06-08-2011, 08:17 AM
#121 |
on an endless build
Oddometer: 1,209
I've since updated this method to not include the SealAll - my experience was that it was too hard and brittle and spoke flexing made small voids which gave leaks. The GOOP however works fantastic and so I'd just say use that by itself and skip the SealAll but do at least 2 coats and three is better. Gino did his wheels on his 950 and they're holding fine and mine have been great too.
Don't expect it to be perfect right out of the box. Chances are you'll need to mount the tire and check for leaks and mark those spokes that leak. Remove and reseal those nipples and you should be done. Once it's air tight you don't need to worry about it again. Gregor
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks |
06-08-2011, 08:28 AM
#122 |
especie en extincion ®
http://www.akapol.com.ar/
fastix alta temperatura sera buen resultado? fastix high temperature good result? saludos |
06-08-2011, 08:45 AM
#123 | |
on an endless build
Oddometer: 1,209
Gregor
06-08-2011, 09:01 AM
#124 | |
Orange Caveman
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,098
Have you had any trouble losing the seal after tightening the spokes?
![]() -cp DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt. |
06-08-2011, 09:03 AM
#125 |
06-08-2011, 09:20 AM
#126 | |
on an endless build
Oddometer: 1,209
I'd also say that for pure dirt wheels I don't recommend it. My 18/21 set runs tubes as the rims are too narrow and lack the appropriate bead to hold a tubeless tire. Flanny runs the tubeliss system and likes that so maybe he can weigh in. Gregor PS - love your location CP. Had to look it up.
06-08-2011, 11:32 AM
#127 | |
Totally Normal? I'm not!
Oddometer: 1,027
I did the same method ( Seal All + Goop) about two months ago on my bike and had the same doubts about the bubbles. But it turned out to be OK and the rim was sealed properly on the first try.
SS. '98 BMW F650 / '05 KTM 450EXC / '03 KTM 950 Adv Caracas, Venezuela |
06-10-2011, 09:52 AM
#128 | |
Flanny-it-up!
For my 19/17 street wheels, I use the silicone method, but will do the goop next time. Flanny
Flanny Flanny-it-up!...Check out the FlannyMedia Web Site and Blog at www.FlannyMedia.Com
06-11-2011, 03:13 AM
#129 |
Fast and Far
Oddometer: 6,814
So that was what was going on Flanny....I was stuck behind you and trying to pass because you were riding so damn slow. Then I realized you were being held up by Gregor, I was going so fast you probably didn't notice me flying by Gregor on the other side as you were passing him...the classic double pass. Ah well, we all ride differently and not everyone enjoys speed
www.GravelTravel.ca Canadas Source For Overland Routes Tales From The Bivouac Rally Print Publications TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada |
06-12-2011, 09:30 PM
#130 |
on an endless build
Oddometer: 1,209
So I've been spending a lot of time tooling my workshop space and so oddly enough I haven't worked on bikes all winter as I've been preparing to work on bikes all winter. It's sorta messed up really. We like to joke at the shop that we're so into motorcycles that we don't even ride them anymore. There's some sad truth to that as building takes away from riding when you have limited time.
Anyway. Some crazy Italian came by the shop today and helped motivate me to pull the engine instead of assembling the cold saw. Gino and I set to work, iPad on the lift (shop manual) and this time I bagged the assemblies and marked them. Airbox off: ![]() Electrics, exhaust and oil lines off: ![]() ![]() Tommy came by to borrow an XR100 to teach his girlfriend to ride and we roped him into helping us pull the engine: ![]() Success! Even clowns can work on these bikes! ![]() There was a lot of metal shavings in the oil that looked like aluminum - hard to say yet what was the final demise of the lump but I'm not sheading a tear. I've gotten a lot of good hard miles from it and it's time for a fresh engine. ![]() One of the really depressing things about doing such a big tear down is finding out how filthy the bike is - there's dirt everywhere; the frame, the wires, the clamps, inside the connectors and then, on top of that, there's rusted fasteners. Ugh. I hate rust. It's going to take a solid day of hard scrubbing to get the bike clean again. I'm going to try to do that Tuesday between jobs. One thing I wanted to see was the intake ports and this encouraged me greatly. Seriously, I'm so excited about what I found. Stock 2004 950 intake port: ![]() Stock 2009 990 SMR port: ![]() That is a massive difference in port size and shape. I'm starting to believe that there's going to be a decent hp difference between the two bikes. Flanny? Do you see that? Just checking! The other thing I decided was that I really want this bike to be "new" to me when I'm done. It's going to be the bike that I'm taking to Portland to explore and since I can't buy a new bike I want to make this one new. I don't have a lot of time to do it but I'm going to try. So, James Renazco hooked me up with these super cool Leo Vince shorty carbon exhausts last year and I was going to use them on my Hypermotard which was stolen. Since I can't get that bike back I've decided to let my 950... er, my 990, become what I was hoping my Hyper would. Namely, a very stripped down and purposefully butch and nasty bike. Since the pipes are short I'm going to shorten the tail of my bike. Here's the new cannisters: ![]() I'm trying to decide if I angle them steeply up like this or tuck them in like stock but much shorter so they barely poke out. I've stripped off the tail light and signals - you won't see them again. In fact, that little fender is almost all I want back there. I've also decided that I really hate all panniers for this bike. The racks ruin the lines and the bike looks like a fat bag lady when they're on. I have two ideas that I'd like to do but I don't have the time right now but one is a monocoque subframe gas tank and the other is to design and make my own panniers and finally do it right. I can promise I will make the best looking panniers ever for a 990. Oh, and paint. My graphics are peeling off, the body panels are all scratched and worn and you can't make the bike new without some fancy new custom paint. If this bike is coming to Portland with me it needs to be painted before it goes while I still have the paint booth. Suggestions? I'm thinking about silver and orange. Was thinking white but I want more bling. More zazz. Yeah, zazz. Alright, that's it for tonight. Gregor
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks sakurama screwed with this post 09-19-2012 at 12:09 PM |
06-13-2011, 01:53 AM
#131 |
Needs to ride!
Oddometer: 2,065
Don't let Geek see those pipes, he might go into cardiac arrest.
Go man, go! Fun fun.
WHHHAAAAT!?!?! ![]() 5 Star RR: VIOLA-TING AMERICA - Chasing the dream of music and motos |
06-13-2011, 02:25 AM
#132 |
Oddometer: 270
Man, this build is epic, can't wait to see the result!
2009 KTM 990 adventure 2005 Triumph Thruxton |
06-13-2011, 02:42 AM
#133 |
Flanny-it-up!
All I can see in this post is an ugly Italiano...
06-14-2011, 04:35 AM
#134 |
Arrogant Horse's Ass #1
Oddometer: 36,513
Sweet, I should have bought a 990 motor from Pyndon too.
The motors are easy to get out! Good luck with the mods. |
06-22-2011, 08:05 PM
#135 |
on an endless build
Oddometer: 1,209
Not much more to report but I'm trying to keep this alive as I need to get this bike back on the road and I have a whole lot going on in my life that is working against me finding the time. These are the times I'm so envious of people with garages who can spend an hour here or there. It takes me an hour to get to my shop sometimes (especially now that I have no bike). I may put the supermoto wheels on my Husaberg but I really don't want another bike stolen - that's getting really old now.
Anyway. I got a little time to work on the bike and right now that just means cleaning it. I removed the bodywork before I brought it in and took it to a carwash but as anyone here who's ridden their bikes off road knows the dirt gets everywhere. I take each assembly down the hall to the slop sink and scrub it down with degreaser and a paintbrush (one of the best bike cleaning tools out there). After degreaser it's soap and water and then I use Pledge to help bring back a shine in the powder coat. ![]() I sat at the lift and wiped down the wiring harness and the frame too. Basically it's clean from the head tube back right now. ![]() I am compiling a parts list of stuff to order from Munn too. I also ordered a new chain and sprockets from KTM Twins and then navigated to the page with the Keihin flatslides and selected 39mm and then sat there for a good 10 or 15 minutes debating if I should click "Add To My Cart". And then I clicked it. ![]() ![]() Well, there you go. They claim they're backordered until the end of the month and as long as that means this month it should work out. The carbs are sort of a way to kick my ass into making sure I do the pipes. The pipes are a way of kicking my ass into doing the paint. I'm making a lot of work for myself and I it will be hard to finish but I have to do it so I'm going all in. G
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks sakurama screwed with this post 09-19-2012 at 12:10 PM |
