Go Back   ADVrider > Riding > Photos
Old 07-26-2012, 06:36 AM   #5581
Kobus Botha
Kobus Botha's Avatar
Oddometer: 1
Please help
Hi, sorry, can anyone please tell me how to place an picture on this site?
Thank you
Kobus Botha is offline   Reply With Quote
Old 07-26-2012, 07:45 AM   #5582
Ride_Safe
Oddometer: 37
My mini converted adventure bike. :)
http://twistedtravster.tumblr.com/
Ride_Safe is offline   Reply With Quote
Old 07-26-2012, 07:49 AM   #5583
richarddacat
high on honeysuckle
richarddacat's Avatar
Oddometer: 3,539
Ride_Safe,
I could live with those handlebars. Did you need to change cables? Looks like you just re-routed.
neat.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 07-26-2012, 07:57 AM   #5584
bhogalrajnish
NirvanaOnTwoWheels
bhogalrajnish's Avatar
Oddometer: 16
Ya good ones, I need them on my bike as well.
Originally Posted by richarddacat View Post
Ride_Safe,
neat.
Ride to NIRVANA on two wheels.
http://ridetonirvana.blogspot.com
bhogalrajnish is offline   Reply With Quote
Old 07-26-2012, 08:06 AM   #5585
WVhillbilly
WVhillbilly's Avatar
Oddometer: 11,542
Thank you
It needs to be downloaded to Photobucket, Smugmug, or something similar to that.
Then linked to here.
WVhillbilly is offline   Reply With Quote
Old 07-26-2012, 08:11 AM   #5586
Ride_Safe
Oddometer: 37
I replaced the clutch/throttle cable with extensions, but I didn't measure properly and they were still a tad bit short... so I did have to re-route them a bit. And I replaced the front brake line with a stainless steel one. The wiring could have been easily extended, but I was able to re-route it instead, so I didn't bother. As for everything else, it pretty much fit like a glove. Aside from the drill-holes for the handlebar clamp mount, which were a little tricky.
I do have risers on the handlebars, so they are high enough that the hand-guards actually go in front of the wind screen, and the brake line goes behind... as seen here:
(This is with the stock windscreen. It works the same way with the tinted bubble windscreen.)
Old 07-26-2012, 08:15 AM   #5587
richarddacat
high on honeysuckle
Oddometer: 3,539
What do you mean "with extensions"? Longer factory cables from Honda?
I wouldn't know if that took any vibrations out of the bars but I suspect it did.
Mid-TN Tag Riders
Old 07-26-2012, 08:22 AM   #5588
Ride_Safe
Oddometer: 37
Nope. I got custom extensions with my local shop. He has a cable kit with assorted fittings/ends and he just makes them himself to a specific length. I had him rip apart my existing cables to re-use the fittings that didn't come in the kit.
I also put rubber dome sealing washers in between the handlebar clamp and the triple clamp. The quality of the rubber is crappy, so you need to replace them quite often, but they only cost like $2 for 4 of them. Not a big deal, compared to how much they reduce vibrations. You can't see them in the pictures above, though, because they were taken before I did that.
And the silver things on the ends of the handlebars are vibration dampening bar ends. They have a rubber cylinder that goes inside the inner part of the handlebar, so they vibrate but the grips don't.
Ride_Safe screwed with this post 07-26-2012 at 08:32 AM
Old 07-26-2012, 08:45 AM   #5589
James Adams
A few crayons short.
James Adams's Avatar
Oddometer: 10,543
That's great! It reminds me somewhat of how I used to ride my Ninja 250, though I'd expect that the longer legs of the Honda work much better.
505 XC-F · DUKE 690
James Adams screwed with this post 07-26-2012 at 08:53 AM
James Adams is offline   Reply With Quote
Old 07-26-2012, 10:53 AM   #5590
captkumu
captkumu's Avatar
Oddometer: 89
captkumu is offline   Reply With Quote
Old 07-26-2012, 05:12 PM   #5591
the borg
the borg's Avatar
Oddometer: 106
the borg is offline   Reply With Quote
Old 07-27-2012, 02:35 PM   #5592
CUD
Oddometer: 6
My Honda Transalp `89
CUD is offline   Reply With Quote
Old 07-27-2012, 02:48 PM   #5593
Wild Boar
Wild Boar's Avatar
Oddometer: 11
here's mine
Here's my 2009
Wild Boar is offline   Reply With Quote
Old 07-27-2012, 03:05 PM   #5594
RichBMW
RichBMW's Avatar
Oddometer: 2,204
Here's my current 2
RichBMW is offline   Reply With Quote
Old 07-27-2012, 03:10 PM   #5595
noshoes
soñando con México
noshoes's Avatar
Oddometer: 2,215
Latest purchase. 02 Connie. In AK.
Guzzi T3 down in AZ.
XRL also in AZ.
"Buen dia ., Buen camino..." - Bato
noshoes is online now   Reply With Quote
Times are GMT -7.   It's 08:39 PM.
