Old 06-18-2009, 10:07 PM   #16
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,647
Originally Posted by DisTech
Great write up Bill. I've got RaceTech emulators and additional holes drilled in the damper rods. Did you replace your damper rods for the Intiminator install?
no. 5wt oil is used for proper flow w/ Intiminators & stock hole size on the rod. even with enlarged holes (from Emulator install) the flow rate is still controlled/metered by the Intiminators. Using 5wt oil max flow occurs with stock or enlarged holes when using Nators.
what is different is Intiminator valves controls the fork better than Emulator valves.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 06-18-2009, 11:06 PM   #17
DisTech
DisTech's Avatar
Oddometer: 616
Excellent, thanks!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 07-13-2009, 06:15 PM   #18
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Originally Posted by NordieBoy
The front just sits up and begs with the Intiminators in.
I'm sorely tempted to sell my Eibach springs.
The race sag and ride height with the stockers is fine.
Just put in the Eibach 0.48kg/mm springs to try on Sunday.
5mm of preload gets me 17% static sag and 25% race sag.
I need to ride it for a bit more but it feels fine so far.
I think they have more potential than the stockers.
NordieBoy is online now   Reply With Quote
Old 08-11-2009, 10:21 AM   #19
Navaho
Navaho's Avatar
Oddometer: 1,043
I just did the same thing as Eakins, replaced the RT emulators with Intiminators. They're great! Much better than the emulators. I'm using 0.45kg straight-rate springs with a preload of 10 mm, and I've increased the oil to only 115 mm from the top. I also mixed in some 10 wt with the 5 wt for a little more damping both directions. I push the DR hard offroad so all this was done to improve bottoming resistance.
I really can't add anything else to what Eakins has already reported. The Intiminators are plush over all sizes of bumps yet have good bottoming resistence. They do make a clicking sound that I can hear on hard hits but it doesn't seam to affect performance.
'07 450EXC, '06 950 Supermoto, '09 YZ450F
Navaho is offline   Reply With Quote
Old 09-28-2009, 07:40 PM   #20
Eagerpooch
Eagerpooch's Avatar
Oddometer: 189
lets sum this up for an idiot
Okay, I dont know much about this kind of stuff but just trying to sum up this review. I hate the dive during hard braking. I an go ahead and keep the stock springs and pretty much this Intiminator valve will solve this issue and make it even better offroad? Sounds like it is worth every penny.
I also feel like the rear shock is too soft. Im no light weight at 205lb and I like to load the bike up with camping gear too. Can I adjust the preload to stiffen this up or should I go with a new rear shock?
I want the most bang for the buck.
Eagerpooch is offline   Reply With Quote
Old 09-28-2009, 08:36 PM   #21
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Cogent rear for best bang for buck out back.
For your weight and use I'd still add 0.48 fork springs.
Old 02-04-2010, 06:44 AM   #22
psmcn
psmcn's Avatar
Oddometer: 22
Great writeup. Just what i am looking for. After I get the GV/springs in the rear I will seriously consider the intiminators for the forks.
Paul
Never Leave your wing-man
2001 DR650
1996 GoldWing GL1500SE
psmcn is offline   Reply With Quote
Old 02-15-2010, 06:06 PM   #23
Tiggleswerth
Jansport
Tiggleswerth's Avatar
Oddometer: 234
Has anyone else gone from emulators to intiminators or the other way around? Just wondering if we could get any more opinions on the comparative performance of these two products.
Slow down for the pavement, speed up for the dirt...
Tiggleswerth is offline   Reply With Quote
Old 02-21-2010, 08:25 PM   #24
frednic
We survived another one!
frednic's Avatar
Oddometer: 6
how many oz's of oil
Great write up! thanks a bunch. I just installed mine today. I put in 16 oz in each fork. The oil level was a little lower than 6.5 inches. I was to lazy to fuck around with it any more. I don't see why the oil level would change with the stock set up. It wouldn't matter how much you weighed or what your preferences were for rebound. I read where you asked for others input on how much oil they put into their forks so I thought I'd put my 2 cents in.
frednic is offline   Reply With Quote
Old 02-21-2010, 11:16 PM   #25
Beezer
Oddometer: 5,748
Oil level affects the quantity of air left to compress in the shock.... more air, more dive on the initial hit, though either valve is much better than stock as far as controlling that.
ATF mixed with Marvel Mystery Oil 50/50 is really close to 5WT fork oil
Beezer is offline   Reply With Quote
Old 02-24-2010, 12:11 PM   #26
ADV Dog
Adv dog
Oddometer: 6
Help with my current set up.
Great info, but I don't have the denaros to spend on Intiminator.
I have the Eibach .5 front spring but feel it hars on wasboars.
I was thinking of dropping to 5w or 7.5w oil (not sure which would work best if at all) to see if it would soften the hit a bit.
If not then I will exchange the springs for some .48.
Any feedback is appreciated.
ADV Dog is offline   Reply With Quote
Old 02-24-2010, 01:50 PM   #27
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Would have thought you'd need to go to 12-15 weight oil with the heavier springs?
How much do you weigh?
Do you have a big tank?
Old 02-24-2010, 05:52 PM   #28
~AJ~
Adventure pooper
~AJ~'s Avatar
Oddometer: 224
Great to see another positive review of the intiminators. I installed mine last year (around April or so) and love them. So far they have been maintenance free and performed solid the entire time. I was coming from a stock setup so I can't comment on the switch from the emulators but compared to stock, night and day.
FS: 2005 DR650... PM me.
~AJ~ is offline   Reply With Quote
Old 11-06-2010, 04:53 AM   #29
NOSIGN
NOSIGN's Avatar
Oddometer: 96
spring rate
Does anybody know what the standard fork spring rate is?
NOSIGN
DR650SE ('97) current project
CBR954 ('03) daily ride
CBR900 ('96) the 'ol days
CR250 ('03), 125 ('89), 80 ('85) the 'ol days
KX80 ('92) the 'ol days
NOSIGN is offline   Reply With Quote
Old 11-06-2010, 06:48 AM   #30
NOSIGN
NOSIGN's Avatar
Oddometer: 96
racetech
nevermind... from the racetech website - stock 0.44kg/mm
http://old.racetech.com/evalving/eng...ngname=english
thanks all
NOSIGN
Times are GMT -7.   It's 09:03 PM.
