Old 06-06-2009, 09:23 AM   #1
DaFoole OP
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,213
Garmin 276c Voltage display question
Have decided to move out of the stone ages and update my 12MAP....
Want to get a 276c as it will work on the boat/bikes/cage. Mostly swayed by the 12v display as I like this as a heads up on possible electrical issues. Can the display be set up on the screen as permanent display or is this only on start-up/shut down?
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 06-06-2009, 03:19 PM   #2
AugustFalcon
AugustFalcon's Avatar
Oddometer: 1,054
Yes, it can be set up to display on any of the screens on my 276C.
It can also be set to alarm if the voltage drops below a chosen set point value.
cheers... jack
04 BMW R1100S
02 KTM 250 Exc Racing
SmugMug referral code: jXF8ohDWlTm56
AugustFalcon is offline   Reply With Quote
Old 06-06-2009, 04:37 PM   #3
DaFoole OP
DaFoole's Avatar
Oddometer: 4,213
Excellent!! Thanks! That was the info I needed!
Old 06-09-2009, 06:25 PM   #4
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,690
I use it to monitor my voltage while running heated gear. Vstrom won't handle all of it on at once (gloves, jacket, pants, socks) so I have to regulate.
Make sure to verify voltage with a volt meter. My 478 reads 0.2 volts lower than my volt meter. Better yet it to verify voltage from the battery with only the unit on (no lights, pumps etc), then you'll know at which point you are discharging the battery.
Times are GMT -7.   It's 12:57 AM.
