Old 03-20-2011, 06:54 PM   #46
iyaoyas98
Bored Silly
iyaoyas98's Avatar
Oddometer: 6,832
Great Write up eakins. Ricor ought to give you a kickback.
I just bought the Ricors that were in the FM. Hopefully I'll get them in next weekend.
Next is to tackle the trampoline ass end....
iyaoyas98 is offline   Reply With Quote
Old 03-21-2011, 12:50 PM   #47
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
I'm thinking that the Ricor back end would match up nicely with the Intiminator front.
The Cogent back would suit an Emulator'd front.
Either would be much better than stock though.
I'd prefer it if the Ricor one had an external resovoir and wasn't an emulsion shock though.
Now if they could bring out a retrofit kit for the stock shock.......
NordieBoy is offline   Reply With Quote
Old 03-22-2011, 02:22 PM   #48
iyaoyas98
Bored Silly
iyaoyas98's Avatar
Oddometer: 6,832
I'm leaning towards a DRZ with big spring. If that doesn't play out, off to Cogent the DR stocker goes. Still eyeing the DRZ front end too, just don't want to rip her apart and get stuck with a problem. The weather just broke here, and it's too nice for serious wrenching...
Old 03-22-2011, 02:31 PM   #49
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 19,403
i have a cogent rear i bought before ricor came out with their shock.
ricor front and cogent rear are working for me but that ricor rear is indeed sweet.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 04-25-2011, 12:35 PM   #50
Ddodge
Harmless Heretic
Ddodge's Avatar
Oddometer: 1,886
Bill,
I'm about to order some intiminators for my KLR650. Is there some reason you removed the front wheel and the forks? If I read their site correctly, you should just have to drain the forks, take the top off, take out the spring, put in the intiminator, put the spring back and put the top back on the fork tube. Did I miss something?
Thanks in advance
Science is that little voice in your head that says, "You could be wrong. You've been wrong before." - Carl Sagan and Ann Druyan
Ddodge is offline   Reply With Quote
Old 04-25-2011, 12:46 PM   #51
oldtrucks
oldtrucks's Avatar
Oddometer: 290
Technically no, you can do it on the bike. You will need to get the old oil out and the easiest way is to pour it out the top. When you add the oil in you want the shock as vertical as possible so you can get an accurate measurement.
oldtrucks is online now   Reply With Quote
Old 04-25-2011, 01:50 PM   #52
Ddodge
Harmless Heretic
Ddodge's Avatar
Oddometer: 1,886
Thanks. That makes sense. I'm not with the bike, but all my others have had drain plugs on the forks. . .
Old 04-25-2011, 07:29 PM   #53
oldtrucks
oldtrucks's Avatar
Oddometer: 290
You could drain the oil out the bottom too, it's just easier pouring it out the top. To go out the bottom you'll need the Giant Allen wrench to hold the dampener tube inside when you pull the Allen off the bottom of the forks. One of the installation bonuses of the Intiminators is you can do it without removing that internal assembly. You'll probably be surprised how easily the front end comes apart
Old 04-25-2011, 08:10 PM   #54
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 19,403
yes that is another method some use. my write up is just how i did it with simple hand tools and what worked for me.
Alaska
Old 04-25-2011, 08:52 PM   #55
Mile Maker
Mile Maker's Avatar
Location: Southern Alberta, only 150 km to a curvy road
Oddometer: 100
Thumb
Bill,
I installed the Ricor Intiminators and rear shock on my KLR this winter. It is a HUGE improvement over stock. Well worth the money.
I have the 220 - 270 spring on the rear shock, it is for sure stiffer than stock, but i quickly got use to it. It doesn't wallow over dips in the road or pot holes anymore. Just soaks up ANYTHING.
I think that the stock shock setup was too soft.
I would recommend this suspension upgrade to anyone. Well worth it.
I removed the forks from the bike for ease of draining and re filling the oil. I am 210 with the Stock springs, the stock spacers cut down the same amount as the thickness of the valve. It feels fine. I cant quite remember how much race sag i have in the front. I think it was 2.75"
and i have the recommended 3.5 in the rear.
I use to have a hard time keeping up to by riding partner on gravel roads and 2 track stuff, Not any more. this new suspension has given me the confidence to drive the bike as it was meant to be driven.
Cant say enough good things. I haven't loaded the bike full of camping gear yet... Looking forward to that.
Mile Maker is offline   Reply With Quote
Old 04-25-2011, 08:56 PM   #56
Mile Maker
Mile Maker's Avatar
Oddometer: 100
OH
Check for online promotions from Ricor.
I could have saved myself $100 when i ordered mine if i had just typed in that key word!
for the KLR it was "KLR.net" i think
There is likely something similar for the DR Or any of the ADV forum members.
Old 04-26-2011, 08:21 PM   #57
Wanna Ride
Oddometer: 84
Before you drain the fork oil, measure the oil level to use that as a reference. Not all factory levels are correct. If you leave the forks upside down overnight, you will be surprised how much junk will drain out. You should pump the forks a bit to get all the oil out of the internal chambers. The oil level will change a bit if you have progressive rate springs and turn them upside down because more, or less, coils will be under the oil.
If you take a glass of water and hold it at the same angle of the forks, you will see the distance from the oil level to the top of the glass will be different on opposite sides. Once you set the level where you like, then you can measure the same way from then on, such as down the back side of the tube when the forks are mounted on the bike.
Wanna Ride is offline   Reply With Quote
Old 10-05-2011, 06:36 AM   #58
The Rizz
The Rizz's Avatar
Oddometer: 639
Anybody know if the Intiminators for the dr650 are the same as those for the dl650? They are both 43mm?
Current: 2000 ZR7, 2006 450 EXC
Sold, stolen, or totalled: 1997 DR650, 2008 Versys, 2004 525 EXC, 2009 Street Triple, 2005.5 950 Adventure, 2003 DRZ400e, 2000 DR650, 2004 KLR650, 2003 DRZ400s, 2002 DRZ400s, 2003 FZ1, 1998 VFR800, 1996 Ninja 250 race bike, 2000 TL1000R, 2000 ZR7.
The Rizz is offline   Reply With Quote
Old 10-05-2011, 10:58 AM   #59
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 19,403
no there is a slight difference on the ID of the forks.
i did a dl650 install too.
ricor sent mr strom ones for my dr and the fit was wrong.
http://www.advrider.com/forums/showthread.php?t=461908
Alaska
Old 10-05-2011, 11:00 AM   #60
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 19,403
Bill,
Thanks in advance
update: KLR has oil drain screws. DR does not.
some DR owners remove lower rod screw and drain however.
Alaska
Times are GMT -7.   It's 10:46 PM.
