Old 07-05-2004, 07:13 PM   #1
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 6,968
Airhead in distress...
I'm in Whistler, BC, and have just been approached by Molly...
...who has just ridden up from Seattle on her 93 R100R...
...and has lost a bolt from the left barrel of her engine...
It looks the same calibre as a spark plug - could a sparkplug be used as a 'get you home' solution - any suggestions?
She's also had her tent stolen - probably not her best week...
Mike
All text & original photos © Mike Oughton 2004 - 2015
MikeO is offline   Reply With Quote
Old 07-05-2004, 07:28 PM   #2
pilot
Slacker Moderator
pilot's Avatar
Oddometer: 31,697
Find someone to garage her bike and let her ride with you.
The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them.
-Furious D
Did you know that in men as we age the first hearing range to go is the one women’s voices fall into? There is a god and he wants us to be happy.
- Anon
pilot is offline   Reply With Quote
Old 07-05-2004, 07:35 PM   #3
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 6,968
A fix for her bike would be a good ice-breaker...
Mike
Old 07-05-2004, 07:55 PM   #4
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,336
It's a prety standard metric bolt. Try threading a spark plug but make certain that the threads are the same. Oh and put some copper anti-seize on it before you put it in...the bolt that is...
Check the opposite side and mak sure that it's tight too....Good I crack myself up....there I go again!
I think the bolt thread is the same as the final drive drain plug....I've got one in my garage....oh never mind, you figure it out!
Cheers,
Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 07-05-2004, 07:59 PM   #5
Davo
BMW Uber alles
Davo's Avatar
Oddometer: 142
Go to an auto parts store and find a sump plug that fits and remember to lock tight it. Suggest that it might be appropriate that you follow her around for a while to make sure the bike doesnt break down . She is a babe!
stone cold sober
Davo is offline   Reply With Quote
Old 07-05-2004, 08:28 PM   #6
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Isnt that for the secondary scavenging system used on later R's? I dont remember them doing away with it once it was in use. If they didnt do away with it, there is a whole lotta stuff missing.
At any rate, try metric sump plugs as has been suggested. If nothing fits, I bet you can epoxy a quarter over it. Or a loonie, as I guess the case may be. I could be wrong, but I dont think a whole assload of pressure goes through that hole.
dead
Chopperman is offline   Reply With Quote
Old 07-05-2004, 08:38 PM   #7
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,336
It does, combustion pressure, it's open to the combustion chamber. When that plug falls out...and they, are known to do that, it makes a nasty racket.
Once the clean air system parts are jetissoned this hole is usually capped with a final drive drain plug.
Cheers,
Jorge
HST-RIP
Cricket the Dog-RIP
Old 07-05-2004, 08:49 PM   #8
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
According to the parts list it looks like a 16 mm thread .. possibly a 1, 1.5 or 2 mm pitch (16 mm come in all three pitches, sorry) . Oh it has a copper gasket.
The final drive plug (for that bike) is a 14 mm with a 1.5 mm pitch.
You might be best removing the one in the other cyclinder to get the right size from a specialist bolt supplier. If it comes out easily. If not then the filler plug on the bevel drive is 14mm with a 1.5 pitch, if that fits fine, use a plastic bottle cap - should fill the filler hole to stop most of the leak. Use some sliastic to stop most all the leak. If it is too small then it is probably the 16mm size, check the pitch to see if it matches the 1.5 mm of the plug.
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 07-05-2004, 09:33 PM   #9
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Cheers,
Jorge
Ah so. I stand corrected. You should be able to find the plug readily. I bet a similarly sized plug is found on other BMWs, Guzzis, Urals and japanese or european cars.
dead
Old 07-05-2004, 10:40 PM   #10
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,986
Mike-
It is 16mm X 1.5 pitch. I still have the clean air plumbing parts that I removed from my 92 GS and I measured. As Frank suggested though, remove the other one and take it with you for a depth check. You're going to want to Loctite it anyway- Red Loctite.
The clean air systems are removed because all they do is burn up exhaust valves.
And of course, more pics. Molly's a beauty. Be sure to come away with her address so you can send her an ADVrider shirt.
"If you don't know where you're going, any road will get you there." -Henry Foster
Eurobiker is offline   Reply With Quote
Old 07-05-2004, 10:49 PM   #11
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,986
Better still, bring her to Ouray.
Old 07-05-2004, 11:11 PM   #12
walkingbear
walkingbear's Avatar
Oddometer: 3,544
plug
that is where the emission air tubes were located.
I will find out the pitch in the morning
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 07-06-2004, 03:42 AM   #13
PhilSpace
The Gov
PhilSpace's Avatar
Oddometer: 35,403
Here ya go
Crush Ring: BMW #07-11-9-963-252
Plug is an M16x1, 5 standard thread - hint - an Oilhead drain plug BMW #07-11-9-919-117
Did this on my old R65 and R100RT courtesy of the IBMWR tech pages.
Mike, give the supreme sacrifice, your own drain plug and maybe you will get lucky
PhilSpace is offline   Reply With Quote
Old 07-06-2004, 04:53 AM   #14
Rider
Moderator Emeritus
Rider's Avatar
Oddometer: 3,060
Hubba-hubba.
2012 FJR1300 - In Search Of Fast Sweepers
My Voice
Rider is offline   Reply With Quote
Old 07-06-2004, 06:51 AM   #15
PhilSpace
The Gov
PhilSpace's Avatar
Oddometer: 35,403
But at least she rides one!
Times are GMT -7.   It's 11:38 AM.
