01-28-2013, 07:31 AM
#3151 | |
Befuddled Adventurer
Oddometer: 1,210
Fantastic information, thank you. Todays economy has certainly put a strain on a lot of industries. The RV sector is most likely feeling it even worse as it is usually discretionary income that stimulates most RV usage. Good news about RV sights increasing usage of wireless, unfortunately most of my camping will be dry docking (4 days avg. stay) and not making use of RV sights. I have got now 3 terabytes of movies and TV to keep me occupied but what I'd really like is internet access to pass some time. However it looks like its not really available cost effectively without a yearly cell contract. I'll check into the options you listed and thanks for the insight. Just missed out on an Ebay Class B by $800 today. So the search continues. I'm finding most inexpensive Class B's (under $10k) often don't have a generator. Knowing nothing about approximate amperage draw would you be able to power enough LED lights to function inside a B for a few days? Say if its only for lights and computer usage and using deep cycle battery(ies)?
Cheers, Team FTB ------------------ Team "Fingering The Bean" Looking for the woman that takes the wheel when I'm seeing double. |
01-28-2013, 09:02 AM
#3152 |
Radical centrist
Oddometer: 21,272
I would suggest that you keep looking; I have a relatively junky Southwind RV that's worth about $5K and it has a good generator. Good enough that I may scrap out this RV rather than sell it simply because the parts are worth more than the whole (with that said if your travels take you to the San Antonio, TX area and you need an occasional RV then drop me a line and we might kick something around).
Good places for RV bargains are eBay (search for repos and no reserve sales - you see some bargains every so often), Craigslist, and www.RVTrader.com When looking for something in the USA remember that this is a big country (although I am sure that you know that) and even Texas is big enough that some RVs may not be economical if you have to travel across the state to pick it up. Good luck! Sent from my iPad using Tapatalk HD
PirateJohn -- http://www.PirateJohn.com IBA #7552 - SS1K in 2000 and 50CC in 2002 In the Laredo, TX area and always willing to help travelers escaping into Mexico.
01-28-2013, 09:32 AM
#3153 | |
not dead yet
Oddometer: 3,631
Or install deep cycle house battery and a simple charging system. That would get you several days.
Caution: Happy Fun Guy may suddenly accelerate to dangerous speeds. If Happy Fun Guy begins to smoke, get away immediately. Seek shelter and cover head. Do not taunt Happy Fun Guy. ~ Randy DL650 DRZ400s |
01-28-2013, 09:43 AM
#3154 | |
visionary
Oddometer: 2,046
"Good Times & Good Friends Make Life Better" www.artworks-unlimited.com |
01-28-2013, 10:23 AM
#3155 | |
Radical centrist
Oddometer: 21,272
With that said your aren't going to run air conditioning or electric heat or electric kitchen appliances without a healthy generator or a huge investment in batteries and an inverter. Sent from my iPad using Tapatalk HD
01-29-2013, 05:54 AM
#3156 |
On Any Sunday
Oddometer: 582
Mini Winnie Furnace Question
Hi gang, we recently purchased a 1986 Mini Winnie class C on a Ford chassis and although in generally good condition, the furnace will not light up. Have been reading the trouble shooting info and for starters, it looks like I need to test the "sail" switch, but in order to reach this switch, it looks like I will need to pull the furnace out of its cubby. Does that sound correct? If this is not the right thread fort his question, please point me to a correct one. Thanks very much!
"Nothing can stop us but fear and common sense” |
01-29-2013, 07:10 AM
#3157 | |
Wee-stromer
01-29-2013, 07:59 AM
#3158 | |
not dead yet
Oddometer: 3,631
My little Honda EU 2000i covers any other longer term needs. Would like to get solar going but not a real priority for me...
01-29-2013, 08:06 AM
#3159 | |
On Any Sunday
Oddometer: 582
Thanks for any help or guidance you or other ADV'ers can provide!
01-29-2013, 09:24 AM
#3160 | |
geezer
PS: if that fixes it, replace the sail switch. It does serve a very useful purpose.
01-29-2013, 09:59 AM
#3161 | |
growing old disgracefully
Oddometer: 644
01-29-2013, 11:26 AM
#3162 |
Wee-stromer
yep, this. you can jumper it with a patch cable.
01-29-2013, 01:32 PM
#3163 |
On Any Sunday
Oddometer: 582
Appreciate the answers, does anyone know if there is a clever way to reach this circuit or sail switch without pulling the furnace from the motor home? Thanks again!
01-29-2013, 05:46 PM
#3164 |
What could go wrong?
Oddometer: 1,654
LC, those things are a pain and the best (only) way to really service them is to remove them. But, before you get that far here are a few things you can try:
1. Really make sure that you're getting at least 12VDC to the furnace. Sounds obvious - it isn't. Often, the voltage loss from the battery to the furnace is measurable. Even if you're getting 12v, try plugging the RV in to 120VAC or starting the engine. Get as much power to the furnace as you can. I've repeatedly seen issues where a furnace would work fine on the bench but fail to light when installed. Make sure your ground is good. Really. Edit: The blower motor will probably run down to about 5VDC but the ignition circuit won't fire. That's why I suggest checking voltage. 2. Since the rig is new to you I'll ask a few of the more obvious questions: 2.a Do you actually have propane? 2.b Is the propane getting to the furnace? 2.c Is the propane cut off valve at the furnace actually turned on? 2.d Is the ignitor trying to fire? Do you hear clicking or see sparking from the ignitor? (assuming you have an electronic ignition furnace not a pilot light unit) 3. If you're getting ignition (spark or clicking noise) then troubleshooting takes a different route. If not then try blowing out the furnace vents. Often wasps make happy little homes in the furnace vents and intake/exhaust systems. Take a shop vac or vacuum cleaner (high volume, low pressure), connect the hose so it 'blows' air and force air through each of the furnace vents on the outside of the rig. Do one at a time. Hopefully you'll get tons of crap blowing out and then you can move on to the next issue or maybe it will even just start. Try that stuff and let us know how it goes. Of course the most expensive risk you run is that your control board is fried. But none of the steps above will cause or prevent that. It's funny that these furnaces need some sort or regular care but no one does that. Then we're all surprised when they don't work.
'00 XRV750 Africa Twin, '99 CRM250-AR, '88 TLM220R, '77 TS-50 Death is more universal than life; everyone dies but not everyone lives. -A. Sachs "Get on with living or get on with dying" Paul Rodden 71 years old Diesel RV build Joz screwed with this post 01-29-2013 at 05:51 PM |
01-30-2013, 08:22 AM
#3165 | ||
On Any Sunday
Oddometer: 582
![]() 1. Checking voltage, this unit is in storage, will go down this weekend and check the voltage. I see one connector going into the furnace, can I just separate the connector and check the voltage at that point? 2a thru 2d. We have propane, I ran the stove top to verify. I have manipulated the valve at the furnace from an inward position to an outward position (rotated counterclockwise) and am ASS-uming there is propane present. there is no evidence (sight or sound) of the igniter trying to light. 3. Will be taking a shop vac down this weekend and cleaning out all hoses and orifices. Will do the due dilligence but believe the furace will be coming out, at this point if furnace is removed, I'll just plan on installing a new sail switch and limit switch, no point going that far and then scrimping on a couple of key and relatively inexpensive parts. Is there a good source (online) to buy the switches? Thanks again to all of you who weighed in on this, I will update with results as this progresses.
| Thread Tools | |
