Old 10-23-2009, 08:12 PM   #46
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,972
this is why I got the Capo rims....just feels safer when haulin the wife...and more fun too
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 10-24-2009, 01:37 AM   #47
Nocer
Nocer's Avatar
Oddometer: 173
What a good picture!!!! Really sharp :o
Do you know what lens and body the guy who took it has? :)
I can see why you would want to keep her safe ;)
And I can see you surely must buy new shoes often
Nocer is offline   Reply With Quote
Old 10-25-2009, 11:26 AM   #48
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,972
no idea but the lens is huge....?....
Old 11-19-2009, 05:58 AM   #49
boxerone
Lord of Garage!!!
boxerone's Avatar
Oddometer: 21
Originally Posted by charlie264
NICE.
Im assuming these rims arent made by Aprilia, does anyone know who the manufacturer is?
yesss : any idea???
boxerone is offline   Reply With Quote
Old 11-21-2009, 01:55 AM   #50
Peanuts
Peanuts's Avatar
Oddometer: 1,660
Anyone fitted a complete Caponord front wheel? Disc diameter is same......
Peanuts is offline   Reply With Quote
Old 11-21-2009, 11:21 AM   #51
LoFlow
Oddometer: 992
Originally Posted by boxerone
yesss : any idea???
The rim has...Aprilia BEHR Germany, stamped in it.
LoFlow is offline   Reply With Quote
Old 04-29-2010, 11:56 PM   #52
vince377
Oddometer: 2
I've just had mine
vince377 is offline   Reply With Quote
Old 12-08-2010, 04:19 AM   #53
Yascher
Yascher's Avatar
Oddometer: 388
these are from Woody? as hubs are not standart and are ABS compatible
Yascher is offline   Reply With Quote
Old 12-08-2010, 07:17 AM   #54
DakarBlues
One-everythinged man
Oddometer: 1,293
I think the ABS ring is not part of the hub, it might be screwed in, just like the brake disks.
He, whose nuts skim the ground while airborne, won't crash very far!
Pedibus Cum Jambus 1200 S
IBA # 38875
DakarBlues is offline   Reply With Quote
Old 12-08-2010, 10:55 AM   #55
mousitsas
mousitsas's Avatar
Oddometer: 2,850
Since nobody asked it, can the caponord rims be laced to the standard hubs with the caponord spokes, or do we need special spokes???
mousitsas is online now   Reply With Quote
Old 12-08-2010, 11:06 PM   #56
mousitsas
mousitsas's Avatar
Oddometer: 2,850
...also are the capo rims significantly heavier than the excels?
Old 12-09-2010, 12:34 AM   #57
DetR6oit
DetR6oit's Avatar
Oddometer: 158
info is in the EXIF. Doesn't say the lens specifically though
Camera Maker: NIKON CORPORATION
Camera Model: NIKON D700
Image Date: 2009:10:17 17:03:48
Focal Length: 240.0mm
Aperture: f/4.0
Exposure Time: 0.010 s (1/100)
ISO equiv: 200
Photographer: PAUL HEROLD
Copyright: PAUL HEROLD
DetR6oit is offline   Reply With Quote
Old 12-09-2010, 02:09 AM   #58
Yascher
Yascher's Avatar
Oddometer: 388
Aperture: f/4.0
ISO equiv: 200
not a bad lens, if can make f4 at 240mm, probably the short end of a tele, if not paired with a 2x magnifyer)))
Old 01-15-2011, 08:10 AM   #59
R Doug
Recalculating
R Doug's Avatar
Oddometer: 312
I just ordered a set of the Caponord tubeless (19/17") for my Adventure last week. I can't wait to get them.
Since I'll be reducing the size of the diameter of the rear tire by 1" and keeping the same profile tire (i.e. 150/70), I'm considering getting a new sprocket for the rear to keep revs down at speed. How many teeth should I go down on the rear? AND, does anyone have recommendations on some good aftermarket sprockets?
I'll keep my stock sprocket for when I want to change back to the 18" rear for my more gnarly plays in the dirt.
-- Doug
R Doug is offline   Reply With Quote
Old 01-15-2011, 09:25 AM   #60
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,971
Did you get a second Cush drive?
I like 17/45 for dirt/DS use. (21/18" rims)
Swap to 17/42 for Street use. (19/17" rims)
All you need to do is swap the rear axle block 180 Deg and you shouldn't need to even adjust your chain.
The SM and SD have a shorter chain, so they can run an even smaller rear sprocket for higher speeds. The smaller you go in the rear sprocket the longer the wheel base gets. I find that 17/41 w/ my 17/17" SD wheel setup works pretty good for general use. Stable and geared about right for general use.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Times are GMT -7.   It's 04:59 AM.
