Old 05-29-2012, 08:20 AM   #31
jonfen
Oddometer: 2
Question Jimbee, after a few thousand miles, did it work?
"After a few thousand miles I'll provide an update." Well? Did it work?
Originally Posted by jimbee View Post
Alright - please no comments on my lack of artistic JB weld abilities.
New Switch:
Taped off where I didn't want to get JB weld
Mixed some JB QuickDry up and set to work - messy...
I waited two minutes and then removed the tape...
So that's what I did. After a few thousand miles I'll provide an update.
Cheers! JB
jonfen is offline   Reply With Quote
Old 05-29-2012, 09:09 AM   #32
jimbee OP
Airhead Intermediate
jimbee's Avatar
Oddometer: 334
welcome jonfen!
update:
- after 4,000 miles the new neutral switch showed no signs of leaking
- after an unfortunate incident where engine was left running on centre stand for an extended period of time causing the engine to get very very hot, the neutral switch began to leak (amongst other problems)
R100GS for going far, FZ1 for going fast, TE250 for getting dirty, and DR650 for when one of the others needs work
jimbee is offline   Reply With Quote
Old 05-29-2012, 06:45 PM   #33
jonfen
Oddometer: 2
Thumb Two out of two mechanics agree...
Good to note. According to the J-B Weld Company Website it should be good up to 500 F.
I actually called airhead guru Ron Schmidt at the Bavarian Motorcycle Workshop and he recommended doing the exact same thing to my existing switch since it still works aside from the leak. He mentioned the new switches come with a silicon coating on them, but he still suggests J-B Weld on those.
welcome jonfen!
update:
Old 05-30-2012, 11:18 AM   #34
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,953
The correct torque for the engine mounting nuts is 55 ft/lbs.
---Albert Einstein
Old 05-31-2012, 04:31 AM   #35
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 527
Rebuilt trani & JB'd neutral switch
After 12,000 miles (trip to Panama last winter)...............no leaks
Photobucket
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is online now   Reply With Quote
Old 05-31-2012, 06:21 AM   #36
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,816
do yourself a favor instead of using the BMW switch and having to use JB weld, just get the aftermarket switch Huckys sell...it don't leak and no modifications needed, plus it's cheaper.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-31-2012, 10:19 AM   #37
jimbee OP
jimbee's Avatar
Oddometer: 334
Nice JB artistry!
OLH - thanks for the heads up
Old 05-31-2012, 01:21 PM   #38
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 1,008
This came up a couple month's ago at 2 of the local BMW dealers in the Bay area..they had a run of neutral switch returns. After a few thousand miles, a leak developed between the plastic and metal. The OEM German version could go 30-50K miles and never leak..some of the Chinese versions didn't get 3K before they puked.
If the box doesn't say made in de fatherland, I put a ring of epoxy around the metal/plastic ring and put it on the shelf to cure.
Worked so far..no returns in a couple years.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 05-31-2012, 04:58 PM   #39
One Less Harley
Oddometer: 4,816
repro one on mine has been holding up well so far this season, which is more than I can say for the POS over priced BMW one. So less money well spent.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 09-24-2012, 06:46 PM   #40
mspa
mspa's Avatar
Oddometer: 143
I'm going to ask a stupid question.
My switch works fine. It has some grey stuff on it that looks like JB Weld, put on by the guy I got the bike from when he installed. Is there any value in using carb cleaner spray to clean the area off (when engine is cold), dry, clean up . . . then apply some more JB weld, avoiding the terminals or case? The stuff on there now is not smooth, and I'm wondering if in the pockets and such maybe there is one small path the oil is coming out of.
Riding my airhead is like eating chinese food . . . an hour later, I need to ride again.
1978 BMW R100S "bitza" (R80/7 frame)
mspa is offline   Reply With Quote
Old 09-24-2012, 07:36 PM   #41
DaveBall
DaveBall's Avatar
Oddometer: 1,163
If it isn't leaking, leave it alone. When/If it starts to leak, get a new one and apply the JB Weld to it. Or, when the one you have starts to leak, take it out and clean the hell out of it and apply JB Weld.
When these things start to leak, they do it very slowly. More like a weeping. I had one leaking for 2 years and only topped up the tranny a few times. Total over 2 years I think I went to thru less that 4 or 5 ounces of fluid.
DaveBall is offline   Reply With Quote
Old 09-24-2012, 08:09 PM   #42
One Less Harley
Oddometer: 4,816
really...just buy the brass version it's cheaper and don't leak!!!
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 09-24-2012, 08:19 PM   #43
mspa
mspa's Avatar
Oddometer: 143
It is leaking. More now than about 2 weeks ago. The clutch job was done last Spring, so not many miles on there. I should add that it doesn't leak enough to leave a spot on the ground. Tho, I can't say how much is coming out under full pressure on the highway. If I push the bike hard on the highway, I may notice a drop form on one side under the oil pan, where it collects. So it's not something that has to be done today. But obviously, has to be dealt with at some point, or I have to make a habit of checking the trans fluid level.
It seems like these things should come in a multi-pak . . .
mspa screwed with this post 09-24-2012 at 08:28 PM
Old 09-25-2012, 07:35 AM   #44
mspa
mspa's Avatar
Oddometer: 143
Anyone try Ultra Black?
Old 09-28-2012, 07:03 PM   #45
mspa
mspa's Avatar
Oddometer: 143
Well, I did. Used Permatex Ultra Black to patch the JB Weld that was on the switch. I cleaned off the switch with CRC electronics cleaner when it was warm (cool enough to touch). Let that dry and noticed some areas where the JB appeared to not have been applied well. I used some thin wood coffee sticks from work (1/8" wide) to apply the Ultra Black. That was two days ago. No leak of any kind so far. I may not be a permanent fix, but I figure it buys time until I order some brass switches from Moto-bins, or somewhere local maybe?
Times are GMT -7.   It's 08:03 AM.
