Go Back   ADVrider > Riding > Mapping & Navigation
Old 06-14-2009, 07:21 AM   #1
HOGCDR OP
FREEDOM ISN'T FREE
HOGCDR's Avatar
Oddometer: 70
Multiple routes on the same map??
How do you layed down multiple routes using the same map but ending each before starting the next. Thus each route has it's own line item and can be highlighted. I know how to do this if the routes starts and ends at the same location, but how do you start a route in Virginia when all others start in Missoula, MT?? How do you turn off the route tool to move to a new location??
HOGCDR is offline   Reply With Quote
Old 06-14-2009, 08:14 AM   #2
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,774
Not sure exactly what you are asking but hit escape (Esc) to finish the current route you are working on with the route tool.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 06-15-2009, 09:51 AM   #3
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
If you want to start a new route, you need to un highlight the existing route. Like tbird posted the escape key will do this. Clicking the arrow or hand unhighlits the route also.
When a route is highlighted, pretty much anything you do affects that route.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 06-16-2009, 07:06 PM   #4
Countdown
Oddometer: 5,916
Thanks, that is so not obvious. I think I had to close the file then reopen to get out of the current Route. Seamed to me that if I click other tool and unselect current route then go back to route tool it reselects the last route.
Now if I can only remember "Escape".
Jerry Counts
Countdown is offline   Reply With Quote
Old 06-17-2009, 05:41 AM   #5
jwd98056
jwd98056's Avatar
Oddometer: 111
You can also do a right click and select Cancel. The Esc key works more reliably. If you use the right click the cursor can't be on top of any POI or object that is in the map database. If you are then the object properties menu pops up rather then the routing menu with "Cancel" selection.
Not that asking questions is an issue, because it isn't, but a better thing to remember might be "Help Menu". Mapsource actually has a halfway decent help section. It won't answer every question that comes up but it answers this one and a lot of others. It might save some time and frustration, especially on a less polished user interface like the one in Mapsource.
Jim or JD from Renton, WA
IBA #32756 - BMWMOA #122647
'05 BMW R1200GS - Desert Yellow (Brutus)
'12 HD Road Glide Ultra - Ember Red Sunglow (JD'sRoad)
'02 HD Heritage Softail - Custom Paint (JDsHog)
jwd98056 screwed with this post 06-17-2009 at 05:53 AM
jwd98056 is offline   Reply With Quote
Old 06-17-2009, 05:44 AM   #6
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 670
This is actually quite a handy feature to have while routing. For example it allows you to zoom in on a city with the zoom tool, find an exact point to place a via, maybe create a favorite or waypoint, zoom back out, use the grab tool to move to the next via location and resume the route planning.
SW
The Weather in my Backyard
Steve W is online now   Reply With Quote
Old 06-17-2009, 11:31 AM   #7
Countdown
Oddometer: 5,916
Now I have to remember that one also!
I normally create Route from start to finish, then zoom in and make waypoints at places I want to stop or know when I am going to get there and then zoom out and drag Route to them. Nice to know I can do them as I make the route.
Just started using Routes with new Nuvi in motorhome. Too many new tricks for me after years with only tracks.
Jerry Counts
Times are GMT -7.   It's 06:32 AM.
