Old 02-03-2014, 10:32 AM   #1
indr OP
Oddometer: 501
What's new in custom molded earplugs?
indr screwed with this post 02-22-2015 at 08:58 PM
indr is offline   Reply With Quote
Old 02-04-2014, 03:53 AM   #2
smithdt
Oddometer: 81
Originally Posted by indr View Post
There's the kits you can buy and DIY at home like the Radians which run $20-$30.
Then there's the ones you can go to a hearing specialist. And they use fancy molds to make you one. They run $100+
If you're using one of these, how long have you been using them, how are the working out? If you have the expensive ones, what it money well spent? Are they painful? Do they come loose? Tell me everything.
G'day Indr
This may not be very relevant to you as I'm in Oz, but I've had a pair of custom moulded earplugs (with in line stereo speakers) for about 4 years now. The mould themselves have lasted very well, but the speaker cable outer insulation is starting to split in some area's.
I wasn't aware of the Radians product - but they look pretty good and are very similar to the way the ear mould plugs are custom fitted over here. Although they don't seem to have the final protective coating of clear silicone.
http://www.youtube.com/watch?v=yF7u-hle380
The ones I have were about AU@270 - given the exchange rate and the bullshit prices we pay for stuff over here, it's probably close to the US$100+ you mentioned.
Money well spent? - shit yeah. Wish I'd got them about 20 years ago.
Painfull? - NO - the usual off-the-shelf plugs start to hurt my ears after about 30 minutes (which is why I never wore any- which is why I've got a bad case of "industrial deafness" now).
The moulded ones I can wear all day and they only start to get a little uncomfortable after very long rides (12+ hours).
Come loose? NO. The silicone doesn't shrink and they're moulded to your own ear cavity, so they're always very snug.
smithdt is offline   Reply With Quote
Old 02-04-2014, 06:30 AM   #3
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,679
The $20 "at home" molded plugs are basically the mold material that you would send in to the company that will mold the $100 silicone plugs for you.
The $20 versions will last you a year, maybe two, and then you will need new ones. They are not as durable or water resistant as the silicone plugs.
However, either version is, IMO, better than the round barrel type earplugs. Anything that is molded specifically for your outer ear and ear canals will be more comfortable and a better seal than the fits-all type.
I have a pair of the silicone versions that I have been using for at least 7 years. My son, a trapshooter, gets the $20 pair every year as his ears are growing and changing shape.
Old 02-04-2014, 10:30 PM   #4
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,018
I have Radians that I made into ear buds and custom ones I did at a show for about $50 (we did 3 sets, so got a discount).
Custom feel a lot better after 3-4 hours and seal a little better.
Radians could have been better but it's a learning experience. If I had bought 2 kits, the 2nd would have been a lot better than the first.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 02-04-2014, 11:56 PM   #5
TourPros
Local wherever I go
TourPros's Avatar
Oddometer: 2,045
Plugs
There are many do it yourself kits. Like anything else however you get what you pay for. You can search my name in Vendors and see what I recommend. I would be happy to answer any questions you may have. We do molded ear plugs as well as molded ear monitors.
Cheers
Hell I've been thrown into better places and got friends I ain't even used yet.
Hug those you love often And turn life up !!!
I really like what your are trying to do. I'm just not sure about how you are trying to do it. It's been a pressure working with you and the pleasure was all yours. If you need me I'll call ya..
TourPros is offline   Reply With Quote
Old 02-05-2014, 07:12 AM   #6
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,419
I went with Dream Earz, recommended by Tourpros a year or so ago. They sound amazing when they don't break the seal. I wish they weren't hard acrylic, but otherwise they're well made and the owner was excellent to deal with. Ultimately, I don't wear them as often as I'd like because of the occasional broken seal in the ear. Bummer. They were expensive. It took 2 go's to get them to this point, and some rigamarole with acrylic nail polish.
My old Big Ears were awesome, after 4 trips back to them, but I lost them unfortunately. They showed me how great custom could be, but also how difficult it is to get a good fit. For me, I wouldn't bother unless you are really sure you're getting the correct fit.
Good luck
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 02-05-2014, 11:07 AM   #7
massrider
massrider's Avatar
Oddometer: 186
I had a molded set made, about $60, at one of the big MC shows last winter and I really like them over the foamies I had been using. It used to drive me crazy if one of the foam plugs wasn't in correctly, which seemed to happened often, and I really couldn't tell until I started riding so I would have to pull over and take off the helmet to fix it. With the molded plugs I have only had a few times it didn't seal correctly. They are also much easier and faster to put in...especially if it is raining and the foam ones get wet and won't compress.
I can't help with the DIY kits but the guy that made mine said some of the cheaper ones just use the mold material as the plug and that it only good for a year or so, I'm not sure what the actual material mine are made from but they seem very durable and clean easily. I had mine made in HI-VIZ so I won't loose them.
I never tried a DIY kit but it doesn't seem like it would be too easy to get it right on the first try.
You can't fix stupid......but you can vote them out of office
massrider is offline   Reply With Quote
Old 02-05-2014, 03:21 PM   #8
TourPros
Local wherever I go
TourPros's Avatar
Oddometer: 2,045
Good luck
Sorry it took that to get them to fit right. Its unfortunately a budget thing. The ones I use are soft and provide 100% seal. Different company however
Old 02-05-2014, 07:08 PM   #9
kenstone
newb
Oddometer: 667
Less than $10 shipped
http://www.amazon.com/Radians-Custom...ref=pd_cp_hi_2
kenstone is online now   Reply With Quote
Old 02-06-2014, 05:34 PM   #10
Baroquenride
Oddometer: 910
So the Radians have a NRR of only 26 vs my standard barrel-shaped foamies that are about 32. Those of you that have the Radians- are you saying they're quieter than foamies, and if so how is that possible???
2000 Honda VFR800, 2008 Husqvarna TE-610
Baroquenride is offline   Reply With Quote
Old 02-06-2014, 06:49 PM   #11
trc.rhubarb
Oddometer: 2,018
For me, I have stupid tiny ear canals... The radians are quieter because they fit properly. The foam ones and all the variants I've tried so far rarely fit well and when I get them in all the way, they hurt. So they work a ton better than the nothing I used most of the time. The question wasn't about disposable vs permanent, just offering what I've used.
Follow me here
Old 02-06-2014, 07:18 PM   #12
peterb
Long Distance Adventurer
peterb's Avatar
Oddometer: 239
noise attenuation
I have ridden many hundreds of 1,000s of miles - probably 500,000 at least. I have many molded plugs, a couple w/ speakers, several without.
What I have found works the best are the multi-colored Howard Leight Laser Lite disposable plugs.
What happens is that the molded plugs transmit a lot of sound through the dense hard material [at highway speeds]. The Laser Lites are very effective sound attenuators.
peterb http://ppldma.com/
2000 BMW 1150 GS with >165k miles and more to come...
2007 BMW R1200RT - new 4/08 with >145K smiles ...
peterb is offline   Reply With Quote
Old 02-07-2014, 07:03 AM   #13
rockydog
just a guy
rockydog's Avatar
Oddometer: 855
I've had custom ear speakers from PlugUp.com for 10 years of so. I also have tried the foam types and the cheap kits, really no comparison in sound reducing quality and function in my case. I use mine when working with power tools, also. plugs aren't that expensive but good earphones are. If you are at a event where a custom vendor is selling earplugs or earphones, check them out, the investment might pay off in the long haul, but each individual eventually finds their best solution
Two lane roads and two bit towns
Rockydog woofs the Isles, British Isles
rockydog is online now   Reply With Quote
Old 02-07-2014, 09:50 AM   #14
wsmc831
wsmc831's Avatar
Oddometer: 773
I have two pair from plugup currently, one as a backup. The fact she repairs them so quickly and cheaply means the investment isn't so bad, she's put a new cord on one pair twice, 35 dollars each time. I've tried many others for music and used ER6's for a while, but the sound isolation is much better with the silicon molded, music volume is pretty low as well and can still be heard well.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 02-07-2014, 08:59 PM   #15
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,659
I feel the same about the radians, I just did a pair 2 weeks ago and I'm not really happy with them, but I think if I did it again it would be better next time. Probably going to pursue the Sugru product next time, real silicone and half the price of the radians.
AviatorTroy is offline   Reply With Quote
Times are GMT -7.   It's 05:19 PM.
