10-09-2012, 03:41 PM
#541 |
...soon or later
Oddometer: 589
![]() ![]() ![]() ![]() ![]() Very impressed! Nic
Explore Alps Off Road: www.over2000riders.com Road 2012 Ducati Multistrada 1200 2008 KTM LC8 ADV 2010 KTM 690R Trips:Europe,Africa,Asia |
10-09-2012, 04:19 PM
#542 | |
on an endless build
Oddometer: 1,215
Gregor
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks |
10-10-2012, 12:23 PM
#543 |
Slack Jaw Gaper
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 757
With the stacks config sorted out, will they now be integrated into a unified airbox/filter design? Are you satisfied with your exhaust or will there be some variations on the flange/inlet diameters with the use of inserts. I wonder if some cosworth "D" profiled exhaust inserts would speed up the exit flow?
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good! justin@giantloopmoto.com www.giantloopmoto.com |
10-10-2012, 04:05 PM
#544 | |
on an endless build
Oddometer: 1,215
As for my exhaust - no, I'm pretty happy. I came out the big torque winner on the dyno (hear that Flanny?) and if there's a change to make it will most likely be on the intake side. Well, that and certainly I'll remake the H pipe to be neater and better. My quick version was not my best work but did pass the test. For me I'll test out a set of 41's and see how it effects my midrange compared to the top end. I suspect that the roll off I'm getting is due to the smaller size of the carb. I might actually try to get tricky and taper bore them but then again I might not. Seeing as it's getting cold and the my chances for riding the bike home are slim I'll just sort it out a bit until I move my shop. Right now I'm excited to have Chris on board to help solve the nagging problems of the FCR's so my bike is going to be a mule for the next while. Gregor
10-10-2012, 08:34 PM
#545 |
Oddometer: 4,295
With the exhaust have you thought about doing a 2-1-2
I've been doing alot of research to see if the advantages of a 2-1 can be kept using twin mufflers. There isnt a lot of info out there on it but from what i can gather if you create a propper merge colector you can then split it again to the two mufflers and still keep the pulling efect of the 2-1 What I couldnt figure out is how short the pipe after the merge colector can be before it can be split again. Would sure love a dyno to be able to test these things. |
10-10-2012, 10:22 PM
#546 | |
Oddometer: 2,175
10-10-2012, 10:42 PM
#547 |
on an endless build
Oddometer: 1,215
The exhaust I made really wasn't much different than stock except in layout which was minor. My system used a heavier gauge stainless over the stock system's thin gauge plated steel. I did that because I went through two front headers and three rear headers - the stock system is just not very hardy which can be seen by the fact that Flanny's rear header cracked as well.
Anyway, I had seen and wanted to try an "X" pipe crossover positioned where the stock system's crossover was. I made a nice one and when things weren't working I began to suspect it might be a problem. I thought the tubing I was using was a bit larger but I failed to take into account the thickness of the 16ga stainless compared to the stock tube and in the end it was only barely larger. My problems were a header flange leak and the TPS not being set. Anyway, the X pipe was fine - didn't hurt much. Replacing it with two separate pipes (2 into 2) completely killed the top end - it knocked something like 5hp off. I made an H pipe and tried that and it made a very clean 1hp gain over the entire range. It was the same with torque. It's not much but the point of testing and tuning was to find improvements so I'm now using the H pipe. The more I read on the subject the more that it seems that an H type crossover is favored over an X pipe type crossover. DrJoe; I didn't really consider a 2 into 1 into 2 because of space. I know Ned got good torque gains from his 2 into 1 but I really love the look of the twin pipes and I don't think there's much room but it might be worth an experiment. One I don't think I'm interested in doing. ![]() Here's a little tidbit for all you though. Both Flanny and I made runs pulling our dB killers thinking it might just be worth a small gain to piss off our neighbors but it turns out that the dB killers did absolutely nothing to the power or the torque. Zilch, zip, nada. We thought we'd see something somewhere but there was absolutely no advantage to pulling them so we both put them back in. Gregor
10-11-2012, 12:15 AM
#548 |
Oddometer: 4,295
Thats interesting about the db killers but i supose that with the two mufflers they would never be close to restricting the pipe maybe if it was just one muufler it would be a different story.
I realy want to do a 2-1 but the owner of the bike i'm doing the exhaust for likesthe twin mufflers and so do I. Some how i need to work out a 2-1-2 but like you pointed out the space realy doesnt allow it so some creative plumbing is in order. |
10-11-2012, 03:45 AM
#549 | |
V-Twin
Oddometer: 261
But anyway nice job/post
'10 990SMT |
10-11-2012, 03:10 PM
#550 | |
Oddometer: 2,238
![]() So, Gregor, please just confirm that you are happy with the engine I sold you? That's been playing on my mind for 18 months now!! ![]() Nice report, thoroughly enjoyed reading through it. Now, got any advice on getting a bit more tensile strength out of a recovering metatarsal 5 to increase capability under increased bending force?
Pyn 2013 Dakar swag available here, your support is hugely appreciated: http://www.lyndonposkittracing.com/support-lyndon/support-packages/ Please visit my web-site / blog www.lyndonposkittracing.com You can also look me up on Facebook or Twitter. |
10-11-2012, 07:00 PM
#551 |
I hate sand.......
Oddometer: 1,110
When I started this whole velocity stack project I proposed it to Chris as something he might be able to sell if it worked out. Well it certainly has worked out. Chris will rework the stacks for clearance (it was tight on Flanny's bike) and finalize the design and I've suggested that he also try to address the numerous other issues that people have with the FCR's like the lack of a choke, the lack of a TPS bracket and the heavy spring. Chris is going to keep my bike to work on these things and once he's figured out a fair price he's going to set up a site and go into production. I'll help him out (he's helped me for sure) and he'll get a thread going in the vendor's section and I'll link to it when he's ready. He might even look into becoming a Sudco distributor and just offer a complete turnkey package which would be nice. The FCR's have some amazing promise but they need a lot of help to be their best. I'll keep you posted.
A turn key package would be great - all jetted up and ready to go. A product that has actually been tested and has the proof to back it up. Well done guys for sticking it out..
Pete ![]() For those who sit at home and dream - let them... Meoni 03 950 Adventure RR - aux tanks and other bling http://www.advrider.com/forums/showthread.php?t=611461 |
10-11-2012, 07:25 PM
#552 |
Fast and Far
Oddometer: 6,879
Impressive as always
www.GravelTravel.ca Canadas Source For Overland Routes Tales From The Bivouac Rally Print Publications TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada |
10-11-2012, 07:35 PM
#553 |
on an endless build
Oddometer: 1,215
Hi Pyn!
Before Chris decided to become a mechanical engineer he specialized his studies in prosthetics and biomechanical stuff. Once he's done working on the FCR project you're more than welcome to see if he can work on your leg. But yeah, the engine seems to be working pretty well. I know a lot of you with FI engines want to see a more "fair" comparison so you'll be happy to know that Gino has already ordered a new CPR air intake and when he's got it we'll fit it up. I'm sure a tweaked FI system can be made to run much better and Gino is very interested in getting his tweaked so we'll do another comparison. I think the interesting thing about it was that a set of FCR's have the potential to offer a carbureted 950 a new lease on life and even give some advantages over a stock FI bike (which is supposed to have a 15 horse advantage in the case of the R). My goal was was to improve my normally aspirated engine and it worked out really well. On the dyno the difference was immediately apparent so I'm looking forward to hearing what Flanny thought on his ride back. Umm, Flanny? Maybe he decided not to stop? Gregor
10-11-2012, 08:23 PM
#554 |
on an endless build
Oddometer: 1,215
Hey man, when are we getting you back in the saddle? Funny story: I ran into your exhaust at the Bend rally. The Flanny/Deadly (deadly Flanny?) legacy lives on.
G
10-11-2012, 08:41 PM
#555 |
Slabbing it
Oddometer: 784
I wonder how the formula found in this article works out with the height of the stacks and extensions that you found to work the best.
http://www.hotrod.com/techarticles/e...e/viewall.html "...N x L = 84,000, where N represents the desired engine rpm to tune for and L is the length in inches from the opening of the ram tube to the valve head..."
49 Hudson - 72 Yamaha - 74 Caravelle - 00 Honda - 03 Chevy - 07 KTM
