Old 02-03-2015, 01:17 PM   #1
Jim K in PA OP
Jim K in PA's Avatar
Oddometer: 1,097
Front brake pads - Organic? Carbon Kevlar? Sintered?
Subject ride: Olga - 1975 R90S
Front brakes: Stock dual front BMW disk - 260mm, with KZ750 calipers
Rear brake: Stock BMW drum
Just a reality check for me, but now that I know what I have for brakes, I am going to pick up some new front pads. I understand the fundamental differences in application of different friction materials. However, I was looking for some real world experience from those that have run a hack, with the commensurate additional weight, and what pad material you have run.
Thanks for input, or a head slap and a reference to a previous thread. I tried the google search for it here and came up with bupkis . . .
Jim K in PA
1979 BMW R100T - Otto - Returned to the road - 5/12/11
1975 BMW R90S Hack - Olga - Olga's story - adopted 3/22/14
Viktor - Coming to a thread near you - eventually
Jim K in PA is offline   Reply With Quote
Old 02-03-2015, 05:06 PM   #2
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 678
I like sintered pads the best for their stopping power and the range of conditions that they work well in. When it comes to brand I always look for Ferodo brake pads if they have the application I need.
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 02-03-2015, 06:16 PM   #3
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,526
I have yet to have any good luck with discount pads, making me think Carl may be right, I took my dust covers off the calipers , shoot some brake cleaner in and blow them out periodically.If I don't clean them they squeal and are annoying.DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 02-03-2015, 07:55 PM   #4
dirtyron
never grew up
Oddometer: 335
I want the strongest pads I can find which are rated HH. ebc brand if available.can't go wrong with ferodo but they are pricy. the softer material will wear faster.
dirtyron screwed with this post 02-03-2015 at 08:00 PM
dirtyron is offline   Reply With Quote
Old 02-03-2015, 11:31 PM   #5
ErictheBiking
Oddometer: 113
I'd rather have good quality soft brake pads than hard brake pads.
I found out the hard way by wearing out my disc rotors.
ErictheBiking is offline   Reply With Quote
Old 02-04-2015, 04:27 AM   #6
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,290
The EBC HH pads work well.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 02-04-2015, 06:55 AM   #7
Carl Childers
Oddometer: 678
I tried EBC's , they stopped well but no better than what I was using and were noisy so I've gone back to Ferodo's, another benefit is under non race conditions they last a long time. I reckon brake pad discussions can be akin to oil threads and bottom line is like Dave mentioned stay away from the cut rate brands.
Old 02-04-2015, 07:10 AM   #8
Jim K in PA OP
Oddometer: 1,097
Thanks guys.
I agree, Carl, and I really did not want to start a "which brand is better" discussion.
Per Eric's comment, my real point in starting this discussion was pad hardness as related to wear, both of the pad and more importantly (expensively), the rotors. Hard pads do not necessarily abrade the rotors quickly, but hard abrasive pads will.
I think I will wind up doing what I usually do, which is experiment with some pads and see what works best. The Tokico pads that are on the bike now appear to be organic, and do wear rather quickly, but that does not bother me too much. I'll probably start with organics, and go up from there in terms of hardness.
Jim K in PA
Old 02-04-2015, 07:14 AM   #9
BWeber
Oddometer: 231
I have had several racers remind me to scotch bright and break clean scrub the rotors clean before using new pads. The advise was for the differences in pad compounds. It did not sound like a bad idea so I have been doing this extra step.
BWeber is offline   Reply With Quote
Old 02-04-2015, 06:22 PM   #10
Jim K in PA OP
Oddometer: 1,097
I've ordered three sets of EBC pads: FA68 (kevlar/organic), FA68V (semi-sintered), and FA68HH (full sintered/hard). We'll start in the middle and work outward.
Jim K in PA
Old 02-05-2015, 02:26 PM   #11
Hookalatch
Born Under Bad Sign
Hookalatch's Avatar
Oddometer: 381
I replaced some slightly worn, glazed EBC HH pads with a new set. I also used a maroon roloc disc on a die grinder and went over both sides of both front discs. The change in braking power was amazing. I have to think part of it was cleaning the disc with the scotchbrite pads.
Chuck
Hookalatch is offline   Reply With Quote
Old 02-05-2015, 06:43 PM   #12
dirtyron
never grew up
Oddometer: 335
my experience with ebc HH pads on my ducati was that the effort at the lever was halved.
Times are GMT -7.   It's 03:49 PM.
