Old 05-09-2009, 07:38 AM   #1
3bangin OP
2010 Tiger 1050
3bangin's Avatar
Oddometer: 234
Crap Scorpion
Wow, I hope it's just me that has an issue with my front Scorpion tire.(Head shake and bad) I've tried everything, tire pressure, suspension setting, dial indicating the front rim etc.
Did they make a bad batch? It would be nice to see how many people have an issue with the Scorpion Front on the KTM.
Bob
Ride Fast Ride Smart!
3bangin is offline   Reply With Quote
Old 05-09-2009, 07:43 AM   #2
DirtyADV
DirtyADV's Avatar
Oddometer: 2,189
No issues with a new tire but all have worn strange for me giving some shakes in the front end after a while even if a lot of pattern left, quite bad by the time the rear is worn out so i have exchanged them both at the same time.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 05-09-2009, 07:45 AM   #3
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,939
Bob
I remember reading about this in this thread by nevgriff http://www.advrider.com/forums/showthread.php?t=288891 he put a new tyre on the bike.
ciedema is offline   Reply With Quote
Old 05-09-2009, 07:47 AM   #4
RAW
stamen in the sniffer
RAW's Avatar
Oddometer: 3,838
You are not the only one.
The scorpion headshake is well-documented. I started a thread about it too.
No consensus on the cause.
Get $5 off of your smugmug signup!
Enter code: sA9I4bmgcofRU
RAW is offline   Reply With Quote
Old 05-09-2009, 07:51 AM   #5
3bangin OP
2010 Tiger 1050
3bangin's Avatar
Oddometer: 234
While riding and looking over the front end, it looks like a bent rim but no. I think the tires are slightly deformed.
Bob
Old 05-09-2009, 07:55 AM   #6
3bangin OP
2010 Tiger 1050
3bangin's Avatar
Oddometer: 234
Thanks for the replies guy's. It seems I'm the latest one to walk up and Kick a dead horse.
Has anyone here contacted Pirrelli?
Bob
Old 05-09-2009, 07:55 AM   #7
RAW
RAW's Avatar
Oddometer: 3,838
Yep, you can look down and watch it wobble.
It's ridiculous.
I've learned to deal with it for now.
I want to switch to a different front tire when this one is dead.
Unfortunately, I've got another Scorp in the garage from my early attempts to get rid of the wobble.
Old 05-09-2009, 07:56 AM   #8
RAW
RAW's Avatar
Oddometer: 3,838
Bob
I played phone tag with a rep for a few weeks. Finally got tired of trying.
Old 05-09-2009, 08:12 AM   #9
borderxx
ifalldown
Oddometer: 105
Pissed
Today I saw the first sunshine that I could USE - so I ran home at lunch, mounted the crashbars that just came in this morning', and geared up to head back to work. Now, understand that it rained all the way back from the dealership (I trucked it from Ohio), and it has rained all this week - I managed a 15-mph ride around the block on Tuesday night between bands of rain. I haven't ridden the bike above a high idle since I got it. So, I get up to about 30 mph, and the front end feels like I am on railroad tracks. Thump thump thump.
Wheel around to the estate, and check it out: Hans (the guy who was demoted from the clutch bolt-tightening position on the assembly line) is now mounting and inflating tires. Hans has FAILED TO SEAT THE BEAD ON THE FRONT TIRE. No problem, an easy fix, but WTF? Is Hans doing quality control as well now? QC at KTM missed it, and the dealer PDI as well?
Maybe check and make sure the tire is fully seated on the rim.
borderxx is offline   Reply With Quote
Old 05-09-2009, 08:14 AM   #10
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,698
I haven't had this problem
I've had 3 or 4 and no real problems. When I got the bike weights were one one side, changing that took away one shake problem. Low pressure did it a bit. Now I am running a trail wing 41 -so I no further data. The TW41 is a better match to the Scorp rear -and it's cheap
ridewestKTM is offline   Reply With Quote
Old 05-09-2009, 09:14 AM   #11
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,233
You can be lucky...or not. My first Scorp was part of the shitty batch. I put a Sahara, problem solved. Now I'm on my second Scorp and is great.
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 05-09-2009, 10:15 AM   #12
Tangai
Oddometer: 573
Yeah, they made a huge bad batch, a lot of 990s came with defective front tires, and there was no recall that I know of. I noticed the front tire on my 07 990s was bad on the way home from buying the bike, but I was already 200 miles away and in the mountains of southern Missouri. I noticed it when my butt started to hurt and I stood, and looked down at the tire. It had a low spot on the left side, as if it wasn’t popped out on the rim all the way. At the campground that evening, I inspected it—it was full inflated and popped out on the rim correctly.
The next day I tried to notice if it affected the handling, it did not—even in left hand corners, and I forgot about it. About a month later, I did notice that it wobbled some at a very slow speed. My buddy’s 08 990a has the same exact defect on his front tire. I’ve read others complaining about the same defect on this site. Now, 10,000 miles later, I just installed a new Scorpion AT, and it is perfect. Hopefully all the defected ones are used up and gone.
Tangai is offline   Reply With Quote
Old 05-09-2009, 10:25 AM   #13
Big Tall Bastard
Voice of Reason
Oddometer: 335
Silly question but did you get it balanced or rebalanced after some wear? My 990 Adv with the Scorps handled really well. Even my sportbike buddies were surprised how good they felt. I have looked over the bars and it doesn't look very true but feels ok. I think running a 21" dirtbike wheel with spokes that gets ridden in the dirt has a pretty good chance of getting out of round. I did get head shake after I put a TKC80 on the front but I expect that with a tractor tire like that.
Head shake can also come from not having your suspension set up properly. My CR500R would get head shake at high speed until Race Tech tuned it for my weight and riding style. After that no problem pinned in 5th!
My old 86 XR 600R had vicious headshake and I thought I was going to die several times as I didn't realize back then snapping the throttle shut was a bad idea. Moving the forks up in the triple clamp solved the problem on that bike.
I'm just sayin.....
Current rides: 07 Aprilia Tuono R, 87 XR600R (Hell Yeah!)
Some of bikes owned in the last few years: 2007 990 Adventure ,2001 Aprilia Mille RSV, 2000 XR 650 R, plated Sold (what a dumbass) 2001 CR500R, 2001 Cagiva Gran Canyon
Big Tall Bastard is offline   Reply With Quote
Old 05-09-2009, 10:32 AM   #14
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,233
I've had Brazilian Pirelli dual sport tires in the past (as far as ten years ago) and while they weren't defective as this Scorps, most of them were crappy tires, so this is a no-new at least for me. Brazilian Sahara's however are very very good tires.
And while front scorpions are CHEAP (...so you get what you pay for) and this could be a excuse for Pirelli, KTM should be paying more attention on what they drop on very expensive bike.
Jaime
Old 05-09-2009, 08:12 PM   #15
GPZ1170
Consumer Whore
GPZ1170's Avatar
Oddometer: 198
I have had 2 new front scorps in the last two years and another in the garage ready to be put on. Everyone I put on new shakes a little for about the first 600 miles or so. After that they seam to work themselves out. For the most part I am very happy and will continue to use them in the future.
GPZ1170 is offline   Reply With Quote
Times are GMT -7.   It's 08:08 AM.
