Thread Tools Rating: Thread Rating: 434 votes, 4.97 average. Display Modes
Old 05-23-2009, 07:31 AM   #136
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,885
Originally Posted by PirateJohn
Here's another possibility for those of you who want to build an RV or bus conversion on a budget. This guy pulled into the Flying J outside Atlanta while I was spending the night there:
The GM "Buffalo" buses can be had dirt cheap. They were built in several models from about 1966 thru 1980. They were all aluminum construction, like an airplane, so rust isn't as much of an issue as it is with buses like a Silver Eagle.
Another inexpensive bus that I hear can make a decent motorhome are the RTS transit buses. Transit buses often are geared very low and have other features that make them less than desirable as an RV, but folks tell me that the RTS's overcome most of those issues:
I like the gold one on top.
What kind of engine/transmission do they have?
DELTATANGO is offline   Reply With Quote
Old 05-23-2009, 07:38 AM   #137
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
According to Wiki they were all build with 8V71 Detroits, so that's the 8 cylinder predecessor to the 6V92 in my coach. I'd say it's a pretty good engine.
The owner told me that there was a small gasoline pony motor that was used to run the air conditioning. He gave me some other info that wasn't right, and said that he had never run the pony motor, so you have to take that last bit with a grain of salt.
Most of them were evidently built with a 4-speed manual transmission although an auto was offered later in the production run.
Once again, Wiki has some choice comments about how hard some of these things are to shift gears. I have heard similar with the early MCI buses before they went to automatics across the board.
PirateJohn is offline   Reply With Quote
Old 05-23-2009, 08:26 AM   #138
DELTATANGO
DELTATANGO's Avatar
Oddometer: 13,885
Those bus type Mohos are neat but they are too big and complex for me to get my head around. I can get 454's and TH400s and stuff like that but the big diesel stuff is beyond me. But they are very nice.
Old 05-23-2009, 08:32 AM   #139
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
We've all got different wants and needs. I need something pretty big to carry all my crap around in and to haul bikes, SUVs, and so forth. Not everyone needs to do all that.
And I've seen some really basic bus conversions and some really, REALLY exotic ones as well. The really fancy ones usually take an experienced person 2-3 years and $100K to put together, and at the end of the day you have a vehicle of questionable resale value *IF* that's of importance to you.
The more that I read these threads, the more that I think that I need to write a book or at least a pamphlet
Old 05-23-2009, 09:39 AM   #140
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,601
Coming home from Medford the other day, I saw this cool hippie bus broke down, I shoulda snapped a pic
Had no idea it was FURTHER #2 on it's way home from a Dead concert
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 05-23-2009, 10:50 AM   #141
NeedForSpeed
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,409
My next rig.
NITRON RACING SHOCKS USA
(801) 663-7436 sales@nitronusa.com
NeedForSpeed is offline   Reply With Quote
Old 05-23-2009, 10:51 AM   #142
NeedForSpeed
Nitron Shocks USA
Oddometer: 1,409
Old 05-23-2009, 11:10 AM   #143
jonpcovington
Oddometer: 1,001
I did a Google for "Toyota Dolphin generator" and ran across comments from people that they had installed Onan and Kohler units. Someone installed a Dometic, which I had never heard of; my quick advice would be to stay away from a Dometic generator.
Supposedly there was a factory-installed 2800watt Onan gasoline generator available in the 1989 22' Dolphins.
D'oh! Now why didn't think of that? Thanx, Pirate John.
jonpcovington is offline   Reply With Quote
Old 05-23-2009, 11:39 AM   #144
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
My pleasure!
Old 05-23-2009, 11:42 AM   #145
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
Originally Posted by NeedForSpeed
My next rig.
Everyone that I have ever talked to that had a Sprinter-based RV really liked them. Fuel mileage is supposed to be excellent, and they are maneuverable, but they would have to be tiny with two aboard.
I did run into two musicians and their manager once who were staying on the road and performing gigs around the USA. If you need to drive a lot, and you don't mind some serious camping, then the Sprinter would be the ticket.
There are some elaborate Class C's on cutaway Sprinter chassis but 1) they are almost as expensive as an entry-level Class A and 2) one has to wonder if they are as overloaded as the other Class C's usually are.
Old 05-23-2009, 03:37 PM   #146
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
Originally Posted by SeanF
Good timing. My summer location will creep toward 100 degrees (with low humidity), so I am going to try a small evap cooler. Basically a large box fan with a pad and pump to circulate the water. Since I have grid power available I don't have to worry about power consumption on this puppy (but it is relatively low anyway). Same with water...few gallons/day, which is no problem where I am. But it would be if I were truly boondocking.
I really like where I am so I hope it works.
Sean, tell us about evaporative coolers. Are there any specifically for motorhomes?
Old 05-23-2009, 05:22 PM   #147
Daniii
geezer
Daniii's Avatar
Oddometer: 24,596
We bought one that attached to a standard ceiling vent. It used a pressurized bottle to get the water up there. The fan had a cone that slung water into the foam mesh. It was very effective. It was pretty cheap too.
Daniii is offline   Reply With Quote
Old 05-23-2009, 08:35 PM   #148
NomadRip
Always a n00b
NomadRip's Avatar
Oddometer: 3,366
Sean, the "regulars" will never grow tired of seeing your bus pics.
Another option that I don't know if it has been talked about in any of the previous threads, is to build one yourself. This dude in Australia has to be about the most ingenious ways to design, build and modify a ginormous full-time rv-like thing based on an old army-type truck chassis he got dirt cheap.
He literally fabricated EVERYTHING that wasn't the bare truck chassis, and it was nice.
Several years later, after having time to consider things he liked and didn't like, he unbolted the thing he built, and built another one.
The website is a little wonky to navigate at first, but once you figure it out, it's worth going back and reading both the first build and the 2nd. The guy is a genius.
Wothahellizat : Winnebago meets Mad Max
-James
"We are adventure riders. The needs are pretty simple. Bring what you need, share what you've got." -cRAsH
Save 20% when you sign up to the best photo hosting site around: SmugMug!
NomadRip is offline   Reply With Quote
Old 05-23-2009, 11:19 PM   #149
Wildcard342
Wildcard342's Avatar
Oddometer: 356
There is a lot to be said for a commercial tractor combination.
One minor complication that's important to me (although I see that you are in Oz and perhaps not as important to you) is that Mexico has been refusing to allow commercial truck chassis to enter unless, in some circumstances, they are hooked to a travel trailer.
Actually I intend to come over to the US and buy this combo in a few years and spend some time touring the US and Canada. I have heard about the Mexico thing, but it used to be OK to cross there as long as you were a rig and came back the same way. I like motorhomes but if they break, and they aren't as tough as a semi, then you lose your home while its being fixed.
A semi is cheap as chips, lasts forever and can control big 5th wheelers easily. 36 foot plus 5th wheelers are huge now and if you get a good brand used then they are really good value to. Plus the rig can carry a car, a few bikes, quads whatever. A semi gets the same or better fuel economy than a big f350 and wont get pushed through an intersection by the 5er. Here is a really good site on HDT's and 5ers.
http://www.rvnetwork.com/index.php?showforum=32
Wildcard342 is online now   Reply With Quote
Old 05-24-2009, 12:54 AM   #150
cornercarver
cornercarver's Avatar
Oddometer: 18,536
Originally Posted by NomadRip
Fuck! I'm going to be up all damn night. I'm only on diary 4 of the rebuild after a significant chunk of an hour of reading.
This is slower going than the bus build...
cornercarver is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 12:55 AM.
