Old 05-08-2009, 03:24 AM   #31
Taurkon
Taurkon's Avatar
Oddometer: 782
Originally Posted by Mr.Vicks
fair enough.
However, for the information of all concerned, please note that disconnecting the fuel line and turning the bike over is not the right test to check the healthiness of the fuel pump.
The quick disconnector is not so simple as you are expecting. There is a valve in there which opens only when the male & female sides of the disconnector have "mated". Once the disconnector is taken apart, the valve closes and fuel does not flow anymore into either sides.
If you look inside the disconnector, you will find a white colored valve. Now try to blow into this and you wont be able to. If you press the white colored valve and then blow, air will pass thru.
I found this when i dismantled the fuel pump on my 990 yesterday.
Good information to know. Thanks. So, even though my test was not valid, the dealer still confirmed my problem and the new pump set me on my way... until recently.
Taurkon is offline   Reply With Quote
Old 05-09-2009, 04:06 AM   #32
Bonkers the Dog
Ned Catcher
Oddometer: 175
Mine packed up 2 weeks ago.
18K mls, 06 ADV 990.
No warning.
Suspected contaminated fuel.
£270 replacement on top of a £450 service!
Not amused.
Bonkers the Dog is offline   Reply With Quote
Old 05-09-2009, 09:05 AM   #33
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
07 I got a fuel pump? 11K.
tahoeacr is offline   Reply With Quote
Old 05-09-2009, 06:54 PM   #34
tumbler45
tumbler
Oddometer: 100
I finally replaced my fuel pump at 31,000 miles (it is a 2007 990 Adv)
I started having an issue at 20k. When the fuel was low (under 1 gal left) and only under hard braking or acceration the bike would stall. I still have no idea why. I delt with it for a while and tried to keep the tanks fuller.
At about 25,000 miles I filled up one day and 15 minutes later I noticed the bike not running quite right. I did a couple hard accerations and under a heavy load the bike just fell on its face. The problem got worse and worse, 40 minutes later I could just keep up with traffic.
I made it home and pulled the pump. The filters were brown, but did not seem to have any restriction. Teed in a fuel pressure gauge to confim the problem.
The bike ran perfect and the stalling problem under braking went away!
I ran the bike for 4000 miles with the gauge and never had a problem. I removed the gauge and everything was fine for the next 1000 miles. Still haven't figured that out.
At about 30,000 miles I was out on a trip and the bike started acting up out of nowhere. Same problem, idled fine but faltered under a load. The problem came and went, but it seemed to be heat related, when I put fresh gas in it seemed to do better. Made it home and ordered a fuel pump assembly. Only 1 ride on the new pump but so far so good.
I still don't know if it was just a filter problem or a pump problem. I did have 30,000 miles including 10,000 in Mexico. It was weird how intermittent the problem was. I decided to replace the pump, even if it was just the filters, I have put the pump through a lot of abuse and I don't want to get stuck.
tumbler45 is offline   Reply With Quote
Old 05-10-2009, 09:31 PM   #35
offroute
Oddometer: 357
2007 990 Adventure @ 19,000 miles. Lots of dirt. Mexico. No problem so far.
2007 KTM 990 Adventure
2008 KTM 450 EXC-R
2005 Honda Elite (just because)
If we don't change direction soon, we'll end up where we're going.
offroute is offline   Reply With Quote
Old 05-11-2009, 02:42 AM   #36
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,173
Thats eerrrr good to hear there mate, so no probs then?
Gimme 2 is offline   Reply With Quote
Old 05-11-2009, 04:39 AM   #37
d.t vet
v2
Oddometer: 223
06,990s,55000km no problem with the pump,didnt know there are filters to clean.
hope it stays this way
d.t vet is offline   Reply With Quote
Old 05-12-2009, 10:22 AM   #38
dezracer
dezracer's Avatar
Oddometer: 642
Mine went at 2,500 miles, Starting running with low power for about 10 miles, then fell on its face and took the main fuse with it. Had to be towed out of the woods by a 4-wheeler. Hope this new one lasts little longer than that.
2007 990 Adventure
Suspension by Super Plush
Rekluse Pro Auto Clutch
WINGS N.O.S Exhaust
Euro Headlight with PIAA bulbs
KTM Hard Parts Radiator Cover
CJ Racer Clear Spoke Clutch Cover
Hilslamer Long Pegs
GPR Stabilizer
DH Racing tripleclamps
'300' Throttle Cam
16t CS Sprocket
Mefo "Super Explorers"
Ram Mount Garmin 76c
PABIKER sidestand relocaton kit.
2007 KTM 300XC (long live lightweight 2-strokes)
Las Vegas, NV and the Great Mojave Desert
dezracer is offline   Reply With Quote
Old 05-16-2009, 10:29 PM   #39
Heatwave
Obsessive-Compulsive
Heatwave's Avatar
Oddometer: 86
07 Superduke
First big trip on my 07 Duke purchased in January. 2,485 miles and the bike died. My dealer suggested cleaning the tea bag filter, but no joy. After pulling the pump motor out we determined it was seized. KTM of Grand Junction swapped me mine for the one in their demo so I could get home. I can't thank them enough.
"It's always nice to be the center of controversy" - Pop
Heatwave is offline   Reply With Quote
Old 05-17-2009, 07:50 AM   #40
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,348
'08 990 with 16,000 miles, stock fuel pump still going strong.
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 05-17-2009, 08:34 AM   #41
Juan Loboe
Juan Loboe's Avatar
Oddometer: 474
2007 990 Adv
About 8,400 miles and no problems.
My $ .02
Juan Loboe is offline   Reply With Quote
Old 05-17-2009, 09:07 AM   #42
dogsbody
Occasionally lucid
dogsbody's Avatar
Oddometer: 303
2007 990 - Used extensively in Outback Australia
Changed pump intake filter set at 28,000kms after experiencing surging under hard throttle.
Filter was dirty and tank had particulates in it. Rinsed tank out, fitted new filter and no problems since.
Filter was quite expensive. If I'd had access to an ultrasonic bath for cleaning it I think I could have reused the filter with no issues.
dogsbody
dogsbody is offline   Reply With Quote
Old 05-17-2009, 09:51 AM   #43
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,301
This is an interesting, and slightly disturbing thread.
I have about 10K on my 07 with no pump issues yet.
However, in light of this thread, it looks like I'm going to start carrying a spare pump and filters with me when I take off solo into the MOFN.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 05-17-2009, 10:01 AM   #44
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
'07 Adv., 15K miles, no probs, but now I'm wondering if I should order a kit...
Anybody have the recommended parts list for a roadside rebuild handy? Might be a good thing to have on this thread if a lot of ppl will be reading it.
viola-tor is offline   Reply With Quote
Old 05-17-2009, 10:06 AM   #45
crashmaster
ow, my balls!
Oddometer: 5,301
Check out this thread started by Mr. Vicks. http://advrider.com/forums/showthread.php?t=461827
very nice breakdown views of the whole fuel pump system for your parts ordering pleasure.
Times are GMT -7.   It's 11:15 PM.
