claims that they have sold this rifle for over four decades.
LINK
That seems a bit of a stretch to me.
I ordered the gun from the Sheridan factory in Wisconsin.
Benjamin bought the company in 1977.
Crosman acquired it in 1992.
History of the Company LINK
They have stood up without failing since I bought them decades ago.
I must say that the more I learn about Airsoft the more I am leaning toward
expanding into the Airsoft arsenal.
The Tokyo Marui M9 replica makes for easy and unobtrusive practice.
Before breakfast shooting from the kitchen door a few rounds at a target in the yard keeps one's
muscle memory intact.
George
Plug and Plug.
Old_Lion screwed with this post 01-30-2013 at 12:29 PM
Old 01-30-2013, 12:34 PM   #58
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,304
Lewis and Clark Girandoni Air Rifle
Be it said that without this Girandoni Air Rifle the expedition might have ended in tragedy.
Some interesting facts about the Girandoni Rifle
http://en.wikipedia.org/wiki/Girandoni_Air_Rifle
The Girandoni air rifle was an important first. It was the first repeating rifle of any kind
to see military service. It was one of the first uses of a tubular magazine.
And, although it saw service for only 35 years, it predated and was more advanced
in design and mechanical technology than the Henry rifle which arrived fifty years later.
Historical background and research LINK
Additional LINK
By Robert D. Beeman Ph.D
See section entitled:
Evidence Area 2: Number of Shots Per Air Charge
George
Plug and Plug.
Old_Lion screwed with this post 01-30-2013 at 02:00 PM
Old 01-30-2013, 12:55 PM   #59
chipgibbs
ChipG
Oddometer: 125
Question Giradoni amazing
How come a modern day air rifle can't get 40 shots on an 800psi fill? And why can't a modern day air rifle shoot 20 shots in 32 seconds? And it doesn't even make a report or make smoke?
I have many air rifles and none of mine can do any of this.....
I hate to say but, I'm pretty sure somebody's got their facts mixed up
ChipG
Old 01-30-2013, 01:52 PM   #60
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,304
Girandoni in the Pentagon
http://www.army.mil/article/27314/army-officers-journals-and-an-air-rifle/
"An air rifle believed to have been on the Lewis and Clark expedition, now owned by the U.S. Army Heritage and Education Center, Carlisle, Pa., is currently on display at the Pentagon."
http://www.army.mil/article/15180/army-opens-living-history-exhibit-at-pentagon/
WASHINGTON (Army News Service, Dec. 15, 2008
" The Girandoni Air Rifle: Designed and manufactured in Vienna, Austria in the 1780s, the weapon fits the description of the air rifle taken by the Corps of Discovery on their expedition in 1803-1806. The rifle has the marks of use and repairs consistent with the descriptions in the Lewis and Clark journals."
George
Plug and Plug.
Thread Tools
Times are GMT -7.   It's 04:57 PM.
