Old 05-07-2009, 12:35 PM   #16
sidestand
bristol, uk.
sidestand's Avatar
Oddometer: 273
07 990S, 12000mile pump failed, start up from cold, ride 30 sec to fuel pumps , fueled up, started her up, into gear clutch out started to roll, stopped dead . pump replaced under warranty. no probs since or before this.
sidestand is offline   Reply With Quote
Old 05-07-2009, 12:41 PM   #17
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 12,493
Nov 07 990 - NO problems at all.
Have not cleaned or replaced the filters yet
All with Mexican red gas (some ocassional visits to Texas)
KTM 990 ADV 07 Member #68,893
Fishkens: Holy shit! Look at that little lizard. It's the Jesus Christ lizard...... Honey Badger don't give a shit.
Ashamed member: I've been around oceans most of my life, and I honestly have never seen a Black man fishing.
Venteuri is offline   Reply With Quote
Old 05-07-2009, 12:54 PM   #18
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,575
Originally Posted by Taurkon
YES. Around 3500 km and mine died.
New one replaced on warranty, and I am now at 10500 km and beginning to wonder if the new one is bummed! Bike is sputtering, popping, stalls at idle once warm, and sometimes is only running on a single cylinder. Thing is, it does not happen all the time. Dealer can't find the problem... plugs are good, diagnostics comes up clean. I've run a few containers of injection cleaner through, and no luck. Starting to think it may be the pump.
a question for you and the others whose fuel pumps were replaced under warranty.
did u guys check with the dealer about the reason & nature of failure on the pumps ? are you sure it was the fuel pump or just the fuel filters ?
'07 KTM Adv990S
No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire..
950Rally picture thread
Vicks is offline   Reply With Quote
Old 05-07-2009, 02:37 PM   #19
sidestand
bristol, uk.
sidestand's Avatar
Oddometer: 273
They showed me the pump looked very new and clean [ including the large external sock filter]. They were sending it back to ktm as at that time, they knew of not one other failure. i'm sure he would have tested it though to make sure it was the pump and not just the filters.[ he's a very good bike mechanic]
If my pump would have failed Now, looking at the pics on this fourm, i would have ripped it a part for a closer inspection.
Old 05-07-2009, 03:06 PM   #20
duct tape
Lost
Oddometer: 387
Originally Posted by Gimme 2
For the record i have a 990 adv s 07 purchased in late 08 and yes the pump packed it in.
The bike had aprox 2500 k's on the clock.
Seems like you answered less than 50% of your own questions.....
950 SE
300 XC-W
Trails Preservation Alliance www.coloradotpa.org
Colorado OHV Coalition www.cohvco.org
duct tape is offline   Reply With Quote
Old 05-07-2009, 03:09 PM   #21
alphajory
alphajory's Avatar
Oddometer: 583
no problems
alphajory is offline   Reply With Quote
Old 05-07-2009, 03:14 PM   #22
Taurkon
Taurkon's Avatar
Oddometer: 567
Dealer stated: Faulty fuel pump.
I am dead positive it was the pump. I just left the tarmac and had stopped for a moment, turning the bike off. Tried to get it started again and zippo. I disconnected the fuel line and turned the bike over, and no fuel was being pumped through the line.
Taurkon is offline   Reply With Quote
Old 05-07-2009, 03:23 PM   #23
killurtv
free range moron
killurtv's Avatar
Oddometer: 605
13500 miles on an 07 990- not a single problem.
one day I will learn, until that day... fuck it.
2007 990 ADVENTURE
killurtv is online now   Reply With Quote
Old 05-07-2009, 06:00 PM   #24
azkiwi
message in a bottle
azkiwi's Avatar
Oddometer: 8,745
Originally Posted by stimmer6253472
10,000 miles and no issues at all with the bike.
+1
I think another question you should ask is how often you run the bike really low on gas. I live near a lot of gas stops and so I rarely go 5-10 miles past when the reserve light comes on.
I've run it pretty low a few times, I usually run it down to the last ½ gallon. FWIW I make a point of filling up with Chevron.
azkiwi is offline   Reply With Quote
Old 05-07-2009, 10:02 PM   #25
jnyrav
jnyrav's Avatar
Oddometer: 334
16,000 miles, no problems with the fuel pump...
jnyrav is offline   Reply With Quote
Old 05-08-2009, 01:02 AM   #26
AUS CRUZER
Lets Cruz
AUS CRUZER's Avatar
Oddometer: 2,409
NO @ 15000km
AUS CRUZER is offline   Reply With Quote
Old 05-08-2009, 01:10 AM   #27
Gimme 2 OP
Team slo ass
Gimme 2's Avatar
Oddometer: 1,664
Yep i did ask and he said the psi of the unit was running too low .
it's only now after reading some post on this site latley i realise there might be some fauty pumps out there thats what im trying to find out to see if im just the unlucky bastard or if there's a common thread to it all.
Give it WOT.
Gimme 2 screwed with this post 05-08-2009 at 01:30 AM
Gimme 2 is offline   Reply With Quote
Old 05-08-2009, 01:37 AM   #28
Gimme 2 OP
Team slo ass
Gimme 2's Avatar
Oddometer: 1,664
STATS SO FAR, 4 bikes out of the 21 that have put their hand up have had a fuel pump issue HANG ON NEW STATS COMING IN, ................yes i am bored
Give it WOT.
Old 05-08-2009, 02:30 AM   #29
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,575
fair enough.
However, for the information of all concerned, please note that disconnecting the fuel line and turning the bike over is not the right test to check the healthiness of the fuel pump.
The quick disconnector is not so simple as you are expecting. There is a valve in there which opens only when the male & female sides of the disconnector have "mated". Once the disconnector is taken apart, the valve closes and fuel does not flow anymore into either sides.
If you look inside the disconnector, you will find a white colored valve. Now try to blow into this and you wont be able to. If you press the white colored valve and then blow, air will pass thru.
I found this when i dismantled the fuel pump on my 990 yesterday.
'07 KTM Adv990S
Old 05-08-2009, 02:51 AM   #30
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,575
here is a pic of the above said valve (see white plastic object insode the disconnector.....
'07 KTM Adv990S
Times are GMT -7.   It's 11:16 AM.
