Old 06-02-2009, 11:48 AM   #16
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 2,586
Originally Posted by Mezo
The cup, now that i understand.
Where did they get the word "Races" from ?
i always figured it was because the bearing "race" around in them
plugeye is online now   Reply With Quote
Old 06-02-2009, 11:19 PM   #17
sander
sander's Avatar
Oddometer: 193
Are the forks there yet?
What are you going to do for a rear wheel. I'm on the lookout for a 18" dr350 wheel (with cush drive)
Panniers should be in before friday
Originally Posted by fizzerfz1
Nice color scheme and Nice tires. Do you know what tires those are?
Also is there a link or a write up for the freebie version of the gsxr can mod? I have a gxsr can sitting and cannot seem to afford or justify an expensive mid pipe at this time.
The tires are Dunlop 606. They whistle on the tar, and if I get 4000km out of them I'd be happy.
I went for the kientech kit. Get the stainless flange because the aluminium one starts to leak after a while.
sander is offline   Reply With Quote
Old 06-03-2009, 03:14 AM   #18
Luushen
Victorian
Luushen's Avatar
Oddometer: 663
what panniers ?
im happuy to get 3500 klms from a D606 rear
Luushen is offline   Reply With Quote
Old 06-03-2009, 04:48 AM   #19
DBM
Let's Just Ride!!
DBM's Avatar
Oddometer: 1,845
OK, so the KTM EXC triples are a direct bolt on, right? The EXC bearings and stem will fit into the DR frame with the DR races, right?
Sorry to hijack.....I am just getting ready to a DR build up myself, and plan to do a similar complete front end swap. Does anyone know of a upgraded shock from a DRZ or MX bike will fit?
THX
08 530 exc
07 XR650L
04 525 exc
DBM is offline   Reply With Quote
Old 06-03-2009, 06:00 PM   #20
sander
sander's Avatar
Oddometer: 193
I've read it on some forums that the dr350 uses the same hub as the dr650 only with a 18" rear wheel. Like to use that because of the availability of tires when you're somewhere near the edge of the world.
If you measure the ID OD and the height of the bearing you need. I'll look through some books see if there's some standard bearing that matches up.
Originally Posted by Luushen
what panniers ?
motosport frames with mtd boxes. Think I will mod the frames so the're symetrical and connect them for extra sturdiness.
Yeah bit disappointed with the tires, I was hoping the would last like the trailwings (7000km)
Old 06-03-2009, 06:54 PM   #21
DisTech
DisTech's Avatar
Oddometer: 596
Whistle? Mine down right howl! I tip to the side a bit sometimes just to get them to shut up, ha.
They may be loud on the hiway but I love them and for $75 they don't have to last that long.
Mezo, that will be one righteous DR when you're done. Good luck and keep the pic's coming.
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 06-03-2009, 07:14 PM   #22
sander
sander's Avatar
Oddometer: 193
Earplugs and a gsxr muffler work wonders against the howling
I like the tires it's just that I don't like changing tires 4/5 times a year. And for an around australia trip you want to find something that'll last 7/8000 km just so you end up in big cities when you need to change them.
Old 06-05-2009, 01:33 PM   #23
LukasM
Oddometer: 4,904
Ok, I'm back.
On my bike I left the stock DR cups aka races in the frame, and then put on the EXC triples/stem/bearings. I also re-used the DR dust seals, maybe KTM ones will fit but I haven't tried.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 06-06-2009, 05:35 AM   #24
DBM
Let's Just Ride!!
DBM's Avatar
Oddometer: 1,845
Excellent!! I am assuming that 03 to present EXC front ends will fit 96 to present DR 650, right? Do you know if a higher quality shock from another off road or MX bike will fit? I saw a post that a Ohlins shock from a 96-97 KTM 2 stroke exc will fit, but that must be pretty hard to find. I know there is a Wilbers shock available but I don't want to spend that much for a new shock. I can buy near new original shocks from parted out current models for around 100 bux.
DBM
08 530 exc
07 XR650L
04 525 exc
Old 06-06-2009, 08:53 AM   #25
torben c
Oddometer: 27
On my pre 96 DR 650 R, i just pressed out the KTM stearing steam of the lower KTM clamp. Then pressed in the old DR steam in the KTM lower clamp. Voula !! and I could use the DR bearings Had to machine a spacer for the top bearing, but i worked fine.
Happy projekt.
torben c screwed with this post 06-09-2009 at 03:19 AM
torben c is offline   Reply With Quote
Old 06-08-2009, 05:37 AM   #26
30Bones
30Bones's Avatar
Oddometer: 4,572
Very nice! I really love this build and all the components. I LOVE my KTM, but sometimes wish I had a DR/XR motor and KTM suspension/brakes.
Today is the tomorrow you worried about yesterday
30Bones is offline   Reply With Quote
Old 06-08-2009, 08:33 PM   #27
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,574
Tito's vodka a weber grill and the rocky mountains,...it all goes away!
Utah Bones is offline   Reply With Quote
Old 06-13-2009, 05:51 PM   #28
jtb
jtb's Avatar
Oddometer: 1,797
You're mad!
But in a good/rich way! Good luck I'll be watching this one for sure!
If you always do what you always did, you always get what you always got!
jtb is online now   Reply With Quote
Old 06-14-2009, 01:50 AM   #29
warnabrother
.. if you see the Rozzers
warnabrother's Avatar
Oddometer: 2,021
bikeless...
warnabrother is offline   Reply With Quote
Old 06-17-2009, 12:49 AM   #30
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,766
Mmmmm.....
I must start work on my spare head.
NordieBoy is offline   Reply With Quote
Times are GMT -7.   It's 03:12 PM.
