05-20-2009, 01:19 PM
#31 |
Oddometer: 179
[quote=t-rider]Nice edition, found online:
![]() Looks like it could be the older version. Those are said to need quite a lot gas, 7 or 8 l/100km, because of a too rich fuel/air ratio . There's an airbox modification to change this. Unfortunately, the instructions I found are German only: http://www.dernacken.de/anleitung_airbox.html or http://winweb373.sr23.firestorm.ch/twin500/cpg144/albums/userpics/10056/KLE500_Luftfiltertuning.pdf If anyone is interested and wants to try it, I can translate it. From 2005 on, the settings are better, my KLE takes only 5l/100km, maybe 6 when I go 140 km/h with panniers.
Hi! I'm a signature virus. Copy me to your .sig to help me spread. |
05-20-2009, 10:32 PM
#32 |
Oddometer: 963
http://www.horizonsunlimited.com/hub...oad-pics-39263
here we go, my old kle and there is a link in the forum for a lot more pics off the kle off road in case anyone was wondering if it is suitable. bought bike standard but if kept it would have put knobblies on it. still great lil bike and was well capable at everything could throw at it, or everything i could thew the bike at
women are like clouds....... once they fuck off it is a really nice day.......
05-21-2009, 04:04 AM
#33 |
Oddometer: 963
have a load of kle links if ye want and horizons unlimited has huge following of kle owners.
05-21-2009, 09:16 AM
#34 |
Oddometer: 24
Does anyone have any information about a tank enlargement or maybe an alternative for the small tank? Would like to have a bigger milage on one tank... Going to perform the airfilter box adjustment in a few days, hope that'll help to...
Oh yeah, please post the other links here to... Would like to see if there are some other nice sites that we havent found out about...
He, who's head is in the clouds, is very taaaaallllll!!! |
05-21-2009, 11:57 AM
#35 | |
Oddometer: 963
as for tank enlargement its not really possible. 1 lad did weld a huge bubble onto the top of tank to hold extra 3L but thats the only ever mod done. the lad that did the dakar had a custom tank made for him. why pay huge money for tank mods, just strap 2 jerry cans onot th panniers and there is a simple, cheap solution and easy to remove them and still keep the clean line of the original tank. on a note on the forks and braking, but 12psi into the bleed nipples on the forks and your braking wil improve as the diving down when braking gives impression brakes are poor. sw motech in uk sell an aftermarket brake disk and it is meant to be good. make sure you watch the paint on the underside of the frame as it can start to chip and rust easy. but it is a great lil bike and it is good at everything but not brilliant at any 1 particular thing. get a proper bash plate made up to protect the exhaust pipes
05-21-2009, 05:31 PM
#36 | |
jack of all trades...
Oddometer: 6,587
You mean before one advances to some overgrown pig breeded from a roadbike and an old off road bike? Can't tell this whole bullshit about "beginner" bikes kind of bothers me, can you... Seems some think that if it isn't biggest and fattest it must be a beginner... Beginner - my ass.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 |
05-21-2009, 05:34 PM
#37 | |
Oddometer: 6,587
05-24-2009, 05:44 PM
#38 |
Oddometer: 53
I am looking at getting a mob in AUS called chain gang to make up a 310 mm wave disc and put a better caliper on it (brembo 4 pot off a monster is fairly compact and maybe a good choice).
Definately need a better brake caliper as the stocker is OKish..but still pretty crap even with good pads. Just put in new fork springs (linear rate). For those interested Eibach springs do a spring that will fit - dont know the part number (I think it maybe off an old XR250) but you can match them to this spec: L = 530 mm (approx) - stock is 522 mm so just cut about 15 mm off the really long preload spacer, which will give it about 10 mm of actual preload. OD = 34.9 mm (stock is 34 mm, but there is a full 36mm ID so this spring OD fits fine). Rate = 0.47 mm/kg is the heaviest they make. I weigh 83kg and it is pretty good - still fairly plush but way better than stock.
05-25-2009, 01:26 AM
#39 |
crash test dummy
Oddometer: 625
Jimmy
I thought the Chain Gang had gone out of the motorcycle business and just do pushbikes now? But just looking at their website they still list motorcycle parts? anyone know? Marty
Marty '10 Multistrada 1200 '11 Tiger 800xc (90%) '79 CB900 (225% in boxes) |
05-25-2009, 06:25 PM
#40 | |
Big red dog
Oddometer: 1,322
"It's cunnilingus and psychiatry that's led to this" - Tony Soprano 10 F800GS |
05-27-2009, 05:25 AM
#41 |
Oddometer: 53
Some links for interest:
big bore kits & performance ![]() http://www.mbmotorsports.net/kawasaki/kaw_engine.html http://www.enginedynamics.com/kits/kawasaki.shtml http://www.orientexpress.com/Kawasak...2ce82f7e9eaab8 http://home.comcast.net/~teamcharm/motor.htm Tuning ![]() http://500kle.aventure.free.fr/Tuning-KLE_e.html http://www.dernacken.de/kle-tuning3.html Braking http://83.211.94.164/catalogo/bk/cat...llo=1&id_tip=1 Air Filter http://www.e-moto.gr/en/Details.asp?ProductID=512 http://www.horizonsunlimited.com/hub...lter-kle-37437 General http://michel.erard.free.fr/500_KLE_e.html |
05-28-2009, 07:43 AM
#42 | |
Oddometer: 48
Heres a more recent pic of mine |
06-01-2009, 09:01 AM
#43 |
Oddometer: 24
Anyone an idea why the arrow exhaust wouldn't fit on the older KLE models? I thought those wheren't changed much?
06-01-2009, 01:53 PM
#44 | |
Oddometer: 48
The engine and frames the same so all the mounting points will be the same. Only the body works really changed. The only issue would be centre stand clearance if you have one fitted. |
06-01-2009, 02:48 PM
#45 |
Oddometer: 24
I Also don't see why, but on the arrow site it says that it will only fit the last models, don't really get why... Would like the exhaust though :-P. is the assymetrical design fixed with this exhaust (any power impromvent afer placing that exhaust)?
