Old 07-05-2004, 02:12 PM   #1
upsman OP
Oddometer: 234
airhead problem need help please
long story short, riding my 78 R80/7 yesterday when it went down to one cylinder without warning. i have checked all the usual things , spark, fuel, timing, compression they all check out good but i still cant get it to run on the right hand cylinder, it backfires out the carb on this cylinder and wont clean out, the bike has a dyna 3 electric ignition and is otherwise stock.
any help or advice appreciated thanks greg
upsman is offline   Reply With Quote
Old 07-05-2004, 02:48 PM   #2
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,299
Have you checked the carb main jet for debris or inspected the carb diaphragm for tears?
Dyna coils have been know to fail but I haven't heard of their ignition module/booster failing for this vintage BMW.
Hope this helps.
Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 07-05-2004, 03:04 PM   #3
upsman OP
Oddometer: 234
airhead problem
yes we checked the carb and put on one from another bike and still nothing, thanks for the input thats what im looking for, we have tried everything and nothing made a bit of difference so far. thanks again greg
Old 07-05-2004, 08:40 PM   #4
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Couple things
Dynas have been known to blow a channel resulting in one side barfing like that. But also check the ring on the cam where the points used to be. That ring will sometimes slip and the timing will get fuxored.
dead
Chopperman is offline   Reply With Quote
Old 07-05-2004, 10:09 PM   #5
RockyRaccoon
Found:Gideon's Bible
RockyRaccoon's Avatar
Oddometer: 53,669
Have you determined whether it's getting spark? Take out the plug and hook it back up to the wire, make sure it's grounded and then turn it over and see if you can see a spark. Sometimes the spark plug wires and caps go bad.
RockyRaccoon is offline   Reply With Quote
Old 07-08-2004, 11:38 PM   #6
Cpt. Ron
aka Birdkilla
Cpt. Ron's Avatar
Oddometer: 2,351
Take the left plug wire and put in the right side, and vice-versa. See if the problem changes sides. If it doesn't, it's a fuel or compression issue. If it does, it's an ignition issue.
Fuel/compression problems: blocked main jet, torn diaphragm, broken throttle cable....
Ignition: worn out spark plug caps, old spark plugs, broken coil, bad connections....
Cpt. Ron
Sack-O-Tomato, CA
'05.5 950 Adventure S "Bad Mutha F@&ker"
'04 R1150RTP "cop motor, cop suspension.."
'00 XR650R Dual Sport "Lil' Mule"
'75 RL250
'01 TTR90
'01 PW50
Conti TKC80 tire swing
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 07-09-2004, 02:49 AM   #7
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,050
Remove right plug, tip a little fuel down the plug hole, re-fit the pug & cap etc & see if it fires up briefly on both cylinders.
If it does, then it may well be a carb blockage as mentioned previously.
If not, then probably ignition related.
Worth trying as there's no cost except 5 minutes of time.
Possu is offline   Reply With Quote
Old 07-10-2004, 03:41 PM   #8
storymitchell
Member of the proletariat
storymitchell's Avatar
Oddometer: 1,157
Lazy turd that I am, I simply shoot a bit of ether into the carb in question whilst cranking the starter. Same outcome, though, I suppose.
Non omnes qui habent quadrigae sunt auriga. - Anon
storymitchell is offline   Reply With Quote
Times are GMT -7.   It's 01:07 AM.
