Go Back   ADVrider > Riding > Regional Forums > Canada
Old 03-09-2013, 03:07 PM   #8281
Hektoglider
One with Life
Hektoglider's Avatar
Oddometer: 2,536
Originally Posted by GreatWhiteNorth View Post
...! Got it home, put away, new coil ordered from Headingly Sports - I guess I've got an excuse now to install the uprated spare stator and new voltage rectifier that I already have. 20 year old bike, gotta expect a few glitches... glad that didn't happen middle-of-nowhere Flatskatchewan on a road trip!
Have you bypassed the clutch and kickstand switches. I will bet $ the ignition coil is fine. Unless you meant pickup coil? You are 100% certain it was ignition problem & not fuel related?
KLR's seldom let you down.
When you figure it out, post up. I suspect a bad wire somewhere. Maybe.
Ride Our World
Hektoglider is offline   Reply With Quote
Old 03-09-2013, 03:32 PM   #8282
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,545
We'll find out
Could be a lot of things. It backfired a few times and smelled flooded... pretty sure it's weak spark. Hopefully it's nothing to do with the CDI module (they're pricey!). Yup, all safety switches bypassed BTW. Have done a bit of on-line research as I like to run heated jacket liner & gloves. This is why I want to replace my stator by installing the uprated one. I found several posts that say that the ignition power is provided by the stator (has special windings) and ignition should be unnaffected by battery/voltage regulator condition/charging... saying once running you could actually disconnect the battery! There is also a pulse coil that reads crank position that could be toast. ...all part of the "getting to know your KLR" program!
Edit - did NOT have heated jacket liner & gloves plugged in today BTW.
GreatWhiteNorth is offline   Reply With Quote
Old 03-09-2013, 03:43 PM   #8283
bwokentoof
Pollyanna Man
bwokentoof's Avatar
Oddometer: 359
Had a similar thing happen to me last week. Turned out to be a frozen gas cap vent.
bwokentoof is offline   Reply With Quote
Old 03-09-2013, 03:56 PM   #8284
GreatWhiteNorth
Oddometer: 2,545
That'd great if it was!
Suspected vacuum lock too... popped the fuel tank cap - no vacuum present and no change. Full disclosure - it did it last ride in January too... got 2 or 3 blocks from home and died. This ride today was further investigation... was running well until it suddenly faded. Letting it cool down 10 or 15 minutes and I restarted and rode home. It seems to be heat related (and electrical). Battery was fully charged this morning BTW.
Old 03-09-2013, 03:59 PM   #8285
SoSlow
Having fun
SoSlow's Avatar
Oddometer: 933
That's where I'd put my chips...
2009 KLR650
1986 TT225 (work in progress)
SoSlow is offline   Reply With Quote
Old 03-09-2013, 04:01 PM   #8286
SoSlow
Having fun
SoSlow's Avatar
Oddometer: 933
... of course, I tend to be wrong on a regular basis.
2009 KLR650
Old 03-09-2013, 04:27 PM   #8287
PiffleMaster
PiffleMaster's Avatar
Oddometer: 2,256
As always, and as you know, check the easy things first; grounds, frayed cables, corrosion on connectors, fuel and air...
That said, I think (all the above being equal) your diagnosis of a weak coil is spot on. The symptom of running fine when cold then crapping out with time (heat) sure points to a bad coil. (And it's cheaper to replace when troubleshooting than a CDI.)
If you need to test further with a known good coil you can steal the one out of mine. (Assuming they're interchangeable.) I won't have need of it for a wee bit...
Cheers, Brian
"He never met a stranger." Drif10 re DRCool
Have Sporadic Spot, will travel sporadically...
And a picture outside my window... Sometimes...
PiffleMaster is offline   Reply With Quote
Old 03-09-2013, 04:48 PM   #8288
GreatWhiteNorth
Oddometer: 2,545
Thnx Brian
Appreciate you chiming in. Maybe I should consult the book of wisdom (factory manual :^) ProCycle offers a new replacement CDI box for $125 - I e-mailed them to see if it's available yet (just in case). Won't be long before much of the old electrics is replaced on my bike!
Hope you heal up quick... you should be fixed up by proper riding season - will the Beemer? Hopefully MPI won't write it off (plastic is bloody expensive!)... tough way to change your ride.
Old 03-09-2013, 05:04 PM   #8289
PiffleMaster
Oddometer: 2,256
Hey Darryl,
Should be good to go after the surgery (and a bit of time), but the beemer will be sidelined for this season. Had multiple trips already planned with the KLR to the east, (Icebreaker, EOAR, Trans Lab and Newfoundland) so the RT was going to sit fallow anyway. It was plated and insured in the NWT with just liability on it, so MPI won't have anything to say about it.
I've sourced the plastics on Ebay Motors, and it'll be doable (assuming mechanicals are ok) when I get around to it.
Cheers, Brian
Old 03-09-2013, 05:06 PM   #8290
PiffleMaster
Oddometer: 2,256
Originally Posted by BOBMUNZ View Post
Glad to hear you survived, hopefully things are back in order for riding season.
Good to hear from you Trevor, I purposely set this up just to get you to chime in.
Glad to know you're still with us.
Cheers, Brian
Old 03-09-2013, 05:08 PM   #8291
GreatWhiteNorth
Oddometer: 2,545
Good to hear
Originally Posted by PiffleMaster View Post
I've sourced the plastics on Ebay Motors, and it'll be doable (assuming mechanicals are ok) when I get around to it. Cheers, Brian
Nice - too many bikes written off too quickly (by MPI) IMO.
Old 03-09-2013, 05:31 PM   #8292
PiffleMaster
Oddometer: 2,256
Originally Posted by waterlilly View Post
hope your feeling better Brian, heal well.
your friends at DSP.
Thanks Katharine, things are definitely looking up.
It's been humbling (and energising) getting well-wishes from so many people.
My sincere thanks to all.
On another note, yesterday the doc told me I had to sleep sitting up, to relieve pressure on the shoulder until the surgery; but my old lazy-boy had three old keyboards in place under the seat to take the place of broken springs, and wasn't really that comfortable to sleep in...
Today my sweetie talked me into getting a new "electric" Lazy-Boy... and I'm now in 7th heaven. :-)
WooHoo!
Cheers, and thanks again to everyone, Brian
Old 03-09-2013, 05:58 PM   #8293
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,470
Thought that looked like a Polar Bear plate on it
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is offline   Reply With Quote
Old 03-09-2013, 06:22 PM   #8294
PiffleMaster
Oddometer: 2,256
Yup...
Old 03-09-2013, 06:27 PM   #8295
Hektoglider
One with Life
Oddometer: 2,536
I agree the coil symptom usually is: runs good cold, dies when hot.
One common issue is the vacuum line for the petcock or the petcock diaphragm. My line had a small split in it & fuel flow was impeded. Just throwing it out there......20 year old stuff on your bike 10-4 on the safety switches.
Ride Our World
Times are GMT -7.   It's 01:55 PM.
