06-18-2009, 09:09 PM
#16 | |
Oddometer: 699
My bike blog and photography site |
06-21-2009, 05:27 PM
#17 | |
Oddometer: 464
If you have starter problems, check to see if the starter has been shimmed, this was/is the best way to fix the crappy starter, or wack it with a small hammer
Don't pick a fight with an old man. If he is too old to fight, he'll just kill you.
If you find yourself in a fair fight, your tactics suck |
06-21-2009, 06:27 PM
#18 |
Oddometer: 160
were there any frame differences between the 920's in the states? (like suspension geometry) or if a guy wanted to build up a sporty xv920 could he find a cheap virago, get a 920R tank and go from there?
06-24-2009, 03:34 PM
#19 | |
XV920CR
Oddometer: 23
06-25-2009, 05:28 PM
#20 |
Oddometer: 160
do you recall what was different about the geometry? if i got one i'd be cutting it apart quite a bit, i'm fine with doing custom rearsets but messing with the fundamental design of the frame doesn't really tickle my fancy. this picture really opened my mind to the posibilities...
09-06-2009, 10:43 AM
#21 |
Oddometer: 1
Virago Geometry
I've got two and "a half" 1981 XV920Rh's. One has the innards from the later shaftie XV1100 in it (XV1100RH?) and a Pichler fairing. The other has flatter handlebars and a "traditional" rear fender. It took me about 6 months to "learn" how to ride this bike -- it needs to be ridden in a completely different way than my 1982 GS1100G, which is why I got it.
Anyway: The steering geometry is changed by the height of the rear tire: a short, fat 16" on the shaft-drive model, and a taller 18" on the chain-drive model. Joe Minton did a great article on "Vitalizing the Virago" ( http://viragotech.com/ ). Basically, the old-school method used to be: front and rear progressive springs, (choose your viscosity) front fork oil, swap the steering head ball-bearings (I know!) for tapered bearings, and add a fork brace. The enclosed chain drive is sheer brilliance. I love the giant headlight. I, too, am intrigued by the "Zero Cafe" Virago. If you look closely, you can see that he left the original spine frame (I'd love to replace mine with a light-as-air Ducati style trellis: sigh. His sense of proportion and balance is perfect. Replicating his work should be rather "easy," since the rear/seat portion just unbolts. Why do a Virago cafe? Good question. It's big: with that 58-inch wheelbase, it's no "flick" bike (convert a dirt bike to be a cafe racer, if that's the experience that you want. Another projecct that I want to do...). It's heavy: 500+ pounds. It's got a high center of gravity. Yada yada yada. The reason "why" is the engine. It's torquey. It has a relaxing cadence that took me 6 months to understand; I kept trying to crack the throttle like on my inline 4 GS1100, and kept feeling frustrated and disappointed. Then, I learned how to let the bike teach me how it wanted to be ridden. Aww, man... The engine is nice to look at, too. (I never liked the look of the Suzuki VX800 engine...) It's all personal preference: that's all that matters. Bike-hating is so irrelevant. What unites us is two -- sometimes three -- wheels. 20-30 years ago, the IIHS was making strong inroads to legislate motorcycles out of existence. Anyway. Our bikes are platforms for creative and artistic expression. If a Cafe Virago/Gold Wing/Voyager/Rokon does it for you, then fine. May the ties that bind us together be stronger than the forces that would tear us apart. kentinstow |
09-09-2009, 04:23 AM
#22 |
I am a proud owner of the european version of the XV920, which is called TR1 and has 980ccm, instead of 920 in the US.
On the early models (81-82) the rear headgasket tends to blow, because of some edges on the cylinderhead. There are some companies in Germany, which can sort that for you by welding it up and then flattening it again. Except from that, the starter is dreadful, but certain versions of the Virago 1100 starter will fit and these will also have a little more oomph. Progressive springs in the front and in the rear (the air-assisted shock is basically alright), plus some steel-braided-brake-hose plus a good set of tyres and you have a nice bike for everyday use. But be aware of the fact, it will never be a true sportbike in that way. Ah, and if you exchange the tail-unit with one from a SR500/XS400 it looks a lot nicer... ![]() ![]() ![]() ![]() Cheers, Greg |
09-09-2009, 08:09 PM
#23 | |
Oddometer: 1,039
09-30-2009, 05:06 PM
#24 |
Oddometer: 160
well, I must have had enough good deeds saved up because a friend contacted me and said "I took on a 81 xv750 that needs a little work for my wife but I realized I'm just not about to get around to it..."
2 weeks later I took this from his garage ![]() ![]() time to put my money where my mouth was, eh? |
11-01-2009, 10:00 AM
#25 |
Yeah! I want Cheesy Poofs
Oddometer: 17,784
My XV920R is getting closer to road ready.
11-01-2009, 04:50 PM
#26 | |
Well, maybe...
Oddometer: 1,764
I find myself lusting over Suzuki SV1000's then I saw a cafe'd 920 and can't get it out of my mind. Having spent my formative years (1965 - 1968) in Europe I'm all too familiar with cafe bikes and I want to live that life at least once before I hang up my helmet. Thank for the great reply and insights! |
11-01-2009, 05:16 PM
#27 |
Oddometer: 17,784
Here. Have some more motivation:
![]() ![]() ![]() Here's another take on the rear fender:
11-02-2009, 02:27 PM
#28 | |
Well, maybe...
Oddometer: 1,764
03-31-2010, 07:04 AM
#30 |
Even my posing is virtual
Oddometer: 2,512
Xv920
A good friend of mine had an XV920 here in Montreal back in the early 90's. We went to a moto rally and he got it dynoed. It had a bad flat spot in the power curve. We removed the little intake snorkel that went from the air box to under the seat and the flat spot vanished. He also gained a noticeable increase in top speed. If I remember it put out something in the high 40's or low 50's in terms of HP. My GL1200 at the time cranked a mighty 77.......
04 Toyota Sienna, new wipers for 2011!! Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!! Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway, Website - http://www.apormc.com/ Vids - http://www.youtube.com/user/Motoriley?feature=mhum |
