Old 10-19-2009, 04:43 PM   #76
minusone
minusone's Avatar
Oddometer: 1,292
My 06 990 has been giving problems which include starving of fuel at varying revs. Sometimes it would work for only 30 seconds and then die if I opened the throttle.
Most disconcerting when out in the wilderness.
My fix that seemed to work is to spray the contacts in the fuel pump plug/socket connector with WD40 and it would work perfectly for some hours then slowly deteriorate again. I will thoroughly clean this plug that is exposed to all the mud and water and see if I can fix it permanently.
I wonder if some of these fuel pump issues are related to dirty plug contacts.
minusone is offline   Reply With Quote
Old 10-19-2009, 06:27 PM   #77
empedrado
Oddometer: 365
If that is the case coat the contacts with dialectric grease. I had all kinds of contact problems with my old 640 Adv with dust and the like and that grease worked wonders.
empedrado is offline   Reply With Quote
Old 10-19-2009, 10:49 PM   #78
minusone
minusone's Avatar
Oddometer: 1,292
I intend to do that, however it seems I need to clean up some tarnished contacts first. Any ideas on something I can soak the plug/socket contacts in to clean them up properly? It is not easy to clean them manually.
Old 10-19-2009, 11:50 PM   #79
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
The contact pins & sockets can be removed using a fine screwdriver.
If you can't do this, a shot of brake cleaner will clear up the grease/gunk, an old toothbrush might help too.
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is offline   Reply With Quote
Old 10-20-2009, 11:35 AM   #80
sp4ce
Orange Invader
sp4ce's Avatar
Oddometer: 431
I use DeoxIT to clean, then apply dielectric grease. Seems to work pretty well.
sp4ce is offline   Reply With Quote
Old 10-20-2009, 03:20 PM   #81
Dusty
Dusty's Avatar
Oddometer: 1,269
good tip, thanks...
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 10-20-2009, 03:48 PM   #82
minusone
minusone's Avatar
Oddometer: 1,292
Yes thats what I was after thanks.
Old 10-23-2009, 03:09 PM   #83
RLCanon
Adventure Arrrrr!
RLCanon's Avatar
Oddometer: 368
Any progress on the external fuel pump/regulator front?
RLCanon is offline   Reply With Quote
Old 12-08-2009, 10:11 PM   #84
RLCanon
Adventure Arrrrr!
RLCanon's Avatar
Oddometer: 368
I just wanted to thank Mr.Vicks for the original post which was invaluable in demystifying disassembly of the fuel pump assembly. I bought a factory fuel pump (ouch!) so I can get my bike out of the hands of the dealer if they prove completely incapable of sorting it out, as well as to have a spare for solo trips to the boonies.
As far as the dealer sorting my fueling issues on warranty, I don't know what to think... First it was three full days to flash the ECU, now it's over a week to warranty the fuel filters. Dropped it off last Tuesday; called them this afternoon, Tuesday a week later, and no filters - no progress. I ordered the fuel pump toward the end of last week and even so I managed to get it before they got the filters, and they had a 3 day head start! WTF? I wait three days before I decide to order, then order from an internet dealer who tells me they have to order from KTM. They get it from KTM and still have to ship it to me, and I STILL get it before the local dealer doing the warranty work gets just the filters? I mean really; WTF?
Old 12-10-2009, 08:54 AM   #85
jeremyk
jeremyk's Avatar
Oddometer: 91
Flow Rate
Flow rate can be calculated by simply knowing the peak HP of the engine and the PSI at which the fuel system operates.
Flow rate cannot be calculated from fuel consumption while cruising, as this is not the maximum fuel flow that will be required at peak horsepower. I've done these calculations before when upgrading turbos on my Dodge Stealth back when I was a "kid".
Here's a calculator. It came up with 110 L/hr using some numbers I threw at it.
http://www.eastcoastrollingthunder.c...r/finject1.htm
Current Bikes:
2007 KTM Adventure 990 (new in fall 2009)
2002 Suzuki Hayabusa
1971 Yamaha R5
Previously Owned:
2002 Kawasaki KLR650
2001 Suzuki SV1000
2000 Suzuki SV650
2002 Suzuki GSX-R750
1994 Yamaha YZF-750R
1983 Yamah Seca 650 Turbo
1982 Kawasaki KZ550
1986 Suzuki DR200
1980 Honda XR100
jeremyk is offline   Reply With Quote
Old 03-04-2010, 08:39 AM   #86
Gluaisrothaí
Feckin' gobshite
Gluaisrothaí's Avatar
Oddometer: 547
3.6 Amps
I measured the current through the pump (at 12.3 V). It was 3.6 A. Make's it most likely to be a type D. I checked it before and after a filter change.
Glu.
Originally Posted by Vicks
Current draw for Type C is 5.0A @ 12VDC and for the Type D, it is 3.8A @ 12VDC.
Edit : Sorry, i thought you were asking for the current draw of the Type C & D pumps, and after re-reading your post, i understood that you were asking for the current draw of the stock pump. Let me try to do some measurements over this weekend and get the figures for you.
I can't believe that none of the inmates know the fuel flow & pressure ratings for the stock pump on the 990 . C'mon guys, we need yar help here ..... This info will be critical to finding the right model of keihin pump, one less problem.
2009 KTM 990 ADV
2006 DRZ400SM
1974 Aero Commander 112A (AC11/G)
2010 FJ Cruiser Trail Teams
2013 Tesla Model S 85kWh
Gluaisrothaí is offline   Reply With Quote
Old 03-07-2010, 12:51 PM   #87
jeremyk
jeremyk's Avatar
Oddometer: 91
We need to know (1) fuel injector size (flow rate), and (2) fuel pressure. With that info. we can correctly select a size for a replacement fuel pump. It's pretty straight forward stuff.
Old 03-07-2010, 03:06 PM   #88
bkshovel
Old Adventurer
bkshovel's Avatar
Oddometer: 115
If you can live with a externaly pump? Here's a thread that might interest you.
http://www.advrider.com/forums/showt...=422042&page=7
I didn't read the all the post to this sooo I hope I'm not interjecting something unwanted. These guys have it pretty much figured out.
bkshovel is offline   Reply With Quote
Old 03-08-2010, 12:36 AM   #89
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
Could you enlighten me pls
any information is good information !!!
I searched in OEM kalatogs and seems the filter assy includes the paper filter the teabag filter and some real cheap orings. Someone in here found them for 1,5$ each. So it seems we are charged for $90 for parts worth $25?
For comparison, Ducati filters go for 9€, bought by MAN, or 19€ by Ducatti.
gefr screwed with this post 05-17-2011 at 12:28 AM
Old 03-08-2010, 12:41 AM   #90
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
Got confused!
Originally Posted by crashmaster
O-Ring Type
For Straight Thread Tube Fittings
Cross Section Shape
Round
Width
.118"
Inside Diameter
2.337"
Outside Diameter
2.573"
Material
Viton® Fluoroelastomer
Shouldn't Inside Diameter + Width = Outside Diameter?
Times are GMT -7.   It's 11:48 AM.
