Old 05-31-2009, 09:25 AM   #16
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,982
Originally Posted by Oly
Patman's write-ups are top shelf.
You going to WMRS this year BgrAl?
Yessir!! I wouldn't miss that one for the world. I'm hoping to do the Silver Canyon bit this year, as my hip is fully healed and ready to go. Plus, I'm guessing that Gillafunk will do it, and that's gotta be good for some laughs.
My wife rode her KLR250 all the way to WARP and back, a total of 883 miles, and she spent the entire weekend giving Kiel crap about him parking his truck at your place and riding in.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 05-31-2009, 01:40 PM   #17
bgoodwin
Got Parelli?
bgoodwin's Avatar
Oddometer: 1,172
My '07 will turn 30k miles in a coupla days. Replaced the broken Doo and spring at 19k, no other problems.
'09 KLR650 Black
Buncha mules and horses
"Take the time it takes, it WILL take less time"
"Listen guys...the only way to insure a successful prosecution...is if I get away" - Me to Al Goodwin and DeBandi
bgoodwin is offline   Reply With Quote
Old 05-31-2009, 07:48 PM   #18
Feo
Now What?
Feo's Avatar
Oddometer: 5,210
Originally Posted by Bigger Al
I did the mod listed in this link, and my oil consumption went down by about 80%. My bike is a'95 with about 23,000 miles, and it used to burn about a quart every 300-400 miles at higher freeway speeds. The PCV mod is simple, cheap, and very effective, at least on my bike. And yes, YMMV.
http://klrworld.com/forums/index.php/topic,11110.0.html
Did the PCV mod awhile back. Haven't seen any real improvement.
Judging by my rear fender, I've got worn rings and cylinder issues.
______________________
Use tools, don't be one.
http://www.advrider.com/forums/showthread.php?t=949341
Feo is offline   Reply With Quote
Old 06-01-2009, 04:50 PM   #19
Dakar dreamer
Dave rocker
Oddometer: 189
Originally Posted by georgej
A '93 with 14,000 on it,properly maintained with maintenance records. Is this bike good for a few more miles before needing any engine work? How many miles are these bikes good for?
I have seen some people report over 100,000 miles.
Dakar dreamer is offline   Reply With Quote
Old 06-02-2009, 11:31 AM   #20
dualsportdave
dualsportdave's Avatar
Oddometer: 93
1988 with 11,000 original miles - runs strong, but it does smoke a bit on startup - maybe rings? valve guides? Had valves adjusted last year. Seems like it has good compression and makes good power. Has been rejetted.
dualsportdave is offline   Reply With Quote
Old 06-02-2009, 11:41 AM   #21
CA Stu
CA Stu's Avatar
Oddometer: 47,801
disabled the vacuum carb
Did you go EFI or what?
CA Stu
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 06-02-2009, 02:10 PM   #22
Bigger Al
Bigger Al's Avatar
Oddometer: 7,982
CA Stu
Steve McQueen
Old 06-04-2012, 10:25 PM   #23
Fishlegs
Fishlegs
Fishlegs's Avatar
Location: Shawnigan Lake, dirt bike capital of vancouver isl
Oddometer: 14
klr with 60000 kilometers
CA Stu
looks like your a king diamond fan! i remember listening to mercyful fate when i was a teenager..
Fishlegs is offline   Reply With Quote
Old 06-04-2012, 10:47 PM   #24
bush pilot
bush pilot's Avatar
Oddometer: 2,526
I got about 75k miles on my travel bike, an 06' model. Installed the 685 kit at 30k. (it started using oil, overheated, my fault)
At 50k took the forks apart, teflon bushings nearly completely wiped out.
I hear there are few guys around with well over 100k on their bikes. I'll probably hit 100k later this year! The suspension will be due for another overhaul at that time I reckon.
EverReady bunnies they be!
USA travels 09'
Anchorage to Ushuaia
RTW...part: Europe
Iron Butt #35784
bush pilot screwed with this post 06-04-2012 at 10:54 PM
bush pilot is offline   Reply With Quote
Old 03-28-2013, 04:50 PM   #25
Chaos-in-MT
OK lets GO!
Chaos-in-MT's Avatar
Oddometer: 446
Klr
I gave my old one to my brother 8 years ago with 85K on it. He is still riding it.
Some people suffer from insanity, Me I just enjoy it.
Chaos-in-MT is offline   Reply With Quote
Old 03-28-2013, 04:55 PM   #26
KustomizingKid
Oddometer: 678
33k on mine and it needs rings.... Or a 1 gallon rottela t iv drip
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 03-28-2013, 06:18 PM   #27
71olds
Motorholic
71olds's Avatar
Oddometer: 1,107
95 with 32k on it. Need to do the doo no clue if it was done.
only put 1000 miles on it so far but no noticeable oil use after 1000 miles.
09 Night Train
08 Kawasaki ZX14
08 Husqvarna TE510
00 Suzuki DRZ400S
71olds is offline   Reply With Quote
Old 03-28-2013, 07:01 PM   #28
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,799
Good?!
From mile one the KLR is barely adequate.
Mine was barely adequate for 35,000 miles until I sold it.
Boon Booni screwed with this post 03-30-2013 at 05:02 AM
Old 03-29-2013, 06:20 PM   #29
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 11,290
I bought my 640A from a guy that had a KLR. He sold his KLR to buy the 640. Said he sod it with 62k miles on it. He said that he would have rode it longer, but wanted to try something else. There is no substitute for anal retentive maintenance.
all around good guy
barnyard is offline   Reply With Quote
Old 03-30-2013, 06:19 AM   #30
Jim patton
Oddometer: 21
23,000
23,000 on mine. It doe not use any between oil changes. I have done
The doo and most other mods. Good thread on this at KLR net, many guys
Over there have 80,000. Oil changes at 2000 mi. Chech valves every
10,000. Keep up on other maintenance, don't cruise over 5000rpm,
Seems to be the trick.
Jim patton is offline   Reply With Quote
Times are GMT -7.   It's 02:38 AM.
