Old 06-08-2009, 11:54 AM   #1
TSPKTM OP
Ride 'em Cowboy
Oddometer: 34
2730 error message "check antenna"
I have a 2 year old 2730. The gps functions perfectly but, when I try to use the xm radio I get a message saying "check antenna" It seems to be connected just fine. One of my riding buddies has a new unit with xm. I tried to use his antenna (hockey puck) with the same resulting error message. Any suggestions?
TSPKTM is offline   Reply With Quote
Old 06-08-2009, 07:50 PM   #2
BeemerBerg
Oddometer: 9
Pissed
Join the club. The little pins in the USB cable from the hockey puck tend to "wear out" and not make proper contact. The only solution I have found is to get a new USB cable with the same size plug, cut and solder onto the hockey puck.
Or pay Garmin ~$110 to fix it.
BeemerBerg is offline   Reply With Quote
Old 06-10-2009, 02:14 PM   #3
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,339
Yeah, I'm about to have to try this with my antenna and splicing a new cable. It bit the dust a while back and now has either a short in the USB cable or the plug is just plain worn out. Either way, it shows "check antenna" when connected to 3 different GPS's. 376c, 478, or 2820.
I did notice before mine went totally tits up, the antenna started rebooting itself at random intervals with greater frequency. I guess that was the precursor. Then I started getting a message here and there about checking the ant, but it would still work. now I'm just plain lucky if I actually get it to work.
I know my USB plug on the GPS is still fine, because it still talks to my PC when connected. It sounds like the OP's might actually be the USB plug on the GPS if it did it with 2 different antenna's.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Times are GMT -7.   It's 01:18 AM.
