Old 06-13-2009, 01:33 PM   #1
Bugman98 OP
Oddometer: 206
Questions about emailing tracks
Is being able to make "tracks" on the GPS necessary to read someone else's .gpx file of OHV trails that I've down loaded? The GPS model in question is a garmin 2730 if that helps.
Bugman
Norman, OK
Wind in my hair, bugs in my teeth!
Bugman98 is offline   Reply With Quote
Old 06-13-2009, 10:05 PM   #2
Countdown
Oddometer: 5,771
Be more specific.
You used Mapsource to download Tracks, Waypooints, and/or Routes to a 2730 or did you download a .gpx file direct to the 2730 memory?
I don't think the 2730 has track features. If you want to download, see, and follow tracks get a hand held or chart plotter (60/76/x76).
Jerry Counts
Countdown is offline   Reply With Quote
Old 06-14-2009, 04:28 AM   #3
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,312
If you have loaded Mapsource on your computer, you can read the gpx file containing the tracks.
Loading them and following them on a 2730 is another story. The 2730 is Street Pilot, not a GPSMAP unit like the 60's, 276/376/378/478, etc. It's not impossible to do with the SP series, but it is a lot more difficult.
dunno.....
Old 06-14-2009, 02:50 PM   #4
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Another option is you can load the GPX files into Google Earth.
Then you can edit them and even delete the parts of the track that was not intended to be part of your original path you wanted to share.
The save it as a .kml file and use GPSBabel to convert back to GPX or to Garmin GDB or whatever relevant GPS device you happen to have.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Times are GMT -7.   It's 07:39 PM.
