Old 04-27-2012, 10:09 AM   #2866
bonzodg
24/7 B-road hooner
Oddometer: 97
AND.............................
if you need to check the camshaft timing with the crankshaft -
turn the crankshaft until both valves are rocking(one going in,one coming back out)
Put a slim screwdriver in the spark plug hole and press it against the top of the piston.
It should be at the top of its stroke.
This is a bloody good 'rule of thumb' way to check,though some camshafts are set very slightly off top dead centre.
Good luck!
20 years of VFR thrashing - if it don't break,it don't need fixing!
bonzodg is offline   Reply With Quote
Old 04-27-2012, 10:12 AM   #2867
nathanthepostman OP
Oddometer: 610
Now I'm baffled.
As they say here in England, and perhaps in other parts of the world as well; there's more than one way to skin a cat. And it seems with valve clearance that's also true as well.
Going to sit down later, take my time over the manual, try and figure it all out and try again once she's cooled.
Just answer me this; how many passes can the 'T' make past the marker before it has completed one 'cycle'; is it two?
And lastly, to anyone who might be wondering why this has become a mechanical seminar and not a ride report, I can only apologise. Sorry.
nathanthepostman is offline   Reply With Quote
Old 04-27-2012, 10:42 AM   #2868
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by nathanthepostman View Post
Now I'm baffled.
YES! Two revolutions. Always rotate the motor FORWARD .... as in the drive direction. (use kick start to determine which direction is forward) When rotating, never go back.
I would not use a screw driver down the spark plug hole ... but the idea is good. Use a chop stick or some such, don't let it break off. When rotating, you will come round to the compression stroke and your chop stick will rise UP as piston come to TDC. At this point line up timing mark. Once there, you are ready to check valve clearances.
If you have adjusted valves when not on compression stroke at TDC, then your current valve setting may be all screwed up and will need to be re-set when at TDC on compression stroke.
Reading the manual is good ... but not always easy to understand.
Good luck!
Old 04-27-2012, 02:58 PM   #2869
Brainflex
Oddometer: 50
http://www.youtube.com/watch?v=QJciyJRJh8Q
http://www.youtube.com/watch?v=Hppcq...eature=related
Brainflex is offline   Reply With Quote
Old 04-27-2012, 11:20 PM   #2870
bonzodg
24/7 B-road hooner
Oddometer: 97
Nice one,Brainflex - wish I'd flexed MY brain and checked youtube!
Liking this video Nathan,same message,different 'language' -
whichever gets the message across clearly to you,eh?
Cheers
Old 04-28-2012, 02:44 AM   #2871
nathanthepostman OP
Oddometer: 610
I got it I got it!!
...if both valves are wiggly then you're on the compression stroke; adjust clearance accordingly.
A bit slack first time, but just re-done and it seems I'm about there. The nuance of 1/8 turn really does make a difference.
Now, as they say in India; full power 24 hour!
Cheers for all the help guys.
Old 04-28-2012, 06:03 AM   #2872
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,781
So whats the next big adventure?
Mr. Fisherman is offline   Reply With Quote
Old 05-01-2012, 09:52 PM   #2873
platypus121
CT.110 NZ
platypus121's Avatar
Oddometer: 106
Could it be something like this ....?
http://www.youtube.com/watch?v=xDOOT-T2gKo
The URL even has DOT in it.
Cheers,
Bernard
BigZoner #096 (English Chapter)
"Keep brotherhood till die"
platypus121 is offline   Reply With Quote
Old 05-02-2012, 01:00 AM   #2874
RDT953
RDT953's Avatar
Oddometer: 282
Funny stuff
Cheers,
Bernard
Laughed out loud, and I ride a BMW haha
I'm lost, I've gone to look for myself, if I should return before I get back, have me wait.
RDT953 is offline   Reply With Quote
Old 05-02-2012, 03:51 AM   #2875
nathanthepostman OP
Oddometer: 610
Haha, that's awesome.
Good old Ed. He'll do it no problems.
Old 05-02-2012, 06:59 AM   #2876
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,768
I got it I got it!!
No nessesarily. TDC comes up twice per combustion cycle. Ergo the valve tappets will get wiggly twice.
To be sure you're on the right stroke place your finger on the exhaust tappet. When you feel it go down and return , stop at TDC and adjust the valves.
Good wrenching to you.
Old 05-02-2012, 04:38 PM   #2877
platypus121
CT.110 NZ
Oddometer: 106
Bad advice !
Nathan had it right.
At the top of the "wrong" TDC (end of the exhaust stroke), the exhaust valve will still be open a little.
So no wiggle of the exhaust rocker arm at this TDC.
It is only at the TDC at the end of the compression stroke that both rocker arms have free play and this is the point at which they should be adjusted.
PS
It's hard to get the motor to stop at exactly TDC - it wants to move one way or 'tuther, but there's no need to be to paranoid about getting the
absolute TDC point (other than getting the correct one, that is). The rockers will have no pressure on them from the cam for a few degrees before and
after TDC so there's a bit of leeway with the setting point.
Cheers,
Bernard
Old 06-06-2012, 12:06 PM   #2878
rthuey
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,826
More than one million views
Out of an estimated 20,000 threads (40 per line x 500 pages) Yes i see that there are 733 pages, a bunch seem to have been moved.
There are currently only 11 Ride Report threads that can claim the additional fame of being members of the 1 million + views club.
Glen is way closer to his 3 millionth view than the 1 mark.
Doug is here twice...looks like your dirtster is a bit more popular than the panhead.
Clayton appears to engage his readers so much in his stories that they are to mesmerized to reply.
Would be great if the mods could let us know how many subscribers each of them have.
Thread Title - Start Date n Time - Replies - Views
Striking Viking bumming the world (On the road again) 05-12-2004, 01:43 AM 7,022 2,988,422
Quit my job to go on a "little" ride....US Tour '07 02-11-2007, 12:42 AM 5,363 1,837,533
Seattle to Argentina on a KLR650 05-07-2006, 05:01 PM 1,264 1,610,653
The BAM Road - ultimate test of man and machine 12-14-2009, 08:00 AM 1,646 1,538,485
Can a Harley make it to Magadan? 04-27-2011, 03:04 PM 2,490 1,441,766
The Mobius Trip 05-23-2008, 06:33 PM 4,880 1,367,401
From Estonia with love (Round the World awesome ADVenture!!) 06-30-2009, 11:05 AM 2,559 1,318,875
Angola, it's not like they said. 09-23-2007, 03:40 AM 1,175 1,237,584
Sydney to London on a105cc Honda callled Dot 05-04-2009, 07:47 AM 2,878 1,204,865
Siberian Extreme 2010 - Back for More 07-21-2010, 08:27 AM 1,820 1,076,804
The WRONG Way Round.... on a Chopper! 05-07-2009, 07:26 PM 1,583 1,067,433
We're gonna go ridin!!!
rthuey is offline   Reply With Quote
Old 06-10-2012, 02:46 PM   #2879
MaverickAus
MaverickAus's Avatar
Oddometer: 942
Hi Nathan,
nice to meet you in Ballina, hope you enjoy Byron Bay and your trip home hope it isn't too wet (like it is here).
Cheers
Garry
1999 KDX 200, 1996 KLR 250, 2006 KLX 331 R , 2006 CT110X, 2012 Versys, 2001 ZRX 1200 R
MaverickAus is offline   Reply With Quote
Old 06-11-2012, 06:29 AM   #2880
kwakbiker
kwakbiker's Avatar
Oddometer: 645
hey, that footwear isnt converse
2007 Versys
More fun being upright
kwakbiker is offline   Reply With Quote
Times are GMT -7.   It's 11:40 PM.
