08-17-2009, 06:54 PM
#121 |
Ride you must.
Oddometer: 1,675
Probably just puked some coolant on the header. A catch bottle is good to have to put it back when the bike cools.
Regarding my LHRB. It would be far better to have a clutch over ride for street down shifts. Down shifted half or more of the time clutchless in the dirt before the Recluse. I rigged my rear brake pedal to do just that but found that mineral oil is a no no for its seals. Haven't fixxed it yet. I'm afraid having two levers would be terrible to use. Difficult to brake hard into a corner and modulate the clutch lever with the same hand. |
08-17-2009, 07:01 PM
#122 | |
Geek Adventurer
Oddometer: 4,601
'09 Husaberg FE570 '99 Beta Alp '04 Ducati MTS - sold Not all who wander are lost |
08-17-2009, 09:55 PM
#123 | |
flaming ahole ;)
Oddometer: 5,343
alternatively, you could source new rubber bits to use mineral oil, though it may be hard to find mineral-oil-compatible caliper components. there's a reason they use brake fluid in brakes (heat).
Blue KTM Forum now!!! ![]() -- '09 Husaberg FE570 '05 BMW R1200GS |
08-18-2009, 05:53 PM
#124 | |
Ride you must.
Oddometer: 1,675
08-19-2009, 11:01 AM
#125 | |
Oddometer: 1,685
I now only use the CRF for trail riding, but the Rekluse clutch makes it a decent trail bike. I have had the clutch for over 6 years now and look forward to getting one on my new XR650R DS bike. I also have the Rekluse rear hand brake (I have no clutch lever) and it is another great product, but it does take longer to get used to than the clutch.
"If you ain't slidin', you ain't ridin'" SVN/XRR/Christini |
08-19-2009, 06:00 PM
#126 |
Ride you must.
Oddometer: 1,675
Research reveals that the Magura clutch setups are mineral oil and Brembos are brake fluid. I found a few instances were some years had both installed. Beginning seems to be '05 on fours but earlier on two strokes. Magura was still used up until '06. I need to get a clutch slave from an '07 or '08 to replumb my rear brake pedel/clutch over ride.
08-20-2009, 01:09 PM
#127 | |
Geek Adventurer
Oddometer: 4,601
08-20-2009, 01:12 PM
#128 | |
Geek Adventurer
Oddometer: 4,601
08-20-2009, 05:15 PM
#129 | |
flaming ahole ;)
Oddometer: 5,343
the rear hub for the SM does have a cush drive.
09-07-2009, 06:09 PM
#130 |
Geek Adventurer
Oddometer: 4,601
Getting to like the Rekluse more and more. Getting used to it, but it has a few quirks that aren't really its fault I guess, just a side effect.
Today I went to Machias to practice some more and it was kind of wet out there so the trails were bit more slippery. The bike seemed to lose traction and then suddenly find it a lot, making it harder to control. It wasn't until I was practicing some hill climbs that it finally dawned on me that I was riding around in second gear on stuff I was used to riding in first gear on. The bike would actually spin the wheel more that way. When I re-rode the same trails and hills in first I wasn't spinning the rear wheel as much, even though I was going the same speed. On the hill I think it was just that the bike had the low end power that it just muscled up the hill rather than bog down. That combined with the Rekluse just kept it going - between the power and the clutch, very forgiving, but I did notice the difference naturally. Anyway, practiced some more climbing some small hills, even did some jumps off the top of one small one. That was fun, but I could tell the bike was not setup for my weight. If I did a big jump it would have been too much. Once I get the damper and ride a bit with that, then I will get the suspension reworked for my weight and style of riding.
09-07-2009, 11:34 PM
#131 |
Oddometer: 437
Did some riding on mine here in N.H. this weekend on some very rocky trails,3rd and 4th gear stuff.Muscles in my upper back are still sore from holding on.I still have not run the map switch on anything but standard.
09 Husaberg FE 570 07 Honda XR 650R 11 BMW R1200GSA |
09-08-2009, 01:14 AM
#132 | |
Geek Adventurer
Oddometer: 4,601
I am also thinking I would like the Christini mod, but they are being conservative about new kits because of the economy.
09-08-2009, 12:23 PM
#133 | |
Oddometer: 1,685
09-08-2009, 04:01 PM
#134 | |
Geek Adventurer
Oddometer: 4,601
I used to think it would do the opposite - that in a higher gear you aren't applying as much torque, right? But after thinking about it, if the engine can handle it without bogging, it is actually trying to spin the wheel faster. Of course, it depends on where you are in the power curve - I was just right off idle. So yeah, I figured it would be just like slipping the clutch, only you wouldn't notice it as much because it does such a good job of it automatically. I try to be in the right gear and not abuse it, plus IMO (and now experience) it makes the bike easier to ride when I am doing it right, but it is nice to know I can make mistakes and it helps compensate for them - to a degree - not near as much a problem as if I bog the bike and kill it. Overall I think the Rekluse is probably less hard on the clutch than I am when I flog it manually. I do notice it when I am too many gears up, but sometimes I mistake second for first when putzing along.
09-08-2009, 04:38 PM
#135 | |
flaming ahole ;)
Oddometer: 5,343
![]() You're actually applying more torque. If you've ever set the valves on an R-type BMW, one often put the tranny into 5th or 6th gear to enable moving the engine by hand. Our TDI Jetta can light up the front tires if my wife or I attempt to accelerate up the hill out of our neighborhood. It's especially bad in the wet. It will spin up in first, shift into second and into third - spinning happily the whole time. I just wish it had AWD.
